Old 08-08-2022, 09:33 AM   #51
zicc1835
zicc1835's Avatar
Re: I am from the Desert
been too hot here ....gave in and sent this off to blast yesterday no pitting or scaling just surface rust I got tired of grinder wheeling in 95 + heat and humidity
zicc1835 is offline   Reply With Quote
Old 09-03-2022, 09:43 AM   #52
zicc1835
zicc1835's Avatar
back from Blaster.....he E primed did a test spot with Chassis Satin Black my OCD kicked in and Im scuffing with 400( 0n cooler days/nights ) to get ready for paint
Old 09-11-2022, 08:36 PM   #53
zicc1835
zicc1835's Avatar
I been spraying one side at a time to control over spray I been baking it in my solar oven...tomorrow ill finish painting cross members last pic is after the blast and epoxy prime
Old 09-26-2022, 10:00 PM   #54
zicc1835
zicc1835's Avatar
better weather better progress motor on frame for weight drop spindles & springs are in they been sitting on the shelf since 2016 or we would have bit the bullet on coil over
Old 09-26-2022, 10:28 PM   #55
zicc1835
zicc1835's Avatar
should have converted to these long ago
Old 09-28-2022, 10:06 PM   #56
zicc1835
zicc1835's Avatar
painted and installed
Old 10-01-2022, 08:30 AM   #57
jaros44sr
jaros44sr's Avatar
Nicely done, good detail, keep it up
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-01-2022, 05:16 PM   #58
zicc1835
zicc1835's Avatar
TY Jim
Old 10-01-2022, 05:20 PM   #59
zicc1835
zicc1835's Avatar
SS brake lines and rear feet bolted back shocks and air line for bags and the A$$ is done
Old 10-10-2022, 08:47 PM   #60
zicc1835
zicc1835's Avatar
brake and fuel lines run and clamped cross members bolted in
Old 10-25-2022, 07:25 PM   #61
zicc1835
zicc1835's Avatar
I ran into a road block my engine mounts motor stands that I was so pleased with will not work to far forward they will be on th FS board ...shame on me
Old 10-25-2022, 07:29 PM   #62
zicc1835
zicc1835's Avatar
back to the stock stands .....moving on
Old 10-25-2022, 07:36 PM   #63
zicc1835
zicc1835's Avatar
I got the steering back in b before I figured out the MMs wouldn't work
Old 10-26-2022, 02:26 PM   #64
FRCvette
Great job so far. Did you bend your own brake lines or buy a prebent kit
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 10-26-2022, 03:27 PM   #65
FRCvette
Great job so far. Did you bend your brake lines or purchase a prebent set.
2004 SSR
2013 Silverado swb
Old 10-26-2022, 08:07 PM   #66
zicc1835
zicc1835's Avatar
thanks for kind words ...I purchased them preformed ( the call it ) prebent from Inline Tube ...they are stainless Im told they are very hard to bend and I know my limitations
Old 11-06-2022, 08:58 PM   #67
zicc1835
zicc1835's Avatar
mid 70s here yesterday put him on all 4s pushed out to power wash the filth off the floor since all dirty work is complete.... job will get in the way..... traveling this week
Old 11-27-2022, 05:10 PM   #68
zicc1835
zicc1835's Avatar
getting closer to this frame and suspension drive train portion to completion.... since last post I replaced the PS with new one got all my pulleys lined up new fan on, P coated them along with brackets and flywheel dust cover installed , rebuilt and lined up the Z bar with new linkage made a braided fuel line fuel tank installed and plumbed up to carb Im down to a punch list of about a dozen items
Old 11-27-2022, 05:12 PM   #69
zicc1835
zicc1835's Avatar
oh yah got a minnie me to install.....
Old 12-02-2022, 08:45 PM   #70
zicc1835
zicc1835's Avatar
mini installed
Old 12-15-2022, 10:21 PM   #71
zicc1835
zicc1835's Avatar
https://youtube.com/shorts/5ASNAO81PLw?feature=share It’s alive
Old 12-17-2022, 10:45 PM   #72
zicc1835
zicc1835's Avatar
motor is running cab is back from body shop going to figure out the sequence for putting all the guts back in ...I think vent doors first then park brake then clutch and brake pedal ...wait may be put the harness and gauge cluster while none of that bake stuff is in the way and oh yah the wiper motor defrost hoses etc. ....and so it goes...
Old 12-17-2022, 10:59 PM   #73
zicc1835
zicc1835's Avatar
any hints on reassemble sequence ? are welcome
Old 12-17-2022, 11:02 PM   #74
zicc1835
zicc1835's Avatar
gaps not bad lines are perfect
Old 12-27-2022, 12:43 PM   #75
cornerstone
cornerstone's Avatar
Glad I checked back in! You've come a long way bud! Your work is spectacular for sure. Is it me or is the forum nearly dead? I would have expected several guys respond to all the work you have accomplished.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
