![]() Join Date: Dec 1999
sm 465
looking for factory chrome sm 465 shifter . thank you in advance Jay
Jay Snyder Leechburg, PA (Northeast of Pittsburgh) 72 Chevy Cheyenne 4x4 camper special #matching '71 Chevy Dually 4x4 '69 Chevy Pro Street swb. '72 Chevy camper special 4x4 402 v8 (not factory) just cool. (truck puller) 70 Chevy swb 400 v8 400 turbo 72 Chevy suburban 4x4, 396 4spd. 68 Chevy shortbed 50th Anv. 327. 72 Chevy 2 wd. Blazer 69 Chevy swb 4x4 327 4spd. 58 Chevy Apache 4x4 swb. 71 Chevy CREW CAB swb 4x4 396 4spd. (just finished) WE BUY AND SALE TRUCKS AND PARTS |
![]() Join Date: Dec 2009
Re: sm 465
Here's a link to the last sm465 stuff sold.
It's not chrome. He may still have it? 2 Year old link : https://67-72chevytrucks.com/vboard/...=sm465+shifter
Re: sm 465
thank you but I am looking for a chrome one to add to a 68 50th anniversary swb truck that I am doing thanks Jay
#4 | |
The Older Generation
Re: sm 465
To the best of my knowledge there were no factory chrome ones. In my 20 years of buying, selling, and building these trucks I have never seen one. LockDoc
![]() Join Date: Feb 2009
Re: sm 465
I may be wrong, but didn’t Cheyenne supers and CST blazers with manual transmission get chrome shifters?
#6 | |
Re: sm 465
LockDoc
![]() Join Date: Nov 2018
Re: sm 465
Re: sm 465
Every Super and CST Blazer has had at a minimum the transfer case lever chrome
![]() Join Date: Jul 2001
Re: sm 465
I had a '71 CST Blazer with a 350/np205 and sm465 combo as my first 4WD. It had the chrome 4 speed shifter and transfer lever in it and to the best of my knowledge it was totally stock, no signs of being tampered with. This was in early 81 or 82. With my normal 20/20 hindsight I should have never sold it.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Re: sm 465
I have a 68 CST, SM465 that's stock. The shifter is painted black. I've never heard of chrome ones being available for the 68's in any trim level.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
![]() Join Date: Aug 2015
Re: sm 465
ive got a pretty much original 1972 C10, sm465, and ive got a spare sm465, neither are chrome, couldnt you just have a stock shifter chromed
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
![]() Join Date: Feb 2002
Re: sm 465
My '71 GMC Jimmy K/1500 w/ Custom trim level, has a chrome shift lever on its SM465. Pretty sure it's Factory. St Louis-built truck. NP205 Xfer case shift stick is chrome, too.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 11-13-2022 at 08:40 PM. |
Re: sm 465
My ‘72 Jimmy custom has factory chrome shift stalk. I have not seen a 2x4 SM465 with a chrome stick in a 67–72 but haven’t messed with but one. It was a ‘70 Sierra Grande but it had a black stalk.
Based on the difference in shape 2x4 vs 4x4 you could probably use a square body chrome SM465 shifter. Or have an original chromed.
Re: sm 465
Fill me in here, but I thought the 67-69 had SM420s?¿?
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() Last edited by prg machine; 11-13-2022 at 11:28 PM. |
#15 |
Re: sm 465
Cut and paste:
When did the SM465 come out? Image result for sm465 history The SM465 was made by General Motors from 1968 to 1991. They are found primarily in GM and Chevrolet trucks, Blazers, Suburbans and many other models falling under the 1/4-ton to 1-1/2-ton platforms. |
#16 | |
Re: sm 465
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
#17 |
Re: sm 465
I have had over 300 of these trucks since I started playing with them when I graduated high school and I would only guess maybe (6) 4 spd. shifters and only (10) 4x4 shifters that were chrome. I am just looking to add one to a 68 2wd to add a little more cool to a build I am hoping to have ready for spring. Thanks for the info every little bit helps. thanks Jay
#18 | |
Re: sm 465
I did this for an older Jeep project that I did about 25 years ago. The plating is still flawless. The key factor is the polishing before it gets plated. I did my own just because, but they will provide that surface finish polishing for you. Think of a paint job, the surface you paint is what you see in the final results. A piece like a Shift Rod shouldn't be that expensive. Just for consideration.
#19 |
Re: sm 465
1967 was the last Model Year for the SM420. M.Y. 1968 introduced the SM465. The first K/5s were Chevy Blazers in M.Y. 1969. GMC followed in M.Y 1970 with the Jimmy K/1500. Custom trim level Jimmys [w/ MT] got chrome shift sticks. [Maybe Blazers, too. IDK?]
I have heard some GMC and Canadian-built trucks were equipped with SM420s thru M.Y. 1969. No Jimmys were built anywhere else but St Louis until M.Y. 1972, when the Flint Mich. plant joined in. I doubt any K/5 - K/1500 [Blazer/Jimmy] utility trucks ever came with SM420s from Factory. ![]() ![]()
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 11-16-2022 at 07:15 PM. |
#20 | |
Re: sm 465
The owner I purchased it from said he had changed the Transmission and Transfercase because the original had the older Divorced, drop down type output, Spicer I believe. It even still has the Crossmember for that Divorced location T Case mounted in it's original location. The truck, when I first got it, had some ungodly low gearing 5:56 or something Ring and Pinion with heavy deep mesh gear teeth. I changed to 4:10s I would imagine those real low gears were meant for pulling some heavy loads. I was told they were popular with the Tractor Pull truck builders. Axles I'm referring to are the Eaton rear and Dana 44 front
#21 |
![]() Join Date: Feb 2000
Re: sm 465
Waking this thread up regarding chrome SM465 shift levers;
In my '71/72 parts catalog there are multiple part numbers listed for the shift levers denoting which came with Custom Sport Truck (C.S.) packages. Example: 71-72 K-1,2,Blazer (K) C.S. w/4-spd......3963035 71-72 C-1,2,3 w/Muncie (6 cyl.) (exc. C.S.), K-1,2 w/Muncie (exc. C.S.)......3899919 while there aren't pictures or other notes like 'chrome' or 'bright appearance' it seems that trucks equipped as CST's got chrome levers or P/N 3963035. Anyone got a bone stock, original Z84 equipped truck with chrome levers? The same is noted for transfer case levers which I've seen some stamped with these numbers; 71-72 All, Blazer (exc. C.S.)....3991931 71 Blazer (w/C.S.)....3983533 The bright transfer case lever is specifically called out in the 71/72 Blazer Vehicle Info Kit,https://www.gm.com/content/dam/compa...let-Blazer.pdf, as part of the CST package on K10 models. I wonder if the chrome 4-speed lever got lumped in with the 'bright control knob and pedal trim' since it wasn't specific to 'K' models.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
#22 |
All about them K’s
![]() Join Date: Jun 2014
Re: sm 465
Chrome 4 speed shifters were absolutely part of the Cheyenne and super packages… my 72 K20 Cheyenne. 100% original shifters 100% factory chrome.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() Last edited by 57taskforce; 06-06-2023 at 07:40 PM. |
#23 |
![]() Join Date: Feb 2016
Re: sm 465
I recently snagged a chrome shift lever out of a a square body truck with an SM465 transmission from my local junkyard.
It looks like it's going to work in my '68 K20 that I'm restoring. I know it has a different bend to it but I think it will clear my seat and T-case lever just fine. Just wondering if anyone else has tried a lever from a square body in their 67-72 trucks?
1966 Custom Camper -327, 3OTT 1968 Chevrolet K20 - 307, 4 speed 1972 K10 SWB - 400, 3OTT 2003 Corvette Z06 - LS6 350, 405HP 2004 Tahoe LT 2015 Silverado 2500HD - 6.0L V8 |
#24 |
All about them K’s
Re: sm 465
My K10 has a square body 465/205 and associated shifters. The 465 shifter will barely hit the seat in reverse but it’s not a huge deal.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#25 |
Re: sm 465
Thanks, good to hear.
