![]() Join Date: Oct 2020
What is this wire?
I installed what is a exact replacement for the OEM wiring harness. It is excellent in every respect, but there is this black wire that wasn't on the original harness. Granted, the original harness was extremely hacked up.
Here are a couple photos of the mystery wire in question. I do not know where it goes, but it is long so I assume it goes to the passenger side. |
Re: What is this wire?
Looks like a fuse holder connection. My aftermarket ac has one inline to the blower motor
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
![]() Join Date: Mar 2003
Is there 12v there either batt or ign? Looks like a bullet plug-maybe for the cig lighter?
Being a black wire I am guessing this is a ground of some sort that connects to a post maybe? I do have an orange wire that goes through the firewall for the blower motor.
#5 | |
I am just real stumped as to what this wire connects to. The only thing I do not yet have installed is the radio...radio ground? I appreciate the responses. |
The Older Generation
Grasping at straws here. Do you have this ground wire? It is the ground for the cluster. You could use a Multi-Meter (OHMS) and see if your wire connects to that space on the cluster connector. LockDoc
![]() Join Date: Apr 2016
That connector is interesting. I would like to hear the end of the story. Specifically where does the other end of that wire go. Trace it through the wiring harness by looking what direction it goes into the bundle and you can probably gently tug on the wire to see or feel what wiggles on the other end of a wrapped run, and check out the color of the wires on the various connectors. Use an ohm meter if necessary.
You may be able to contact the manufacturer or vendor of the wire harness and find out from them. |
![]() Join Date: Nov 2010
Does the other end go to the fuse box? Is this an m&h under dash harness?
Some progress is better then no progress |
![]() Join Date: Nov 2018
Just curious...Your new harness kit did not come with a fuse block/wiring diagram? I've installed at least a half dozen of those over the years and they all had diagram/instruction sheets provided. Then it got even easier on the last one I did on my 40, each wire was printed about every 18" or so with what it went to.
Looks like 1/2 of a fuse holder. Related to the amp meter possibly?
#11 | |
I guess I will chase that wire down using my multimeter. Thanks again guys! |
Mystery solved, the wire in question is from the under dash air conditioners wire to the binary switch (back in the day it went direct to the compressor.
I just had to unravel the harness tape to follow it. Thanks to all that offered their thoughts and guesses. |
