Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 03-23-2011, 04:54 PM   #1
way2lo2
way2lo2
way2lo2's Avatar
1960-1972 Lowering Block U bolts
I have been reading countless posts concerning people not being able to get longer u bolts (at a reasonable price) when installing lowering blocks for the 60-72 Rear truck arm suspensions. Yes, we all know , if you can find a big truck spring shop, you can get a set made, as long as you know the size, length width etc. We've been stocking these so I figured I'd offer them to members. You get the longer U-bolts to accommodate a 1"-2" block with washers and nuts for $14.95 each. These will fit in a USPS flat rate envelope anywhere in the US for $5.00 shipping. I also have solid blocks in 1" 1.5" and 2" sizes.
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Way2Lo2@aol.com <----also my paypal
http://www.hubgarage.com/mygarage/way2Lo2
way2lo2 is offline   Reply With Quote
Old 03-29-2011, 01:41 PM   #2
charx2
charx2's Avatar
Re: 1960-1972 Lowering Block U bolts
No 3" blocks huh?
My 67 c10 Thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=409192
charx2 is offline   Reply With Quote
Old 03-29-2011, 02:56 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Thanks for offering up the U-bolts.
Like you said,... we get many members wanting them.
I'll send them your way, from now on.
Keith
Convert to disc brakes.
Old 03-30-2011, 08:37 AM   #4
way2lo2
way2lo2
way2lo2's Avatar
Originally Posted by charx2 View Post
No 3" blocks huh?
I can't say I've ever seen a 3" block in a truck arm application. I guess if there is enough call for it, I will start making them.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 03-31-2011, 09:28 PM   #5
72MARIO
72MARIO's Avatar
3" block could run into posible scrub line problems ? Read somewhere 1.5 is the max with a 15" wheel
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-01-2011, 01:39 PM   #6
SCOTI
SCOTI's Avatar
Definite scrub line issues unless running big diameter wheels. A 1.5" block on 15's is the safe limit. They're close, but as long as you don't sling the rubber off the rim & the u-bolts don't extend beyond nuts, you'll be ok.
That being said, I've seen more than one guy use 3" blocks w/o problems. It just seems to be an un-worthy risk.
Boris, what are you getting for the blocks?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-01-2011, 02:51 PM   #7
way2lo2
way2lo2
way2lo2's Avatar
Retail on them is $24pr for the 1" $32pr 1.5"
2" are $38pr. I will probably run a April special for U bolts, blocks, and hardware.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-06-2011, 01:23 AM   #8
nrgtruck
I am looking to lowering my 72' C10 with 2" lowering blocks; Lowering block u-bolts, adjustable panhard bar and a pair of shock relocators.
I already have 3 inch lowered springs. I don't want to c-notch.
Please let me know when you are offering the packaged deal.
Thanks,
Frank
juiced66chevelle@aol.com
nrgtruck is offline   Reply With Quote
Old 04-06-2011, 04:13 PM   #9
djquik88
djquik88's Avatar
Hey Boris, don't forget to send me those blocks when you get them in stock.
Mike
djquik88 is offline   Reply With Quote
Old 04-06-2011, 04:52 PM   #10
way2lo2
way2lo2
way2lo2's Avatar
went out today, thanks again Mike
Boris
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-06-2011, 05:04 PM   #11
djquik88
djquik88's Avatar
Awesome!
Old 04-20-2011, 08:56 AM   #12
Custom 68
Custom 68's Avatar
I saw you might be running an april special. Could you PM me a price on the setup for 1.5 inch blocks and the appropriate u-bolts, nuts and washers.
David
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-29-2011, 11:29 PM   #13
big_al_71
big_al_71's Avatar
David
The same thing for me as well..
thanks Al
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 05-03-2011, 12:51 PM   #14
gcburdic
Restoration Virgin!
gcburdic's Avatar
boris....can you make standard length u-bolts for a 71 rear end?? If so, how much for a pair shipped to 27596 with all washers and bolts....Thanks
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-04-2011, 10:55 AM   #15
way2lo2
way2lo2
way2lo2's Avatar
Yes, stock length U bolts are also in stock $14.95 each.
Geoff, yours were shipped to Jesse today.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 05-04-2011, 08:53 PM   #16
gcburdic
Restoration Virgin!
gcburdic's Avatar
thanks so much Boris!
Geoff with a G
Old 05-07-2011, 06:47 PM   #17
gcburdic
Restoration Virgin!
gcburdic's Avatar
Thanks again for the quick shipping Boris....Jesse got'em Friday
Geoff with a G
Old 06-08-2011, 10:47 PM   #18
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Im looking for a 1" or 1.5" drop block for a 68 c10 pickup with coil springs...
Do you have any blocks, or just U bolts? Thanks, and great prices!!
John
1999 Toyota Tacoma 4x4
Old 06-09-2011, 07:53 AM   #19
way2lo2
way2lo2
way2lo2's Avatar
Yes, we have those blocks. PM sent
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 06-19-2011, 07:07 AM   #20
tazattitude
tazattitude's Avatar
I need a set of 2" block U-Bolts (only the bolts, not the blocks. I stripped an end on mine).
Can you send me payment info? I can pay by Paypal.
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
Old 06-19-2011, 08:05 AM   #21
way2lo2
way2lo2
way2lo2's Avatar
Pm sent
Old 06-19-2011, 10:58 AM   #22
tazattitude
Paypal'd the money.
TAZ
BUILDS
1966 GMC Suburban
Monthly Updates
Pics / Video
Old 06-20-2011, 11:11 PM   #23
jmlcolorado
And im in line for a set of 1 1/2" bolts. PAypay accepted?
jmlcolorado is offline   Reply With Quote
Old 06-21-2011, 05:23 AM   #24
way2lo2
way2lo2
way2lo2's Avatar
pm sent
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 08-15-2011, 04:54 PM   #25
First66
First66's Avatar
How much for 2" blocks, and the U-Bolts combo?
Thanks.
1966 Step C10
First66 is offline   Reply With Quote
