Old 02-06-2012, 02:07 PM   #1
62 Barnfind
62 Barnfind's Avatar
1962 chevy c10 update.
Just finished blasting and painting the rear frame. I used rustoleum rusty metal primer and semi gloss black. I think it came out good. I do recommend this product for cost cutting. The quarts cost $8.00 each and lay down smooth. The truck is coming together slowly. I also cut out the cab corners and finished putting the engine back together. I had three people stop when I was working on it out side. I also received a ticket for storing my bed in the driveway.
62 Barnfind is offline   Reply With Quote
Old 02-06-2012, 02:19 PM   #2
hopped up
hopped up's Avatar
Re: 1962 chevy c10 update.
lookin good. whyd you get a ticket for having the bed in your driveway? thats bs!!!
hopped up is offline   Reply With Quote
Old 02-06-2012, 07:18 PM   #3
62 Barnfind
I know, I live in a new sub division and there is construction everywhere so I didn't think it would matter. So I have to move it into the garage.
Old 02-06-2012, 11:55 PM   #4
Jeff La
That's just stupid for the ticket. Nice job
Jeff La is offline   Reply With Quote
Old 02-07-2012, 02:00 AM   #5
Captainfab
60-66 Nut
Your truck is looking good
Are you leaving it mostly stock?
I think that is BS getting a ticket for your bed being in the driveway. I am so glad I don't have to worry about things like that around here......not yet anyway.
Old 02-07-2012, 07:36 AM   #6
62 Barnfind
Yes I am planning on stock with little modifications. I will change the wheels and put either a 2 or 3 carb setup on it. I want to do something different than what everybody else does. I wanted to put a v8 and auto but everybody in my area has that. I want to do a 60s theme with a hot strait six. I saw an eposode of gears and he did a strait six with three carbs and it looked kick ass. Thanks for the comments. I moved my bed inside last night so I won't get into trouble.
Old 02-11-2012, 06:58 PM   #7
62 Barnfind
Replaced the right cab corner. The left one I messed up and need to get another. Does anybody know the best way to remove the front cab mount/ floor brace? Mine is rusted thru.
Old 02-25-2012, 08:08 PM   #8
62 Barnfind
Just replaced the right front cab mount. It took longer than expected. It had a bunch of spot welds. Plus it was harder to do upside down. I finally removed and replace it.
Old 02-26-2012, 04:23 PM   #9
McMurphy
McMurphy's Avatar
Wow your resto work looks great!
The motor looks like it is totally back from the dead, and your p-side cab corner looks awesome!
Are you doing all this solo, or do you have some help?
I am also guessing this is not your first project piece.....
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 02-26-2012, 08:51 PM   #10
62 Barnfind
I am doing all myself. I did a 66 when I was in high school (1988) that I found in a farmer's field. I have been a Army Mechanic for 22 yrs and I have been watching all the how to shows like Gears, Trucks, Muscle ca and Overhaulin. I have been wanting a project for a long time and came across this truck. Thanks for the shout out!
Old 02-26-2012, 09:56 PM   #11
McMurphy
McMurphy's Avatar
Congrats on your 22 years of service!!
I just rolled over 20 years active last August.
Keep us in pics on your build, this is the fun stuff !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 02-26-2012, 10:10 PM   #12
62 Barnfind
Same to you! August is when I hit 22.
Old 02-29-2012, 12:51 PM   #13
juanz1947
rusty 66
juanz1947's Avatar
Nice truck
1947 chevy fleetmaster
http://www.cbforum.net/forum/
1966 chevy c10 long bed
http://67-72chevytrucks.com/vboard/s...d.php?t=439219
1970 chevy impala custom
http://www.layitlow.com/forums/index...pic=349867&hl=
juanz1947 is offline   Reply With Quote
Old 02-29-2012, 05:50 PM   #14
DLOE65
DLOE65's Avatar
Lookin good! Nice body work on the cab corner!
DLOE65 is offline   Reply With Quote
Old 02-29-2012, 08:48 PM   #15
62 Barnfind
Thanks for the complements. I received the inner fender seals so I am going to replace the inner fenders. If I have time I am going to do the other cab corner. I do not want to get in a hurry because last time I did and I messed it up. I am looking for a good right front fender. I started sanding the front and noticed that it is rusty and dented bad in the front.
Old 03-09-2012, 09:01 PM   #16
62 Barnfind
Did more work today. I replaced the left rocker panel. It wasn't as bad as I thought. The hardest part was stretching the panel to get a good fit. I still have to grinding and fill the seam to make it look better. I also fitted my front fenders. For some reason they are not lining up right.
Old 03-10-2012, 10:58 AM   #17
j.kirn
Great work keep it up
j.kirn is offline   Reply With Quote
Old 03-14-2012, 03:05 PM   #18
C@rnut001
Your truck build is coming along great! Keep up the great work. Your engine is looking killer now.
C@rnut001 is offline   Reply With Quote
Old 03-14-2012, 08:42 PM   #19
62 Barnfind
Did more metal work today. Didn't get to finish because the lower part of the right door is rusted thru. So I have to order a patch to finish it.
Old 03-23-2012, 01:22 AM   #20
FetchMeAPepsi
FetchMeAPepsi's Avatar
Subscribed. It's coming along nicely
FetchMeAPepsi is offline   Reply With Quote
Old 03-26-2012, 01:01 PM   #21
Chad215
looks great- I'm going to have to replace at least the bottom of my door skin eventually- I'm very nervous even thinking about it - your work looks awesome.
'64 GMC in progress
http://67-72chevytrucks.com/vboard/s...d.php?t=484861
Chad215 is offline   Reply With Quote
Old 03-31-2012, 09:56 PM   #22
62 Barnfind
Replaced my left side door skin and lower door panel It came out ok but it's a bout 1/4 off. I still have to adjust it a little.
Old 04-01-2012, 04:05 AM   #23
markeb01
Senior Enthusiast
markeb01's Avatar
Very impressive progress, your truck is coming along nicely. In my youth I always wanted to build a 6 cylinder engine with a 4 barrel and headers, but it never worked out that way. Triple carbs have always provided a better wow factor though. I wish I had your sheet metal skills. Keep up the good work!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-01-2012, 10:56 AM   #24
62 Barnfind
Thanks,
One day I will having look as good as yours. I have been a mechanic in the Army for 22 yrs and just started to get into the body work. While I was in Germany I watched all the how to car shows and learned a little. I wish I were better.This was the first time I did a door skin. It came out ok but it is a 1/4 in off from the left door. How much does the door seal stick out from the sill plate on the bottom? The bottom door is knocked in a little because it was sticking way out. I need to do some more hammering and filling to get the door better. If I didn't have to replace the lower door I think it would have come out better. This is the hardest part of the build so far. Getting the doors right.
Old 04-01-2012, 11:15 AM   #25
j.kirn
Looking real good keep it up it will pay off in the end
