12-04-2021, 05:12 PM | #1 |
At the body shop.
Re: 2wd swap
Ordered 2 got a whole box.
Quick connects on the peterbilt should be ok on this bucket ?
" That didnt make it any newer " " Dont antique the equipment " |
12-04-2021, 06:32 PM | #2 |
Re: 2wd swap
As long as they're DOT fittings. Cheap/China fittings break easier & don't secure the line as well allowing them to pop off.@ inopportune times.
12-10-2021, 12:52 AM | #3 |
Re: 2wd swap
Seems like the "touch line" is the same all the way across. 4X6 pad of 1/2-5/8 steel welded to the bottom of the crossmember for the first hit?
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
12-12-2021, 09:31 PM | #4 |
At the body shop.
Re: 2wd swap
So we raised the upper arm up 2 inches this time.
Finally got the bumpsteer manageable. The camber change is pretty good til full droop which is beyond the shock travel.
12-12-2021, 10:04 PM | #5 |
Re: 2wd swap
Visually, that curve does look good. Extension shouldn't be that much of a concern w/the shock limitation.
12-12-2021, 10:14 PM | #6 |
At the body shop.
Re: 2wd swap
Now to build the upper bracket that looks nice.
Gonna tie it into the top flange. Glad the in-house welder is on his game.
12-12-2021, 10:33 PM | #7 |
Re: 2wd swap
How do things look on the driver side interference wise (column/steering linkage)?
12-12-2021, 10:58 PM | #8 |
At the body shop.
Re: 2wd swap
In the way.
But that is a given with a sectioned crossmember
12-13-2021, 12:20 AM | #9 |
Re: 2wd swap
True. But it depends on the amount notched. I did a small notche on the stock upper a-arm & it cleared the stock shaft. I feel that's about the limit before you have to go the multi-joint path.
12-13-2021, 12:53 AM | #10 |
At the body shop.
Re: 2wd swap
As soon as we raised the upper mount up it wasn't even a thought.
In the new drivers side upper bracket will be a spot for a heim. Probably a 3 joint deal
12-13-2021, 12:54 PM | #11 | |
Re: 2wd swap
Nice progress.
01-04-2022, 02:49 PM | #12 |
At the body shop.
Re: 2wd swap
Slow and low lately but progress
01-05-2022, 01:48 AM | #13 |
At the body shop.
Re: 2wd swap
Kid sends these tonight.
2" inch dom lowers sure..
01-05-2022, 09:20 AM | #14 |
Re: 2wd swap
Heavy D.
01-05-2022, 08:35 PM | #15 |
At the body shop.
Re: 2wd swap
So ride height is set.
3 inches from the deck. Lower links are gonna be yuge
01-11-2022, 02:23 PM | #16 |
At the body shop.
Re: 2wd swap
Stacks on stacks.
2nd pass of 3 to finish his lowers up
01-11-2022, 03:30 PM | #17 |
Re: 2wd swap
Very nice!
01-12-2022, 06:09 PM | #18 |
Moderator
Re: 2wd swap
Wow those links are some monsters. It all looks great.
01-13-2022, 05:49 PM | #19 |
At the body shop.
Re: 2wd swap
Thanks.
We just realized he has been welding for a year the 11th I can't make silicone look that nice.
01-13-2022, 05:53 PM | #20 |
Re: 2wd swap
All the more impressive!
01-15-2022, 10:55 PM | #21 |
At the body shop.
Re: 2wd swap
Lower link mock up.
Also some of his production work for his uncle. Has a 125 pieces to do this round.
01-24-2022, 07:10 PM | #22 |
At the body shop.
Re: 2wd swap
Love when new parts require more new parts.
Our camaro calipers won't clear our American racing wheels. Rocket racing says theirs do. Any one have experience with them. I notice it's a holley brand now. At $550+ I'd like some 1st hand experience
01-24-2022, 10:21 PM | #23 | |
Re: 2wd swap
The Rockets do offer greater caliper clearance but I've seen guys run spacers on them as well. What exact calipers/rotor combo? That's the bad thing about the 'big brake' set-ups from late model cars (or aftermarkets sources) they're mainly designed w/a bunch of pad offset required to clear fat/long calipers. Old school wheels don't have the same wheel center/barrel shape which helps.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-24-2022 at 10:27 PM. |
01-24-2022, 11:15 PM | #24 |
At the body shop.
Re: 2wd swap
American racing Rodder
10 spoke 20x9.5 and x8 With a ss camaro brembo caliper. Would need at least a 3/4" spacer. Of 2 wheel companies I emailed only rocket responded. Said their attack wheel has 1.9 inches of caliper room. The other option is baller stuff. 5k+ in wheels or 5k brakes isn't in this blazer project.
01-25-2022, 09:14 AM | #25 | |
Re: 2wd swap
2018 Z51 Vette rotor I'll ask for 100% verification but don't believe he's running a spacer:
