67 is sold
Rear Fuel Tank swap
I will be ordering a rear ruel tank/cell setup for my '67 SWB 2wd truck very soon.
I've been looking at the tank offered by Fuelcellguy as well as the kit through ECE (seems a bit pricey to me). Another option is a stock GM repro blazer tank. I'm looking for real world replies. What do you guys honestly recommend and why? What would you do if you had to do yours over again? Consider I am going with a 6" drop or bags in the rear end. Thanks ![]() |
Almost done!
Pick the one with the largest fill neck size. Otherwise, you spend a lot of time trying to fill up the tank. The 1 1/4 ID necks are too small. Next time I will cut the old one out and weld in a larger size. Kinda hard to weld once you put fuel in it. Even so, I would do the conversion again. I got a tank from Kenny's Truck in Tulsa OK. About $225 for the complete kit. I installed the marker light fuel filler and love it too. Good luck with the conversion.
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
I like my Blazer tank but it hangs pretty low.
i just used a poly fuel cell (you can get htem from summit for pretty cheap)
68 short step, 406/700r4, 9" w/discs. |
67 is sold
Thanks for the replies, good points.
Nate68 - any chance I could get a pic or two of your install? Did you have to fab your own fill neck? Do you fill in the bed floor or elsewhere? |
here's an old pic from before the bed was on.
67 is sold
Anybody else have info to share?
I have not done this yet, but I know that the Truck Shop has the complete setup for $166 and it includes all of the straps, sening unit, nuts and bolts....This is the best price that i have seen so far....I am just waiting for the pennies before upgrade....
#9 | |
In my catalog it says that the straps and sending unit are sold separate. So that would be another $75 on top of the $165.
1971 LWB Chevy C-10 350/350 3:42 eaton ![]() |
I have a FCG tank. I just fired my TPI up tonight, and so far the tank works great. It installed easy, and mine has an in-tank pump. It also has a 2" filler.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Got Light Emitting Diode?
71swb4x4 i think you can take the working on TPI off of your signature now
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Young Gun wth Fast Inline
Has anyone put a later style blazer tank in there 67-72 truck... Will it fit, it looks like it will fit in the frame... what are the dimensions of the 69-72 blazer tank, anyone know. Thanks
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
Merciless Butcher
I used one from FCG. It was awesome. He included the mounting straps and builds it to your specs: location of filler etc.... I will use his tanks on any future projects. My ex-brother in law once used a plastic fuel cell from Summit. It was really flimsy and really didn't fit all that well. I just didn't like the idea of that flimsy plastic cell under my bed. That was the major reason I went with FCG.
Your Bought And Sold....I Got Your Soul! |
67 is sold
Yeah, so far the FCG setup looks like just what I want.
I appreciate the feedback guys ![]() |
#15 |
i was really thinking about a fuel cell. but i didn't want a gas tank under the bed. so at the risk of being completely origional, i'm installing a diamond plate combo tool box/tank. it is pretty normal for people with 5th wheels to have an aux tank like this. but i really like having the combination and having a 50 gallon capacity. looks attractive, holds alot, strong as hell, easy to get to (no fabbing fuel doors) check out www.transferflow.com just for kicks.
just my $.02
RN U OVR |
#16 |
67 is sold
Cool.
I have been thinking about the tank swap since I first read about the blazer tank swap a year or so ago here. I like having the tank under the bed, primarily to get it out of the way. I was never happy driving around with a 'bomb' behind my seat ![]() |
#17 |
transfer flow is based out of chico. i should see how much they would want to build me tank
#18 |
TOTY 2006
![]() Join Date: Dec 1999
"I was never happy driving around with a 'bomb' behind my seat "
I was just wondering why people say this? I have not heard or seen of any of the old trucks (of which most of them have tanks in cab) blow up or catch fire because of the in-cab tank.... Not trying to be an a$$, just wondering why those that do this swap are really doing it for? (I would expect most do it just because) |
#19 |
Im wanting it for some weight transfer and bucket seats. Otherwise i wouldnt bother.
#20 | |
67 is sold
Personally, I'm doing it to clean up the side of the cab and remove the filler top and gain even a little seating room inside the cab. The room under the bed is wasted space, so I might as well take advantage of it ![]() ![]() |
#21 |
for me: a nominal gain in traction and so i can put stuff behind the seat. i have no other place to store things (and dont say the bed because that isn't functional
#22 |
Insert funny comment.
I have the ECC FI version.. not cheap but its a very nice product.
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com Last edited by lock; 09-04-2004 at 12:25 AM. |
#23 |
Nate68, Where from around Chico are you?
I lived in Colusa for awhile...Where you from?
70 CHEVY STEPSIDE |
#24 |
My only problem with installing a fuel cell between the frame rails is... Where the heck do we store the spare tire so it's not in the way and messing up a otherwise neat an clean looking truck?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
#25 | |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 09-04-2004 at 11:23 AM. |
