03-12-2020, 10:24 PM | #226 |
Re: Eaton HO72/HO52 vs. 14 Bolt FF
Will the G80 locker from a 14 bolt fit in the eaton carrier? They are both 2 piece carriers, just not sure what is on the internals of both of them
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
03-12-2020, 10:58 PM | #227 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
No...The 14-bolt G80 carrier is a unit unto itself. In other words, you cant put a True Trac or Detroit locker in a 14-bolt with the G80 carrier because it uses a 3 pin design instead of a 4 pin like the standard open carrier...I don't know what the specs are for the HO72 carrier but I doubt the 10.5 ff 14-bolt carrier would swap as a whole unit.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
03-13-2020, 12:50 AM | #228 |
Heres some good info... http://67-72chevytrucks.com/vboard/s...=536119&page=2 Rather than swapping a G80, why not look for a 14-bolt that has the Detroit Locker in it and just use the locker unit. I believe the Detroit Locker was the only traction device used in the Eaton HO72 & HO52...
03-13-2020, 09:45 PM | #229 |
60-66 Nut
I have seen several of the Eaton HO52/72's with Detroit Lockers in them. My '66 C20 has one. You might be able to find one from an Eaton.
03-14-2020, 10:23 AM | #230 |
It should be mentioned that if you want to put a 14 bolt FF rear in the 72' & older leaf spring truck with out modifying spring perches,it has to be from a one ton.3/4 ton perches are in the wrong location
09-23-2020, 06:10 PM | #231 |
Here is a YouTube video comparing the HO52 / HO72 carriers of a 4.10 and 5.14 ring gear:
https://www.youtube.com/watch?v=Ol5f...ature=youtu.be Looks like GM used the same carrier and just thinned out the ring gear. Here is some discussion of the ring gears: https://www.youtube.com/watch?v=QCXq...ature=youtu.be
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
11-26-2020, 09:06 PM | #232 |
11-26-2020, 09:22 PM | #233 | |
I would be interested in seeing pictures. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
11-26-2020, 09:23 PM | #234 |
I also would be interested please. I have the EATON in my 72 k2500. I am looking to upgrade it where I can, if I can. Thank you.
12-02-2020, 04:43 PM | #235 | |
https://johngobby.smugmug.com/My-Fir...DL/i-5nsdCLN/A https://johngobby.smugmug.com/My-Fir...DL/i-SmGK2gr/A https://johngobby.smugmug.com/My-Fir...DL/i-9JvSC7V/A https://johngobby.smugmug.com/My-Fir...DL/i-DjxhJh5/A Hope you can see the HO72 stamped in crown gear as well 39 x 10 gears the CO stamp I suspect it refers to a corporate designation . Also hope the pictures turn out , I had to wait for my 7 year old grandson to drop by to help me post the pictures . JOHN Last edited by panel fan; 12-02-2020 at 08:14 PM. |
12-02-2020, 08:14 PM | #236 | |
12-02-2020, 08:25 PM | #237 |
12-02-2020, 08:26 PM | #238 |
12-02-2020, 08:27 PM | #239 |
You have a Very Rare part
12-02-2020, 08:35 PM | #240 |
I suspect the reason for the shortage of 3.90 's was lack of demand as at 60 mph
on 30 in tires there's only a little over 100 rpm difference , hardly worth the effort . John |
12-02-2020, 10:25 PM | #241 |
DND Trucks
John,
Just curious here, is there a GM part number on the ring gear and the nose of of the pinion gear that you can take a pic of? Lmk thx |
12-03-2020, 09:47 AM | #242 |
12-03-2020, 09:49 AM | #243 |
12-05-2020, 12:52 PM | #244 | |
DND Trucks
Or it could be a GM Canada thing, whereby there were definitely differences in production and equipment. Having a GM part numbers would clear up any confusion on being original or aftermarket. Thanks |
06-27-2021, 02:50 PM | #245 |
I'm confused.
I have a SRW H072 in my C3500, So do I just get the backing plates from a 14bolt ff and the drums, then take my hub/drum, separate them, put the new drum and my old Eaton Hub together, swap out backing plates and brake parts, and re assemble? I am confused if I reuse my Eaton hubs, or if I have to do some kind of magic to make the 14 bolt hubs fit my Eaton spindle...... |
06-28-2021, 05:47 PM | #246 |
From my understanding you are good to go on the SRW axle. I am geared up to try the swap myself in the near future. My donor axle has slip on drums though. Fingers crossed and good luck.
On a side note. Alot of dual rear trucks came from the factory as SRW and are dealer converted to duals. There is an actual RPO code for it. I have one of these trucks in my yard right now but the SPID is missing. |
07-20-2021, 12:59 PM | #247 | |
I have the backing plates, just need to get the drums, shoes, hardware kit, and lug studs. In my research I swore I read in a thread on this subject that 14 Bolt hubs were required, and that with some creative interchanging of inner bearings and races, that the 14 bolt hubs would work. I then re-read this thread exclusively, as I cannot find the other threads I previously found on the subject, and discovered 14 bolt hubs only work with some machining to accept the Eaton inner bearing race. I did buy some 14 bolt hubs, but will most likely use the Eaton hubs for my swap to 14 bolt brakes. Any information you guys can provide on the subject that I am missing will be much appreciated. |
07-21-2021, 08:14 PM | #248 |
I bored a set of hubs out with a good drill. The metal was actually pretty soft. Then I installed the larger lugs. It was all pretty easy. I haven't run them yet. That will be part of my upcoming swap. I want to set up a rear to be able to run duals but be switchable back to SRW eventually. I need a K30 for a few months.
07-22-2021, 07:23 PM | #249 |
That sounds easy enough. Did you use a drill press? I don't have one, but may be able to use someone else's. I'd hate to have lug studs all crooked
This is all going in the '65 C20 in my avatar. I discovered in my parts truck's HO52, that it housed a 4.11 3rd member. I went to move the sometimes daily driven truck the other day to remove the radiator for it to be cleaned and sealed, when my clutch decided to act up. I have been wanting to swap in my SM420 and Ranger OD, but have been enjoying the current setup in the truck. Well, if I have to remove the transmission to work on the clutch, a trans swap is in order, along with an upgrade to the HO52. I swapped in front disc in November 2015, so the braking is much improved, but now for a few more upgrades, and more modern 13 inch brakes will be a nice addition. Last edited by DOUBLE-DINGO; 07-22-2021 at 07:31 PM. |
07-22-2021, 08:32 PM | #250 |
I used my cordless drill after my good drill finally died. I did chuck them in a vice though. It went quick and they came out straight. I mounted the rims with no problem. I did this with a DRW rear but I am going to decide which axle to put under the K20.
Thread Tools | |
Display Modes | |
