11-20-2021, 06:00 PM | #26 |
Moderator
Re: Problems running at operating temperature
Sounds like spark knock otherwise known as detonation. It could be extreme piston slap but let's think good thoughts.
Check your base timing to be sure it's proper. The steps to do this are in the service manuals. Carbon buildup on the piston crowns and head chambers will increase the compression ratio. The old fashioned remedy was an Italian tuneup. If you've never heard the phrase "Italian tune up" before, basically, it means driving your rig hard and bringing it to near the redline for a several mile stretch on the highway with the goal of knocking loose carbon deposits. The other option is water but you want to be extremely excessively careful to not hydrolock the engine. http://youtu.be/KFtp_jmLF3k Assuming the base timing is spot on another thing to try would be bumping up the octane one tier to 89 on your next fillup. If you have a half to a full tank you might try a bottle of octane booster. I wouldn't use octane in a bottle as a regular thing but for this kind of condition it may let you use up the lower octane fuel without an excessive amount of spark knock. I've forgotten whether Texas allows the sale of 86 octane fuel. Last time I was in Dallas was in 2010. If you have 86 octane in the tank that is most assuredly your problem. Just say no to 86 octane in your post 1960 GM V8. Old crappy fuel has lost some octane too.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 11-20-2021 at 06:09 PM. |
11-28-2021, 03:20 PM | #27 |
Glad to hear that it runs now. Hopefully you can sort out the pinging too.
11-28-2021, 03:27 PM | #28 |
The EGR valve is good. It holds vacuum and the engine stumbles when I push up on the diaphragm. The coil and ignition module is new as of a couple months ago. Since code 43 is related to knock sensor I may as well replace the knock sensor.
1988 C1500 Regular Cab, Long Bed, 2WD. |
Thread Tools | |
Display Modes | |
