11-19-2013, 05:49 AM | #76 |
Re: Trouble codes
Roger that Shawn, the thing is, there is only one grounding wire in the entire Speartech harness. So if grounds were a problem, you would affect both sides, and not just one. Is there anything mechanical that could cause this problem?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-19-2013, 02:07 PM | #77 |
Re: Trouble codes
Random thoughts, but I'm no mechanic….
Put a stethoscope on each injector to see if they're firing correctly. Pull each plug and ground it and then watch it spark. How do the plugs look? Fuel rail clogged? Bad pressure regulator on the rail? Intake manifold leak? It's been my experience that one bad injector will make your trims on that side look bad…but not misfire multiple cylinders. Good luck with what is probably very frustrating! Wil also, have you run an ohmmeter on your harness to confirm wiring?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 Last edited by OldCreek; 11-19-2013 at 02:23 PM. |
11-19-2013, 02:40 PM | #78 | |
Re: Trouble codes
11-19-2013, 10:05 PM | #79 |
Re: Trouble codes
Check the harness first....Make sure all Injector drivers on that bank are wired to the correct cylinder.
Make sure all Ignition coil drivers are wired to the correct cylinder. Load test the Coil grounds, I use a Halogen sealed beam headlamp, Then check ALL ECM grounds.....Not many with a E38. Load testing is the ONLY way to truly check a ground. If you need help on test procedures, Let me know. |
11-19-2013, 10:14 PM | #80 | |
Re: Trouble codes
11-20-2013, 12:44 AM | #81 |
Re: Trouble codes
11-20-2013, 11:31 AM | #82 | |
Re: Trouble codes
Rob
11-21-2013, 11:01 AM | #83 | |
Re: Trouble codes
Last night I did a compression check on all 8 cylinders just trying to eliminate any possible mechanical problems. All cylinders were 215+ psi. Friday I will do a smoke test to make sure I don't have any vacuum leaks. If that checks well, I'll start digging into the wiring....
11-21-2013, 02:27 PM | #84 |
meowMEOWmeowMEOW
Re: Trouble codes
Did you ever take care of that metal-nub that you showed me the Manual pictures of?
11-21-2013, 03:21 PM | #85 |
Re: Trouble codes
Not yet. I'm going to do a smoke check to see if I have a vacuum leak first.
11-21-2013, 08:20 PM | #86 | |
Re: Trouble codes
Load testing is very straight forward. I use a headlamp because you can SEE if the ground is poor, If the lamp is bright, the ground is good. If the lamp is yellow/brown or doesn't come on....the ground is poor. Test it straight to the battery first to get a feel on how bright & color the light is. The diagram should help, Hook one side of the Lamp to the positive side of the battery. With a suitable probe & lead hooked to the other side of the Lamp......Probe the ground circuit your testing, This will load that circuit. What I mean by "Suitable Probe" is Don't stretch out the terminal in the connector your probing. Or damage the plastic connector. |
11-22-2013, 07:58 AM | #87 | |
Re: Trouble codes
11-22-2013, 10:37 AM | #88 |
Re: Trouble codes
CB thank you for posting the "load test".... i will file this away for future use. as will others i am sure.
11-26-2013, 09:57 AM | #89 |
Re: Trouble codes
Quick update guys. I messed around with the truck all weekend, with very little luck. Did a compression check, all cylinders 220 psi +/- 5. Did a smoke check, could not find any vacuum leaks. Stonewalled. Totally scratching my head.... I had set up an appt to get the exhaust put back on yesterday. I almost cancelled it since the truck would hardly run, but since I had taken the day off, I went ahead and called a rollback and had it hauled to the exhaust shop. I had planned on putting on some new Magnaflows that I had laying around, but they wouldn't fit, . I had wanted to switch the Magnaflows because I had read that they sound better with the LS motors, oh well....And with the new crossmember I built for the 6L80 tranny, my electric cutouts weren't working out so well either, . So I just told the exhaust guy to reconnect the Flowmasters that were on there (50 series) and at least I could do some tuning without getting fumigated. OK, so we get everything hooked up and I start the truck up just to see how it sounds....and to my surprise, I like it! And to my even bigger suprise, I hook the HPTuners scanner up and all the issues I was having with misfires and crazy Fuel Trims were gone!!!! Other than running a little rich, the idle is good and it's not throwing any codes. So the Moral of the story is, NEVER do any tuning on a FI motor unless you have the exhaust on and don't believe everything you read on the internet, . I'm eating some serious humble pie, I would never have thought that not having the exhaust on would have created the "symptoms" that I was seeing going on with my motor. Go figure. I did learn a lot through this experience, and will be a better "tuner" because of it. Now I have to undue some things I did when I was chasing a problem that wasn't there, .
11-26-2013, 12:46 PM | #90 |
Truck and auto performance nut
Re: Trouble codes
Interesting. I don't think I realized you were tuning running open headers? So lets see the exhaust!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
11-26-2013, 01:13 PM | #91 |
Re: Trouble codes
Well I technically I wasn't trying to tune it. I was just trying to get it running well enough to load onto a trailer to take it to the exhaust shop. Big mistake. Won't happen again. The exhaust is nothing special. I cut the orginal exhaust in from of the mufflers, so all he had to do is go from the headers to the mufflers. I'll try to post some pictures this evening.
11-26-2013, 03:36 PM | #92 |
Location: Sunny, Florida, some might call it South Alabama
Re: Trouble codes
What cut out where you using? And why didn't you like them?
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
11-26-2013, 03:55 PM | #93 |
Re: Trouble codes
I have QTP cutouts and really like them. I had them installed prior to doing the LS install. My new tranny crossmember is in the way. We could have made them work, but I just wanted to get the exhaust on so I could get it running. After I get everything lined out, I'll probably have him redo everything.
11-26-2013, 06:32 PM | #94 |
Re: Trouble codes
yea I didn't realize you didn't have full exhaust either. I am guessing you were getting some air back in and causing the o2 sensors to freak out so to speak. Glad it is coming together much better now.
good luck Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
11-27-2013, 12:10 AM | #95 |
Re: Trouble codes
YES, thank You, I will file that right next to using a flasher for checking shorts to ground
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
11-27-2013, 11:24 AM | #96 |
Re: Trouble codes
Haven't heard this one. Please explain. TIA.
11-27-2013, 11:56 AM | #97 |
Re: Trouble codes
When looking for a short that keeps blowing a new fuse, temp. wire a flasher can to the fuse posts, when it stops "clicking" and you have isolated the short, you have a good circuit, now replace the fuse
11-27-2013, 12:52 PM | #98 |
Re: Trouble codes
Sweet!
12-08-2013, 11:55 PM | #99 |
Re: Trouble codes
I'm still getting a couple of trouble codes but I think I might just need to delete them out. Here they are:
[] P057C - (SES) (Pending) (Old) (History) (Current) (Immature) [] P0621 - Generator L-Terminal Circuit (Pending) (History) (Current) (Immature) [] P0622 - Generator F-Terminal Circuit (Old) (History) (Current) (Immature) [] P2537 - Ignition Switch Accessory Position Circuit Low (Old) (History) (Current) (Immature) I'm running a 2 wire alternator off of a 2004 Chevy truck (140A). I had it checked and it checked out as "good". Any thoughts?
12-09-2013, 01:16 AM | #100 | |
meowMEOWmeowMEOW
Re: Trouble codes
The p057c code came up as an SES for failed cruise control module. I'm guessing you might have something wired off the TCC/brake switch incorrectly (lol I know you and JorgenSC have gone back and forth on diagrams for this in the other thread). can't find anything on the p2537
Thread Tools | |
Display Modes | |
