06-18-2002, 02:11 AM | #1 |
Thats the Hillbilly way
Opinion on price of 72 blazer buckets & console
I can pick them up for 150. the seats need to be reupholstered and some foam replacement ,the console shows normal wear.
These are off a Blazer and I believe the brackets are lower than the one's for the trucks . Does anyone know how much lower , if I get them I will use a spacer to raise them to stock truck height . Your thoughts. ?? Bill
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
06-18-2002, 03:38 AM | #2 |
i would probably pay the 150 i paid $220 canadian just for the 2 buckets and they need to be totally recovered with lots of foam too.
1972 C/10 LWB 1972 K/5 Blazer |
06-18-2002, 07:44 AM | #3 |
Look at it this way---to recover seats----seat covers will cost anywhere from $185. to $300. depending on supplier. Will probably need to repaint console as well = $ 5. If you do the rebuild of the seats, plan on several hours per seat as well as another $10-20. for foam, spray glue, new hog rings, etc. I just rebuilt a pair of seats and it took me about 4-5 hours each seat as they were badly worn. Of course trying to find original buckets that don't need to be recovered/refoam'd for under $400. is about impossible. If you buy them and have them professionally rebuilt---well that could get real expensive. So, if you want the orginal look but not "as built on your build sheet", go for it. If you really want buckets and comfort, you might consider getting a seat asm from a newer truck with a 60/40 seat and built in console as they are much more comfortable. jmo---Huck
06-18-2002, 11:47 AM | #4 |
Thanks ; guy's I always have planned to get a later model bench with a console, just happened to run across these and they got me thinking .
There is still the issue with the Blazer brackets being lower than the truck. Thanks Bill
06-18-2002, 01:01 PM | #5 |
Id be happy to pay $150.I have 3 Extra sets now and several consoles.people offer $300-400 for them but i wont sell,i bought a set from a Blazer only difference was passanger seat folds foward,i put on some extra truck brackets i had,pass side are just stamped steel fixed brackets,you could probably bolt on a set of bench brackets,i know hole widths are the same for bolts on seat.a restored(painted)and cracks fixed console goes for $100-$150,seats when 4 sale needing lots of work are $250,or just buy a set of 73 Blazer seats real common,and make seat brackets.
Thread Tools | |
Display Modes | |
