02-22-2007, 09:40 PM | #1 |
Never Been So Happy To Hear A Motor Run
Well after so, so many set backs I finally got the motor cranked tonight. I haven't heard a big block on open headders in a couple years and I am hear to tell you it sounds bad ass. The cam is so big I am wondering if the 2500 stall is going to be enough, but that is what edelbrock told me to use. Here are the specs on the cam:
Brand: Edelbrock Product Line: Edelbrock Performer RPM Cam and Lifter Kits Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 1,500-6,500 RPM Intake Duration at 050 inch Lift: 240 Exhaust Duration at 050 inch Lift: 246 Duration at 050 inch Lift: 240 int./246 exh. Advertised Intake Duration: 300 Advertised Exhaust Duration: 306 Advertised Duration: 300 int./306 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.560 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.573 in. Valve Lift with Factory Rocker Arm Ratio: 0.560 int./0.573 exh. lift Lobe Separation (degrees): 112 Intake Valve Lash: 0.000 in. Exhaust Valve Lash: 0.000 in. I also put on a set of 206 heads off a 66 396 chevelle, 1.7 roller rockers, 3/8 push rods, edelbrock pro-flo fuel injection, alabama boss hogg 2500 stall, 3:73 gears, eaton posi, patriot clipsetter headders, hydroboost off a 93 3500 chevy, 92 bbc serpentine setup and waiting on glocks new brackets so I can get the impala rear disk brakes on. As bad as it sounds with open headders I think I am going to have to get some electric cutouts so I can run a open exhaust when I want to. I still have to finish some wiring, adjust the valves, set the timing, bleed the brakes,and fix the trans dipstick leak. I will hopefully know how it performs saturday and I will let you all know. |
02-22-2007, 10:44 PM | #2 |
Re: Never Been So Happy To Hear A Motor Run
sounds awsome.. good luck with it!!!
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
02-23-2007, 07:21 AM | #3 |
The 2500 stall ought to be ok. I have run a few RPM cams in small blocks and they work fantastic. Pull hard to 7000 and still have lower end grunt. I can still pull a loaded car trailer with ease. My 68 2wd was a 350 4 speed with 3.73's and I took off like normal with the Blazer on the trailer. I didn't even know it was back there. Very good all around cam with an excellent sound.
69 Chevelle SS 375/396 TKO 600 71 Suburban 3/4 4x4 402 5-speed (project) 68 chevy C10 shortbed 327 5-speed (project) 72 Blazer 4x4 400 4-speed (wifes project) Numerous 67-72 parts trucks Last edited by Troy-Built; 02-23-2007 at 07:22 AM. |
02-23-2007, 10:44 AM | #4 |
Post Whore
Yep, uncorked BBC's are sweet - be interested how the cutouts work for you if you go that route.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
02-24-2007, 11:06 AM | #5 |
The LuvShack Garage
Pic's? Audio clip? Etc.......................
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Thread Tools | |
Display Modes | |
