Help understand these symptoms please!
Hi,
My buddy has a 2000 1500 with the 5.3 gas engine in it. He's been experiencing rough idle/stalling when it's cold. He's also a couple of times gotten code P0171 (System too lean - bank 1). I hooked it up to my AutoEnginuity yesterday after the truck was all warmed up. The short term fuel trim for bank 1 was between -1 and 1, while the short term fuel trim for bank 2 was about 145. Also, the Average Injector PWMs were way out balance on bank one vs. two. So the scan tool seems to be saying that bank TWO has injector problems, and it's continually trying to richen that side. The DTC, though, said that bank ONE was too lean. I logged the O2 sensor voltages, but I didn't have time to delve deeply into what was happening with them. Any ideas? Thanks, B |
chrome makes it go FASTER!
Re: Help understand these symptoms please!
Have you changed your intake manifold gasket yet?
These motors were infamous for poor gaskets resulting in the codes and symptoms you described.
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
#3 | |
Bloo
99+ trucks are notorious for the injectors getting clogged. we have a fuel injector cleaning tool, that runs 75 psi of pressure instead of the normal 55-60. it usually fixes the problem your having
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Pick'n up the pieces!
I've got the same symptoms without throwing a code. I suspect intake gaskets. I'll be checking with the b12 in the next day or two. I bet it's a vacuum leak between intake and head. Only in the cold is my main clue. Time will tell. dkf
Give an update when you can to see if changing the intake gaskets fix your problem. I'm on the short road to changing mine in the next week or two. So it would be nice to know what results you get.
1969 Blazer: 350/350, 4X4, HEI, Edlebrock carb/intake, dual flowmasters, np205, 3:07's and the rest is mostly stock. The front end disc swap is finally complete ![]() 2002 Z71 Tahoe. CAI, Flowmaster 40, Silverstars in high, low and fogs and a bunch of mods (upgrades) inside and out. |
Thread Tools | |
Display Modes | |
