gage cluster bulbs
Does anyone sell at bulb kit for 55-59 oem gage cluster. My turn signal blinker is burned out. I figure I should change them all at the same time.
Re: gage cluster bulbs
best deal I found was a 10 pack on ebay for about $10 from a guy in US. I will post his id when I get to my computer. locally they wanted 2.50 each. do not buy from the hong kong guys, I paid for some led lamps and never got them.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
thanks for the tip!
![]() Join Date: Dec 2012
What should the Color of them be? Red,Green. The Ignition Green bulbs dead for me, reds on its way
1971 GMC Sierra 1959 GMC 100 |
I assume they are all the same color with the exterior color plastic changing the color? Can anyone confirm this?
Orrie: Any luck finding that link? |
Here is the company on ebay and a link to current auction.
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_2177wt_1838 Schrum, the lamps are all clear, the color comes from the lense in the dash panel.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 01-23-2014 at 04:54 PM. |
This won't help on the blinker, but check out these LED's in a gauge.
http://s1074.photobucket.com/user/wh...74341040370092 http://s1074.photobucket.com/user/wh...46499843835435 |
thanks guys... I just ordered them. Do you have to remove the cluster to change them or can them be accessed from behind?
Oh okay some are still lit up but some are dead
I don't remember if I ever had my head up under the dash of my 57 Panel but I think most of them can be reached from the back.
Just for info: There's two different bulbs in the cluster. The gauges use 57's for illumination and the turn signal indicators, high beam indicator, and ignition switch light takes 53's.
#12 | |
There you go give Russell a hand folks as that makes it real simple.
#13 |
Not to hijack the thread, but anyone have a source for the sockets? I'm missing a couple.
#14 |
57 and 53 have the same socket, just different wattage. 57's work of illumination because they can be dimmed. I used them for the others too figuring they are not on long enough to cause a problem. Attached is the back of my cluster, note the new black socket on the right, I got it off the rack at O'riellys, GM used those for decades. I used a trailer connector so I could prewire everything, getting to the lamps after is not impossible but requires small hands, and on mine the AC duct runs up in that area too. The illumination lamps are not in, I reused the original harness from the light switch. Ammeter wirers directly, oil is a mechanical fitting.
#15 |
I need a back of a GMC Gauge
#16 |
That is a nice setup Orrie and solves the pull it out to work on it and have to deal with the wires problem.
#17 |
Orrie....so the empty sockets light up the cluster and the one you changed is a blinker?
#18 |
yes, two outside are blinkers, center high beam. top three guages and Speedo, with extension to heater control lamp. some deluxe had lamp on the ing switch too.
#19 |
My speedo isnt working btw. Time for a new one
#20 |
Thanks, Orrie. I just purchased from eBay. -Doug
#21 |
Does anyone have a picture of a back of the 59 GMC Cluster
#22 |
fyi: i bought new bulbs from napa
illumination i believe is #56 turn and hibeam is #59 pulled numbers from my head, take the old bulbs in
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Thread Tools | |
Display Modes | |
