04-07-2002, 08:14 PM | #1 |
brake adj. problem
Have a 4X4 and just changed front drums to disc. Now the brakes don't engage until the peddle is almost on the floor. I noticed the Power boost rod had a threaded shaft for adjustment, could this need lengthened? Also a light on the dash now comes on that says "tandem lock". Any ideas what this means, I thought maybe the brake light wired wrong or is this it? Any input would be appreciated.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible. |
04-07-2002, 08:50 PM | #2 |
its all about the +6 inches
The tandem lock should be reading brake...it is in the lower left on your gas guage isn't it? This set up is out of a larger truck.
Go and try pumping the brakes and see if it helps, could just be a low level or air. (the light coing on says that to me) ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
04-07-2002, 09:03 PM | #3 |
"See the U.S.A....."
It is possible that the plunger on the booster needs adjusted like you said.But if you over adjust this you may get brake drag or full blown brake lock!
1970 short bed fleetside 1949 all origional chevy 3600 1974 camaro Richmond , Texas(just S.W.of Houston) |
04-07-2002, 09:16 PM | #4 |
Cab is not original so may be off of bigger truck. Will try re-bleeding tomorrow. Am I right that you have to hold in the button on the end of the prop valve when doing the rear brakes? Pumping brake did not help much.
04-07-2002, 10:28 PM | #5 |
you mentioned u change from drum to disk. don't you have to change the master cylinder
disk brakes take more fluid than drums. i have never heard of holding prop valve to adjust the rear brakes. the light might just be i the wrong hole in the back of the dash. the light might of came on because pressure is not building up on front brakes. [This message has been edited by blue72stepside (edited April 07, 2002).]
72 Cheyenne Stepside 357/TH350 3.07 Posi 379HP@5500 412FT#@4000 96 1500 Work Truck 88 Chevy Van 3/4 97 Tahoe 8.5 Lift (Sons) 00 1500 LT 4x4 (Sons) 98 Ford Cobra (Wifes Car) |
04-08-2002, 07:33 PM | #6 |
When I changed I swapped in disc master cylinder and prop valve. Everything now off of an 85 3/4 ton 4X4. Pretty much a bolt up except for changing some brake lines. Didn't get to look at it tonight, got home too late and the moon isn't real bright tonight!!
