Old 12-03-2004, 04:44 PM   #1
OverRunWithSons
OverRunWithSons's Avatar
'88 --Replacing "Pick up Coil" --Distributor question....
I am asking this for my husband.... on how difficult is it to replace a "pick up coil" on a Suburban (5.7 liter), does the entire DISTRIBUTOR have to be taken out of the engine to replace this simple $10 "pick up coil"...... is it worth the trouble to do this on your own with a Haynes manual --- or should he take this to a garage, how involved is this project, how time consuming? Any advice, please help! Thank You
OverRunWithSons is offline   Reply With Quote
Old 12-07-2004, 08:57 PM   #2
bisquik65
bisquik65's Avatar
You have to remove the dist from the motor. Take the cam gear off and remove the dist. shaft from housing,use plenty of p.b.blaster/wd40 to make it eaiser . Then remove the module and little clip holding the coil in place. You can do it but if your shaft wont come out you might have to get another dist. When the shafts get tight on tbi engines it will cause high idleing and loss of power under load. Hope this helps,Erick
bisquik65 is offline   Reply With Quote
Old 12-08-2004, 02:05 PM   #3
OverRunWithSons
Thank you for the reply...
My husband got my dad to help him the other night, all went well, easy than he was expecting. Thanks again.
