Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-18-2006, 10:34 AM   #126
409biscayne
409biscayne's Avatar
Re: Ran 11.44 @117.69mph
Originally Posted by 71Dragtruck
Let us know what you find out about the doors. The pics you showed of your bed, that's complete? You just have side skins and tail gate skin no front, with framework? What do you run for a cover? I've often wondered if a aluminum floor would be worth the cost, I want to lighten mine up, but would like to keep a full bed.
How do the repro steel doors compare in weight to 'glass ?
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 07-18-2006, 10:40 AM   #127
djracer
djracer's Avatar
Originally Posted by 409biscayne
Morning guys
This is my favorite thread . I'm running the factory points distr , with 38 degs of timing , no vac advance , i do have a 6a box and msd distr i could swap in . Whatta ya think of a 75 shot of NOS ?
Not trying to hi - jack , that's my last question .
Thanks ....................................... 409.
Don't think you are trying to Hijack I revived the tread just to keep it going feel free to ask all the questions you want! If you have forged pistons I'd add the msd and the nos!
The glass doors I have are way lighter than aftermarket steel! I can easily pick up a door with one hand!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-18-2006, 10:55 AM   #128
409biscayne
I don't really know what pistons i have , i've never had the heads off . I would guess there the stockers , everything else was . I need to get this big fella to 13.99 , so i can race bracket 4 . Lots of cars in bracket 4 , only about 7 or so in bracket 5 . I'd rather not get too deep into the motor at this time , better in the fall / winter.
Later .......................................409.
Can-Am Motorsports
Old 07-18-2006, 11:07 AM   #129
djracer
djracer's Avatar
You would probably be fine as long as you don't detinate it! I'd start with the msd!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-18-2006, 11:09 AM   #130
djracer
djracer's Avatar
Bigjim
I'd like to see more pics of how your bed is attached and interested in what you run for a cover if any!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-18-2006, 12:54 PM   #131
71Dragtruck
71Dragtruck's Avatar
Yes all questions are welcome here, it's the new drag truck discussion thread. 409, a little trip to Canada you could pick up my old motor, it ran 12's. For sure drop in that MSD stuff, must need with the NOS.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 07-18-2006, 03:11 PM   #132
nxtruck
nxtruck's Avatar
Thanks for the info Jim! 409, I know that if you're careful with your tuneup, a stock shortblock will take 125-150 hp hit of spray. Like I said, though, you really need to look at all of your plugs and make sure that it's not detonating. Go 1 step colder on your plugs and follow the nitrous company's advice on recommended fuel pressure. Also, take out 4* timing for every 100 hp added. This will get you close. BTW, the MSD will definitely make life easier when adding the spray.
nxtruck is offline   Reply With Quote
Old 07-18-2006, 03:30 PM   #133
djracer
djracer's Avatar
Just got off the phone with Marty Chance of Neil Chance racing convertors I will be sending off my 9 convertor in the next day or two to get it checked out and tightened up!
Hope that will help my times on the spray! It may hurt off the bottle but you got to give a little to get a little!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-18-2006, 04:50 PM   #134
bigjimzlll
bigjimzlll's Avatar
Yup thats my complete bed. It mounts with 2 studs to the cab..2 mounts in the back and 2 out riggers by the wheel well. I have an aluminum bed cover made from 3 pieces of .030 aluminum. Mounted to 1x1 square aluminum tube. With the back panel piano hinged.
The truck is at the painters right now...when I go over I will take some shots of the bed mounting and cover..b4 and after install.
409...a 75 shot will sure wake that puppy up...yeeehaw
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 07-18-2006, 05:07 PM   #135
69CvyPickup4x
69CvyPickup4x's Avatar
dont know how many people do this or maybe its been talked about earlier.. but there was a truck that had a custom rear bumber made from rectangular tube and the guy put a little hole in the top to fill it with a 100 pounds of lead said it helped with traction greatly..
69CvyPickup4x is offline   Reply With Quote
Old 07-18-2006, 05:09 PM   #136
djracer
djracer's Avatar
Thanks for the pics in advance BigJim!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-18-2006, 05:11 PM   #137
djracer
djracer's Avatar
If these trucks are setup right they hook pretty well with out adding weight! The rule of thumb is every 100 pounds is a tenth of a second! I need to eat less cheese burgers!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-18-2006, 07:25 PM   #138
bskylerj
bskylerj's Avatar
Originally Posted by djracer
Post us some pics I'd love to see your ride!
DJRACER,
I will get some pics soon. My fuel cell has a leak so I pulled it and I have just a few more things to get on it. I need to cut and buff it again as the last guy did not do a good job at all.
71Dragtruck,
I have the slicks sitting here ready to throw on it. I will be out there soon. We are shooting for the dyno at the end of next week as well. We are hoping for high 10's low 11's. I need to hit the 10's so I can get my new personal plate 10SEC71.
bskylerj is offline   Reply With Quote
Old 07-18-2006, 08:06 PM   #139
57sailplane
57sailplane's Avatar
hey bigjimlllz
please can you post the bed pictures. come on i wana see....
57sailplane is offline   Reply With Quote
Old 07-18-2006, 08:55 PM   #140
71Dragtruck
Originally Posted by bskylerj
DJRACER,
71Dragtruck,
Well if you don't get in the 10's I might have to use your plate idea for mine. Just kidding, hope you make it, and in one piece. I would like DRAGTRUCK but too many letters maybe DRGTRK, DRAGTRK, DRGTRUK, just don't look right. Maybe DAMFAST, or an idea from 20 years ago WICKED
Sponsored by:
Hard Candy Customs
Old 07-19-2006, 12:22 AM   #141
bigjimzlll
bigjimzlll's Avatar
I'll get pics as soon as I can...It's just too damn hot to go out. Over 110 all day today.
On the tag thing..I was thinkin just "YES" yes it's fast...yes i'll race you..yes it's street legal...yes i'll take your girl friend....
Anderson,CA
Old 07-19-2006, 12:28 AM   #142
409biscayne
DJRACER,
71Dragtruck,
Dang it Brian , you're killing me . I've got to get faster or my plate will be 14SEC68 . Maybe a 150 shot .
Can-Am Motorsports
Old 07-19-2006, 12:31 AM   #143
djracer
djracer's Avatar
I might need to get one that says 8secpu After a little more work!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-19-2006, 12:58 AM   #144
71Dragtruck
That thing of yours get's any faster than that you'll have to get one for good luck that say's THISIDEUP.
Thinking SEEYA would ge good also.
Sponsored by:
Hard Candy Customs
Old 07-19-2006, 01:04 AM   #145
djracer
djracer's Avatar
How about likmygat
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-19-2006, 01:34 AM   #146
bskylerj
bskylerj's Avatar
I think I like them both DAMFAST and THISIDEUP.
409(Doug) The headers and new exhaust will be your answer. lol
Just kidding. I think the 150 shot on yours and it would be the ultimate sleeper. It looked like you had some good lights a few weeks ago when I was out there.
Old 07-19-2006, 11:57 PM   #147
71Dragtruck
What are you guy's running for race seats? djracer I see you have Kirkey seats in yours, what size are they and how do they fit? I'm a larger guy, 6' 1" around 250lbs. farm boy build I ordered in a set of cheap seats but they are fairly small in the seat part, not too bad on the back little tight in the ribs. Likely ok for a 1/4 mile and a bit of cruising, but still thinking of the Kirkey seats. The place I get stuff from has 17" in stock, had one 18" but gone now, need to decide by tomorrow night if the ones I got are going back or not. Leaving Fri evening to get my roll bar in, I guess what I need to know is how do the Kirkey seats fit. Looked at the measurements on thier web site, but also thought the ones I got would be fine from the measurements. Don't really want the RCI type plastic ones, They ones I got are a sports car type, not too bad for weight, but for sure heavier than full race seats.
Sponsored by:
Hard Candy Customs
Old 07-19-2006, 11:59 PM   #148
71Dragtruck
DAMFAST on the back, and THISIDEUP on the front.
Sponsored by:
Hard Candy Customs
Old 07-20-2006, 12:28 AM   #149
bigjimzlll
bigjimzlll's Avatar
i'm using a cheap RCI type....and I'm 6-3 290lbs
Anderson,CA
Old 07-20-2006, 12:39 AM   #150
djracer
djracer's Avatar
I think the kirkey's I have are 17 inch! I am 5 10 210! I love the kirkey's they fit the truck and my butt quite well!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
