12-02-2006, 06:39 PM | #1 |
Junior Member
How Low????
I know that this question has probably been asked a thousand times, but I am going to ask it again. I just picked up a '70 Chevy SB and I want to lower it without using air. I already have a front disc conversion with drop spindles and the rear is coil. I want to lower it as low as I can.
Dave http://www.putfile.com/dham ~ 1970 Chevy Big Block SB 2wd - driver/restore ~ 1967 Chevy SB 2wd - project ~ 2007 Cadillac EXT on 22's ~ 2006 Allison Performance Boat+225 Merc=87mph |
12-02-2006, 06:47 PM | #2 |
Re: How Low????
You can do a 6" drop coil in the rear and I think a 2" coil in the front. You can also run a 2" block in the rear, but you might be close to the frame at that point, so consider a frame notch.
It might be a harch ride, but you'd be low. |
12-02-2006, 07:29 PM | #3 |
Re: How Low????
"Low enough" is never low enough.
12-02-2006, 07:45 PM | #4 |
I am a Referee of life.
Re: How Low????
As far as it goes you can "Z" the frame and have it layin' rail.You won't be able to drive it that way but you can lower it that much.The real question is how low can I get away with and still be able to drive it.The ride height you decide on needs to be high enough to keep you from high centering on speed bumps,in dips in the road and on the slope of driveways.I think for around here that would be at the very least 4 in for a weekender and around 6 for a DD.You know the conditions where you live better than I but these are things you need to consider.You don't want to hate driving it cause it sprays sparks everywhere you go.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
12-02-2006, 10:58 PM | #5 |
Re: How Low????
I am not using air, either. Air was way out of the budget. I simply have 2 1/2 inch ECE drop spindles and 2 inch springs on the front and 5 inch springs in rear. Of course I can go lower in the rear, but I wanted a nice rake look. Also, your wheel/tire package will be a factor in your decision. I run 20s on all corners with 255/45-20 front and 295/45-20 rear. This may help serve as reference.
Jesse
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) |
12-02-2006, 11:24 PM | #6 |
WTB this ad
Re: How Low????
This thread is a wheel tire thread but a lot of guys also have their drop listed as well. http://67-72chevytrucks.com/vboard/s...d.php?t=143835
I wanted my C10 as low as I could it get it out back without having to run a notch. I also wanted to keep the rake to a minimum. I wanted her to look pretty close to level. My rear drop is 6" which I was told wouldn't bottom out but it does. Under most driving conditions it's fine but if I hit railroad tracks to fast or when I drop off a speed bump it bottoms out. I am kind of halfway planning on adding a notch with a large bumpstop. I would rather have it hit on a rubber stop than on the frame. If you put in a notch with a very small bumpstop (or none at all) reportedly you start having axle bedfloor clearance issues. My front drop is a 2.5" drop spindle combined with a 1" drop coil. Here it is parked next to member 71see10s pickup his truck has a 2.5" drop spindle with a new stock height coil in the front. Out back he has a 5" drop coil. In my opinion he has the right drop if you don't want to be worried about bottoming out but still want a lowered truck. You can also go to www.earlyclassic.com they have a section of stance photos. |
12-02-2006, 11:52 PM | #7 |
Re: How Low????
Since we're on the topic...
If you lower the rear 5 or 6 inches in the rear without air, will you lose the ability to tow? I don't do alot of towing with my 72 (that's what the 93 K1500 is for), but i'd like to have the option to pull a trailer if need be.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 12-02-2006 at 11:52 PM. |
12-03-2006, 12:31 AM | #8 |
Re: How Low????
Nice trucks see-ten!! The towing would depend on tongue weight I would guess. With it that low any tongue weight would push it down to the frame. Where you at in MN brak?? I'm in the cold part
12-03-2006, 01:56 AM | #9 | |
Re: How Low????
I'm down in bloomington. as far as towing, that's what i figured, but i remember that somebody (western chassis maybe?) had it listed on their site that a 4/6 drop was the lowest you could go and still tow. my truck was lowered by the PO, not sure how far, but it bangs badly. I'm preparing to swap over to a SWB frame, and want to do the suspension right. I like the idea of a 4/6 drop, but want to make sure my truck is still functional.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
12-03-2006, 04:22 AM | #10 |
Re: How Low????
Im 6/8 with spindles and coils up front and coils with "custom" spacers on the ass end.
Personally its to low for me being that its also my daily. My rear axle makes contact with the frame on even the tiniest of bumps. I cant pull up to the speaker thing at Sonic because my front bumper wont clear the curb thing they have there. And its to "rakeish" looking for me, but it was like that when I bought it so Im not to blame. If I had the time Id notch it. And the ride is so bumpt its made my CD player skip a few times. But like any project practicality comes first. Sure you want the truck to sit down in the weeds...but not so low you cant drive over a speed bump. And dont forget the "nickle and dime" **** that comes with every project (different shocks, bump stops, etc....) and look at 71See10s truck...you might even need an alignment too. Hopefully I dont need to tell you NOT to ever cut coils to lower a vehicle. never, never, NEVER do this....I dont care what some self proclaimed gearheaded backwoods hillbilly tells you. DONT DO IT! |
12-03-2006, 04:31 AM | #11 |
Re: How Low????
Oh yeah....and get an adjustable panhard bar so you tires dont rub when you turn right.
12-03-2006, 09:23 AM | #12 |
WTB this ad
Re: How Low????
Those pics of 71see10s truck were made right after we finished with the drop and it had not been aligned yet. Alignment was a real nonissue, it seems like it only had to have two shims added on the passenger side. The cost of a drop can also add up quickly. I think I spent about $1800 on mine. The drop kit is just a small part of the equation. You have to figure for things like new exhaust (it no longer clears things down there anymore). I also used the ECE extreme drop crossmember and had a one piece driveshaft built. Then we somehow missed it needing upper control arm bushings until it was at the shop to be aligned, so I let the shop handle them. Both my truck and his also used the super track bar out back to keep everything lined up when rolling down the road. I would also think that towing a trailer with a 6" drop isn't going to happen without the addition of some bags back there. ECE sells a rear bag kit just for this purpose. You don't have to have an onboard compressor but you will have to fill a schrader valve every time you want to load it up.
12-03-2006, 01:30 PM | #13 |
Chinook Arch
Re: How Low????
I've hauled 2 sport-bikes in mine with a 5" drop, and it wasn't bottoming out.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus. Elsie's truck 2.5" dual exhaust with Hooker Aero Chambers Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350 ECE drop 3.5/5 |
12-03-2006, 01:35 PM | #14 |
Re: How Low????
12-03-2006, 07:51 PM | #15 |
Junior Member
Re: How Low????
I love this site. Thanks see ten for the pics, AWESOME truck by the way. Thanks everyone for the input.
12-03-2006, 11:05 PM | #16 |
Re: How Low????
Just one...its ****ty though. I took it through the windo right after it rained. Its also got my peice Camaro in it....
