Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 09-29-2006, 10:33 PM   #251
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Re: New Project truck!!
Here is a bad pic of me bringing the truck home from getting the exhaust done. Had a tune and a 4.10 gear put in the 05 just to pull a trailer better!! Mobile phone pics SUK!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 10-01-2006, 12:07 AM   #252
phantom dually
Ok guys I got my gauges wired up and mounted to the interior panel. Though they are not in the truck and completly wired I had to show a pic. I was hesitant on spending the extra $$ for the ULTRA lite 2 series gauges. But after seeing them light up Im sold. What do you think?? One pic is a daylight pic with power off. One is woth power on in daylight. Other is lights out night time pic.
Old 10-01-2006, 06:29 AM   #253
That is very nice. They look very good all lite up!
Old 10-02-2006, 02:57 PM   #254
phantom dually
Thx I am really happy with the look!!
Old 10-15-2006, 11:43 PM   #255
phantom dually
I have got a little done on the truck lately. Got the 97 column fabbed up and mounted in. Took me 3 days to wire the column up to the 92 harness. I have to go to the Junk yard and get a DS light for under the dash. After I get the light I can button up the wiring. The gauge panel is mounted and I can start to wire all the senders. I was really happy to get my brake lights, tail lights and turns all to work right. So far everything is going pretty smooth. The hardest part of the dash swap by far has been the column mounting.
Old 10-24-2006, 04:49 PM   #256
84 400
Sb 400 club
84 400's Avatar
nice work dually can't wait to see it wrapped up!
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 12-15-2006, 09:08 PM   #257
phantom dually
TTT still alive!!
Old 12-17-2006, 11:41 PM   #258
BayouSS
BayouSS's Avatar
Glad to hear that, I was getting worried.
1990 454SS Under Construction
1996 Corvette Collectors Edition LT4 Slightly Modified
BayouSS is offline   Reply With Quote
Old 12-28-2006, 11:13 PM   #259
phantom dually
Finally I have a update that I can post a pic of. I have not been working on the truck as much as I should but whats new!!! I recently completed the wiring portion of the 92-97 interior upgrade. I got all the power windows/locks, steering column, headlights, tailights, brake lights all working. The swap from 92 to 97 is NOT for the faint if heart. Mounting the column iteself was a big challenge. Anyhow everything is now working. I started working on the fuel system. I got the bed cleaned up a bit and sprayed it with a rattle can brand bedliner. I fiquered I didnt want to put $400 into a spray on rhino type liner for a bed that wil not see any work ever again. After I cleaned the bed I got to fitting the fuel cell. Turns out I picked out the only fuel cell summit has that does not have a set of mounting brackets available for it. After a quick trip to Home Depot I picked up a few pieces on 1" wide aluminum strips. I used them and bent them up to make my own mounting brackets for the cell. Got the fuel cell mounting done tonight. I have a few pics attached. They turned out very bad due to the lighting. I have not plumbed any of it yet. I plan to start that maybe friday??
Old 12-29-2006, 07:02 AM   #260
Kevin45
Kevin45's Avatar
Phantom, Phantom, Phantom........I have always looked forward to see your upgrade pics. But rattlecans? With the quality of work on the rest of the truck, don't stop at the bed. And if you do leave the rattlecan undercoating maybe go back over it with the gallon can of bedlining that you can get from the parts store that rolls on. The reason I say this is that looking at the bed tunnel you see dull and light spots. You can't put everything else under the spotlight then stop there. You need a uniform look. Even though the bed don't /won't see duty doesn't mean it won't get looks. BTW nice job on everything else.
Kevin
'93 Silverado Reg. Cab Shortbox
.060 over 350 Quick and fun!!!
Kevin45 is offline   Reply With Quote
Old 12-29-2006, 08:04 PM   #261
5.7L JWL
Keep up with the pics. Looking good so far. Where did you get the 4 link from and where are you pulling your geometry from for the set up. The reason I ask is have a drag truck and am thinking about a 4 link.
I wrote the above way before getting to the end of this thread. Your pics and work are great. It's one thing to buy something done it's another thing to build something yourself and have fellow enthusiests praise your work. You should take pride in your truck especially knowing you did most of the work yourself. Just my $.02 Jay
'98 C-1500 ECSB 5.7L Edelbrock shorty headers Ceramic, Stage 8 locking header bolts, Magnaflow S/S y-pipe w/converters, Magnaflow S/S
Cat-Back Exhaust (DI 2.5" / SO 3.5" w/ 4" Tip.) Synthetic Fluids throughout. Polished TB with Blade removed, ASP Pullies, Performance Distributors "Vortec Firepower" Ign. Kit, BlackBearPerformance Tuned PCM '84 Kawasaki KX-80 "Mint"
5.7L JWL is offline   Reply With Quote
Old 12-29-2006, 11:13 PM   #262
phantom dually
Thx for the comments. The rear setup is a comp engineering ladder bar setup wirth Qa1 coilovers. I followed the directions that came from Comp engineering. Seems to have turned out OK. I am rethinking the bedliner. It really dont ook bad at all in person BUT the stuff i used scraths easily. Im going to look into line X or maybe a do it yourself herculiner.
Old 12-30-2006, 12:11 AM   #263
97silv5.7
MooMoo
97silv5.7's Avatar
Bed looks sweet! I think it would look very good with a nice spray in liner
'97 ext 4x4 3" body lift and 7'6" Fisher MM2
'04 Polaris 700 twin EFI **sold 2-1-07**
'07 Polaris 800 twin EFI Stealth Limited Edition
Support the Board! Or deal with me foo!
Its all fun and games till you find out shes 16.
97silv5.7 is offline   Reply With Quote
Old 01-02-2007, 08:18 AM   #264
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
i just read through the whole thread...nice truck..your doing a great job on it..i like the gauges,,they look great when lite up. the rest of the truck looks really great..good job on fabricating..
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 01-03-2007, 11:51 PM   #265
phantom dually
Thx. I recently found a online Ebay seller who has original takeout carpet with the plastic still on it. $100 shipped.
Old 01-22-2007, 11:49 PM   #266
84 400
Sb 400 club
84 400's Avatar
nice work keep it up
1985 C10 LWB Sold
Old 01-24-2007, 12:46 AM   #267
corn
I couldnt tell by the pics. Did you mount your new cluster behind the stock lens? I like the panel black better. Im not a huge carbon fiber fan but it may look pretty sharp on your panel in a newer dash like that. Keep up the good work!...
corn is offline   Reply With Quote
Old 01-24-2007, 11:23 PM   #268
phantom dually
Yes I ended up using a piece of black matte finish plastic. My buddy owns a sign shop and has alot of diffrent materials. I do plan to put it behind the stock cluster BUT I am going to have a company put a new piece of clear plex over the piece. The one I have is scratched and cracked. The main decision is the hole in the stock cluster lens is in the wrong spot.
Old 01-25-2007, 12:09 AM   #269
corn
I think that will give it the perfect finishing touch behind a factory lens. Gets my approval. Cant wait for the next update...
Old 01-30-2007, 11:38 PM   #270
phantom dually
Here are a few pics I snapped. Notice the window switchs from the 92 style to the 95-up. Also the dash and column swap. I will be putting the interior together in the next few weeks. I put new window sin the doors. Also the inner metal panel had to be changed out to go from the 92 door panels to the 95-up. The seats shown are not going to be used. I ordered a set of LG1 leather buckets from corbeau today.
Old 02-03-2007, 08:38 PM   #271
84 400
Sb 400 club
84 400's Avatar
truck looks *****en
1985 C10 LWB Sold
Old 02-21-2007, 10:57 AM   #272
84_chevrolet
Truck CRAZY!
84_chevrolet's Avatar
hey nice looking truck and that is some awesome faberication, but i would like 2 know what is envolved in putting the dash in how much metal work and wiring is envoled in it and any pics of ur metal work or anything would be appreciated and did u have 2 cut or modify the dash any?
84_chevrolet is offline   Reply With Quote
Old 03-09-2007, 09:52 PM   #273
phantom dually
Dash will bolt right in. If you can find a donor truck you can drill out the bracket which holds the column and put it into the older truck. Wiring was not to bad. By searching the internet you can find alot of info. I did my column wiring by myself. If you have a good 12v knowledge along with a test light and a voltmeter this is not bad to do.
Old 03-13-2007, 09:27 PM   #274
phantom dually
I finally have a few updates. Got my cluster lens issue fixed. The flash of the camera adds some looks of scratchs on the dash bezel. These however are not there or seen in normal lighting. Added a new steering wheel also. I have test fitted the seats and am very pleased with them. I am currently searching for some good cooling fans.
Old 03-13-2007, 10:27 PM   #275
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
It looks like you had to make some seat supports. do they still slide. the gauge looks damn sexy by the way
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
