Old 05-12-2002, 09:25 AM   #1
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Post What causes this sound wo wo wo?
The wo wo wo wo wo while going down the road?
thanks
Ben
67 Fleetside Custom C-10
SBC 350 .030 9:1 comp.
Comp Cams Extreme Energy XE256H-10
Carter AFB 600
Edlebrock performer intake
Screw in rocker studs
Oversize valves
Scat 350 crank
Everything balanced within one gram.
Marine grade plywood bed(looks awsome)
67Fleetsidedream is offline   Reply With Quote
Old 05-12-2002, 09:28 AM   #2
Andy4639
Old member
Andy4639's Avatar
Cool
A TRAIN near by. Had too!
Sorry couldn't pass that up.
It's not enough to go on what else is it doing?
Andy
71's Are for ever!!! or 67,68,69,70,72
71,factory tach,tilt for straight drive,gauges,ac,speed warning,clock,305 HO TPI with 700-R4, lowered 2" & 3" ,and 17" Chrome Stealth wheels, Pioneer reciever,100 watt amp, 6 disc changer, 2-10" subs (behind seat) 2-6x9 in doors, 2-3ways mounted under seat, and 2 tweaters on door panels
www.geocities.com/chevy71tpi/main.html
www.picturetrail.com/Andy4639
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-12-2002, 09:42 AM   #3
Gordo
Talking
Yeah,,,need more info. A couple things come to mind anyway, scalloped/knobby tires or wheel bearings going bad, front or rear.
1971 C10 swb stepside 350/700R4/3.73posi
Killingworth, Connecticut
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 05-12-2002, 09:50 AM   #4
68 Stepside
huh?
68 Stepside's Avatar
Post
Carrier Bearing?
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 05-12-2002, 10:09 AM   #5
67Fleetsidedream
Post
It does it at around 1500-2500k rpm range in 3rd gear when moving down road.
Ben
Old 05-12-2002, 10:40 AM   #6
tom hand
CCRider
tom hand's Avatar
Post
I would look at the tires first. They seem to be the most common thing to cause that problem. If you know someone that has a truck that has wheels that fit your truck maybe you can talk them into switching[one at a time] to help find the problem. BUT [and this is a big one] it could be most anything that rotates so you could be looking for a while. Transmission,[espesally if it is a manual]driveshaft,u-joints,carrier bearing,rearend, or wheel bearings could also be suspect. It is impossable for anyone to tell you without hearing it.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
Olive Branch MS
tom hand is offline   Reply With Quote
Old 05-12-2002, 12:29 PM   #7
68Custom
Hammer On!
68Custom's Avatar
Post
I agree with 68 Stepside, CHECK THAT CARRIER BEARING!!! I had mine replaced and the new one gave out not even 1 week with it on, but before it did i was hearing an odd (at the time) sound from under my truck. I let it go (big mistake) and ended up having it towed back to shop because the new one broke completely, not fun! Good Luck
68Custom
1968 C10 Custom Long Wood Bed
New Crate 350/TH400, PS, PB
*50th Anniversary Pickup*
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
68Custom is offline   Reply With Quote
Old 05-12-2002, 12:42 PM   #8
Fast68Chevy
Fast68Chevy's Avatar
Post
if it does it at same rpm no matter what gear you are in then its not tires, if it only does it at certain speed the its tires or could be driveline, have to sit down and think about what things would make sounds at certain rpm or speed and such. if you think its tires then swap a couple spares on the front or rear and then go drive again at same speed when it was doing it and see if it is, if it still is then chekc out the bearing, see how much slop is in it and also in the rear U joint at the rear axle, shake the driveshaft all around, or try to and look for slop, especially if truck makes a clunk! when you put it in gear(if its auto trans)
i had a maybe similar kind of sound come from under the 79 G20 van when was cruising at around 75 or 80, like a hummmmmm......hummmmmm.....hummmmmm noise, thats when i knew i was really booking it down the freeway as the speedo was not connected up, it was either the little passenger tires not liking the rpm they were turnign or the driveline slip yoke with wear int he splines,. never did care to find out, it cruised liek a caddy so oh well. it was a neat sound actually, only someone like me would take a 79 G20 beater trashed van with door rotting off and loosing pieces of door skin and body side molding and other body panels onto freeway literally that fast and think nothing of it hell yeah zoom zoom
good luck !
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase, #1
-90 Cavalier 2.2L sky blue, a driver
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2
-82 purple Trans Am, project #3
*Paint is overrated*
© RSS Enterprises 2000
[This message has been edited by Fast68Chevy (edited May 12, 2002).]
Fast68Chevy is offline   Reply With Quote
Old 05-12-2002, 01:37 PM   #9
imaindianoutlaw
GMC SHORT FLEET F/S
imaindianoutlaw's Avatar
Post
tires are cupped
Charles W. Hein
S. Williamsport PA
imaindianoutlaw@yahoo.com
REFRIGERATION TECH
1971 Rolling chassis
FOR SALE
1963 Pontiac Tempest
1965 Pontiac GTO
1956 Pontiac 2 dr
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
imaindianoutlaw is offline   Reply With Quote
Old 05-12-2002, 03:05 PM   #10
67Fleetsidedream
Post
I will check the carrier bearing. I don't think it is the tires. I bought 4 new ones 4k miles ago. Could the drift shaft be out of balance? I just does it at a certain RPM range.
Ben
Old 05-12-2002, 03:21 PM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Post
Wasn't this question answered in the "How to shower like a woman/How to shower like a man" post?Woo Woo sound???
Deland does Chevys 68Chevy panel(LIZ)
"A man and his truck,it's a beautiful thing"
"I have the body of a god,unfortunately it's Budda"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-12-2002, 03:24 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I have had worn rear bearings do this too.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
E-mail longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-13-2002, 04:50 AM   #13
67lwbfleet
Post
Could it be the pinion gear in the rear?or low diff. fluid.
[This message has been edited by 67lwbfleet (edited May 13, 2002).]
67 fleet 327cu.small window hope to grow up 1 day and be a big block im still in red primer.my owner lives in raven territory.
BALTMORE,MD
67lwbfleet is offline   Reply With Quote
Old 05-13-2002, 05:38 AM   #14
Mudder
Mudder's Avatar
Post
my swampers sound like that at about 75 mph, and yes the old ones were cupped.
67 stepside 4x4 Owensville MO mudder67@hotmail.com
Mudder is offline   Reply With Quote
Old 05-13-2002, 06:24 AM   #15
kurts72
Post
Tires is my vote.
Kurt in Durand, IL
kurts72 is offline   Reply With Quote
Old 05-13-2002, 07:23 AM   #16
imaindianoutlaw
GMC SHORT FLEET F/S
Post
if its 4x4 its tires my bet
Charles W. Hein
S. Williamsport PA
REFRIGERATION TECH
FOR SALE
1965 Pontiac GTO
1956 Pontiac 2 dr
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
Old 05-13-2002, 09:03 AM   #17
Joachim
Carolina Cajun
Exclamation
Have a similar sound in mine, believe it to be the speed-O cable. Tried lithium grease. Some relief but not totally gone away.
Joe
The Carolina Cajun, almost famous in North Carolina since 1989!
Driving a 68 & Restoring a 66.
Lookin' for Rochester Manual 1bbl & 2bbl carbs!!
Concord, NC & Ponchatoula, LA
Joachim is offline   Reply With Quote
Old 05-13-2002, 09:05 AM   #18
68 Suburban
68 Suburban's Avatar
Post
Arsinial Hall?
Check out other members trucks
1968 50th Anniversary C-10 Suburban (Tows all these cars all over the place)
1968 50th Anniversary C-20 Pickup CST, Sold to Fine69
1969 SS Camaro Conv't
1960 Lakewood Travel Trailer
1963 Ford Falcon Wagon, Still For Sale
Phoenix, AZ.
Click Here for Parts and Venicles I have Available
THINGS I AM LOOKING FOR:
67-68 SUBURBAN TRIM. $$$$ Reward
for finding the 3rd door trim piece
and the small piece that goes on
the 1/4 panel right behind the
3rd door.
Click Here to see the two pieces I need.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-13-2002, 11:24 AM   #19
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
is it comming from outside the cab, or inside, mine makes that sound too, but it is definitely the spedo cable, and it only does it in cold weather. I did have a big truck that made that sound one time, accompanied by a vibration, this was about 50 miles before the ring gear in the rear drive axle snapped in 3 pieces, i hope that is not your problem.
"In the words of Motley Crue, This will always be my home sweet home"
Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
Angel girl: 67 Cutlass convertible
330, 3spd stick
Greener: 90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
no name yet: 72 442 under serious construction
my site:
http://communities.msn.com/Beastonabudget/homepage
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 05-13-2002, 04:42 PM   #20
COBALT
COBALT's Avatar
Post
What happens when you speed up and/or slow down in this RPM range?
What about going around corners (1500-2000 RPM isn't all that much)?
If you're sitting still, and your tranny is in N and you rev the engine do you hear the sound?
Find a long hill, and start at the top. Put your truck in N and coast down. When you reach that familiar RPM range do you hear the noise?
With that same hill start at the bottom, and drive up until you reach that RPM range (I assume you'll hear the sound). Does the noise sound worse than usual? Does it sound worse then when you coasted down hill?
Is the sound coming out of a particular side of the truck?-front, rear, driver's side, passenger's side? Have someone ride in the back on a flat straight road with no other cars and listen...
With what you're telling us it could be anything engine, trany, driveline, or differential related! Narrow it down.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
