05-09-2008, 12:11 AM | #1 |
Parts Hunter
Re: Project 67 GMC custom 6.5 turbo diesel
I have the entire hydro boost from the 88 burb that donated me the 6.2 I will not be using. Make sure if you go with the 6.2 and turbo stuff you studd the heads. I'm gonna stud my 6.5 just because I have the kit I was going to use on the 6.2.
1968 Chevelle 300 DLX (350 4 speed) 1984 GMC 2500 6.2, 700r4 work truck 1967 GMC Custom (was 6.5 Turbo Diesel powered) My ebay Store: http://stores.ebay.com/The-Musclecar...3aFQ3aSTQQtZkm My website:http://themusclecarshop.net/ 1967 GMC 6.5 TD conversion build:http://67-72chevytrucks.com/vboard/s...d.php?t=290922 |
05-09-2008, 12:32 AM | #2 | |
GM 6.2 build up It's a great read and has helped me to avoid what NOT to get. Also, there is a lot of great info on dieselplace.com along with the awesome info board member Russell has been giving me. I'm new to the diesel concept, but a friend and I are building a bio-diesel still at his house. He bought an '01 Dodge Ram 3500, I decided to stick with what I know and got the '71 I may end up just getting a runner in there for now and building a monster motor or saving for a Duramax/Allison combo as an upgrade later. Being on a tight budget sucks, but it's worth it.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
05-09-2008, 09:08 AM | #3 |
Parts Hunter
Jimmy,
Good call on that article. I read it after the fact and the 88 6.2 I have is a v-belt motor. We aren't sure what to do with it now and were thinking about finding a shoe box nova wagon and leaving the diesel stock and just pulling mpg on the cheap with it. Ya it took us a few pitchers of sierra nevada to come up with that one.
05-09-2008, 09:12 AM | #4 |
Parts Hunter
Spray-bomb I've seen a few of these updated cooling set ups on ebay and wasnt sure about them. Its good to hear another opinion on it. My question is, how much of it do I need? Any good articles out there I can digest? For injectors I got a set of marine nozzles and am having my diesel guru buddy do the tear down-clean-rebuild for me. I'm still lost tho..............where is Health Diesel? Web? Brick-n-Morter? both?
05-09-2008, 02:03 PM | #5 |
I have a radical idea!
Here a few of the better sources for parts including Heath's site. I recommend a DSG main girdle if you plan on turning up the boost. I also recommend a set of fast heat glow plugs aand manual controller. These engines are actually easy to get first generation Duramax numbers out of (300HP/500TQ range) if you change the pistons to 18 : 1. Tim (Special-K) has a Peninsula 300HP 6.5 in one of his trucks.
http://www.ssdieselsupply.com/ http://www.heathdiesel.com/ http://www.dieselservices.com/html/g...iesel-special/ http://www.marinepowerusa.com/diesel.html http://www.peninsularengine.com/
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 05-09-2008 at 02:06 PM. |
05-09-2008, 02:09 PM | #6 |
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
