Old 07-27-2008, 05:22 PM   #1
72blazer_mud_bogger
72blazer_mud_bogger's Avatar
serptine belt conv....
i converted over to the serpentine belt when i first built my motor and put new accessories on, since have had a problem with my power stud on the back side of my alt seems to be shorting out and cooking my alt by jumping to the valve cover. can i get a bigger belt than the one i have and use the old style alt bracket and move the alt a bit away from the valve cover... any ideas would be a great help. tired of buying altenators
72blazer_mud_bogger is offline   Reply With Quote
Old 07-27-2008, 05:50 PM   #2
Re: serptine belt conv....
I have not seen them mounted with old style brackets. It would probably throw off the alignment. How about finding/making a rubber cover for the stud. I know several style vehicles use a cover over the stud to prevent it form shorting against something
Old 07-27-2008, 05:53 PM   #3
72blazer_mud_bogger
thanks will give it a try when i get back to my blazer
Old 07-27-2008, 07:49 PM   #4
vtblazer
vtblazer's Avatar
The serp set ups have a stationary alt.
Find a way to insulate it, that's about all you can do.
vtblazer is offline   Reply With Quote
Old 07-27-2008, 08:22 PM   #5
Arad68
Trucks N Tranzams
Arad68's Avatar
You can re-clock the alternator. Loosen and remove the screws holding the rear case on. Pull it apart slowly taking care not to disturb the the brushes and turn the case to where you want it. Check out these links for more details.
http://forums.off-road.com/jeepster-...lternator.html
http://www.sytyarchives.com/howto/vi...ir=electronics
http://www.4wheeler.ca/index.php?showtopic=34271
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 07-27-2008, 08:34 PM   #6
72blazer_mud_bogger
now that was a great help thanks i will take a look at it when i get to my truck this weekend
