02-21-2001, 07:13 PM | #1 |
It has started.......
Well, first off, I'd like to thank you all for responding to my first post "why isn't my truck starting?!" well, I traced the problem all the way down to the high quality auto zone unit that I had.....it was "new" and had not been on anything, I took it right out of the box, and bolted it up...well, needless to say, i went back to AZ, and got yet another "new" starter and bolted it up and it spun over....I was quite happy....after discovering I had my distributor in 180 degrees off, and swapped over all my spark plug wires...I got it to start up, and ran it for about 6-7 minutes...while adjusting rockers and such, I went back up today to get some more work done on it....and drove it around the lot a little bit, it feels like it'll be kinda peppy, time will tell....anyways, I have one more question, the vacuum line that goes from my tranny (TH400) to the ???? I've got an edelbrock #1406 600 cfm w/ elec choke on top of the stock cast iron manifold....where do I put this vac. line?? does it go to the front of back of the carb, or what? if I can get all these little things taken care of, I should be driving it by friday....thanks again
------------------ '81 3/4 ton Silverado Warmed up 355 TH400 w/shift kit Corporate 14 bolt w/ 3.73s
94 S10 82 K30 81 C20 80 K20 76 C10 69 C20 68 C10 4 sale 51 3600 |
02-22-2001, 02:15 AM | #2 |
you should have a vacuum port on the manifold behind the carb, that is where it hooks. if not then just hook it to any manifold vacuum sorce. if it is a stock cast iron manifold it should have the port on the manifold or a place you can screw one in. good luck.
------------------ 85 C10 350/700r4 HOLLEY STREET DOMINATOR IANTAKE EDELBROCK 1406 COMP. SERIES CARB. HYPERTECH POWER COIL FACTORY HEADERS MAGNAFLOW CAT/MUFFLER/3in. EXHAUST 3.42 REAR GEARS PROTHANE SUSPENSION-TOTAL KIT and still going "thats my toy" Jeff Dodson Angleton,Tx.
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
02-22-2001, 02:20 AM | #3 |
Truckin' Krazy
The line just runs straight to manifold vaccum, usually to the port coming right out of the manifold behind the carb.
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
