10-12-2008, 10:53 PM | #1 |
Rear bag mounting pics please
I am in the middle of putting in a rear c-notch, cpp trailing arm crossmember and redoning my rear air bag setup. The PO put in really small bags and some really messy blocks/brackets..
My first question is how are you guys mounting your air bags?? When you put in the c-notch are you taking out the rear spring upper plate. Are you mounting the bag to the trailing arm with just one bolt up through the trailing arm.. If you got any pics I would like to see them.. Second I was wondering what bags you guys are running. I was going to get the Doninators, but wasn't sure if they were to big for the front and rear. Thanx. Trevor |
10-12-2008, 11:18 PM | #2 |
Re: Rear bag mounting pics please
here is my 86 with f9000
10-12-2008, 11:34 PM | #3 |
Wow, that is alittle out of my league. I am just putting a c-notch and cpp crossmember.
But, is that ever nice... |
10-13-2008, 12:44 AM | #4 |
It'd be alot cooler if you did
here is what I've got...
10-13-2008, 01:21 AM | #5 |
3DrDwn--the 'burb not the band
Mine on my '72 burb
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
10-13-2008, 09:47 PM | #6 |
Got the c-notch finshed off today... Should of taken some pics, but everybody has see it before..
10-13-2008, 11:15 PM | #7 |
I must say that it is refreshing to see people running the correct bag on the rear in this thread.
10-14-2008, 10:40 AM | #8 |
what would the wrong bag be,I,m going to do mine here soon ,would like to know
10-14-2008, 11:38 AM | #9 |
I'm guessing a dual convoluted bag. Sleeve bags are better for this application, atleast with ride quality in that mounting area. Besides that, I don't know...
10-14-2008, 11:40 AM | #10 |
well every bag pictured here so far is a F9000 "sleeve" bag. The double convolute bag aka firestone 2600lb, Slam specialties RE-7 RE-8, etc. are also popular in rear aplications but many feel they are not ideal. Neither bag is "wrong" just suitable for different apps.
Josh
10-14-2008, 02:54 PM | #11 |
Man u guys have some beautiful rear suspensions!! Its just like art or something. My suspension will not be as elaborate but i can appreciate your work, AWESOME!!
10-14-2008, 03:46 PM | #12 |
Ya, I wish I had to time and $$$ for something like that. But I will just have to keep it simple. I have a hard time getting the simple stuff done. 20 min. here and 20 min. there just ain't cutting it..
10-14-2008, 04:30 PM | #13 | |
10-14-2008, 06:19 PM | #14 |
Progress = 0%
Is this what you are looking for? I have a single bolt through the trailing arm. The upper bags studs go through the notch and frame. The studs were barely long enough to go through the frame and notch (only a couple of threads showing). Not that they are going to fall out, but I'd like to know what others are doing to remedy this situation. My thought was to remove the notch and enlarge the holes in the frame (large enough for a socket the size of the nut to fit through). Then bolt the notch back on, put the nuts on the studs and tighten them down. Then the bag would actually be bolted to the notch only. Make sense?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra Last edited by Slammed67; 10-14-2008 at 06:22 PM. |
10-14-2008, 06:47 PM | #15 | |
Since you already have the Stones, they can be inverted vs. the way you have them installed. This allows for the use of a bolt that gets the correct amount of thread engagement through the c-notch + frame + reinforcement plate. For the trailing arms, 'clock' the bag so the studs straddle the C/L of the trailing arms 2-halves. Drill 3/8" holes for the studs & the larger 1/2" hole for the air fitting. Route the airline so it's not contacting anything & call it done. I had them installed this way in my 68 because of the same issue w/there barely being enough thread to secure the studs through the frame & notch. Slams use bolts on top & bottom so they're more user friendly on these trucks. I'm not sure what newer Stones use these days either.....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-14-2008 at 06:48 PM. |
10-14-2008, 08:39 PM | #16 |
Slammed67, that is exactly the kind of pic I was looking for and I too had the same questions about the studs on the top.
What do you guys think of the Dominators for installing?? Anybody got more pics to help a rookie out.. |
10-14-2008, 09:05 PM | #17 |
10-14-2008, 09:24 PM | #18 |
That's Porterbuilts bolt-in rear 'Dropmember'.
10-14-2008, 09:30 PM | #19 |
slammed67 could you post up some more pics of your setup im also needing some pics
1987 Gmc sierra 1962 Apache 10 |
10-14-2008, 11:08 PM | #20 | |
A guy with a truck
I have the Domintors on my pick-up. Night and day difference in ride vs. Slams and no problems so far. I'd say the Slams are more of a sporty feeling bag vs. the Doms that are more plush. Check out MrShelley's FAQ for good pics on rear bag installs.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-15-2008, 12:24 AM | #21 |
Thanx, I found the air bag install in the FAQ's. I saved most of the pics for future ref.
I think I am going to go with the Doninators. |
10-15-2008, 09:01 AM | #22 | |
Progress = 0%
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
10-15-2008, 09:27 AM | #23 |
how your frame is notched, how low it sits in the back, and what you had to do to leave the stock trailing arms, or did you just pull the coil and put an air bag in there
10-15-2008, 09:38 AM | #24 |
Progress = 0%
I'm in KC so if you'd like to come by and check it out in person, let me know. You can e-mail me at jason (at) jayspot (dot) com.
10-15-2008, 09:44 AM | #25 | |
