Old 02-24-2009, 08:36 PM   #1
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
boxing a frame
so I'm getting ready to start on my '50 project, and am doing some planning. I plan to box at least the front half of the frame, but am not sure what thickness of steel to use. I have a lot of clean 3/16 steel laying around (15 sheets, 30" x 16") that i could use, but that seems to thick.
Should i go get some 1/8"?
IvelDesigns is offline   Reply With Quote
Old 02-24-2009, 08:51 PM   #2
BuiltByBrooks
Argon User
BuiltByBrooks's Avatar
Re: boxing a frame
I would use 1/8, Easier to cut and form....
BuiltByBrooks is offline   Reply With Quote
Old 02-24-2009, 09:22 PM   #3
tds
Re: boxing a frame
if you already have 3/16s IMO dont go buy 1/8.
off topic but do you hit any minnesota shows
1981 - C-10 SCSB
Planning on putting this thing on it's rocker!
tds is offline   Reply With Quote
Old 02-24-2009, 09:22 PM   #4
tds
Re: boxing a frame
1981 - C-10 SCSB
Old 02-24-2009, 09:38 PM   #5
p8ntballer1911
Bodydropped71
p8ntballer1911's Avatar
Re: boxing a frame
Its really up to you. I did all mine with 3/16 i think. All i had then was a cut-off wheel. Now that i have a plasma cutter everything would have been 100x easier.
p8ntballer1911 is offline   Reply With Quote
Old 02-24-2009, 09:57 PM   #6
IvelDesigns
Re: boxing a frame
yeah, that's my situation too. I'm gonna need to buy stock in cut off wheels if i go the 3/16 route.
I haven't made it to any MN shows, but i'm not opposed to it. Got any good ones up that way?
Old 02-24-2009, 10:42 PM   #7
Rigo's 70 C10
Re: boxing a frame
What is boxing a frame, and what purpose does this serve?
Rigo's 70 C10 is offline   Reply With Quote
Old 02-24-2009, 10:49 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: boxing a frame
Most frame rails are C (three sided) channels. Boxing a frame is accomplished by making a filler panel for the fourth side. This makes the frame more rigid, and cleans up the appearance.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-25-2009, 12:48 AM   #9
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: boxing a frame
I would not use 3/16. I used 1/8 on the small section where I boxed mine. Not that expensive... Just consider all the extra weight.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-25-2009, 02:48 AM   #10
abadsvt
abadsvt's Avatar
Re: boxing a frame
As others said. 1/8" is plenty strong and even though you have the 3/16" I still wouldn't use it. Save that for incase you have to make any brackets for the truck and buy some flat stock. Good luck and let us know how it comes out!!!!!!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 02-25-2009, 11:02 AM   #11
Kayotic
Kayotic's Avatar
Re: boxing a frame
See if you can barter, trade the 3/16" for 1/8". You are only planning to do the front half for now anyway.
Plus the extra labor should you ever need to drill or cut through it for elec., plumbing.
I would look for 1/8"
See as a matter of fact if you where close you could do my truck too, help of set the cost you were trying to avoid...
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 02-27-2009, 12:57 PM   #12
Houston54
Re: boxing a frame
I boxed the frame on my 54. It certainly stiffens the ride. Suggest you identify all the through frame connection points for rear cab mounts, bed mounting, rear bumper mounting, etc so you can identify where you need to have access holes.
It goes without saying though to use short welds to keep heat build-up down. Excessive heat will warp the frame.
Houston54 is offline   Reply With Quote
