04-15-2009, 10:58 PM | #1 |
60-66 Nut
Impala SS Rear Disc Brake Brackets
Here is my latest design of the Impala SS rear disc brake brackets. These are laser cut out of 1/4" with 1/4" spacers stitch welded on and then tapped M12 x 1.25 for the caliper cage attachment bolts. These brackets will bolt onto the truck 12 bolt rear differentials from '64-'82 and the 10 bolt truck differentials from '79-'87. The price on these is $115.00 plus a flat rate shipping of $9.20. This pricing is always current and up to date. PayPal is preferred, but I will also accept money orders. The package includes one pair of brackets plus grade 8 fasteners to attach the brackets to the axle tube flange and the metric bolts to attach the caliper cages to the brackets. This setup is for the 5 x 5 bolt pattern.
If you would like a set, post in this thread, send me a PM or send an email to captainfab454@hotmail.com, and I will give you the ordering and payment instructions and current lead time.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 10-08-2021 at 09:42 PM. Reason: Shipping cost increase |
04-15-2009, 11:05 PM | #2 |
Re: Impala SS Rear Disc Brake Brackets
Another nice product
What did the impalas use for e-brakes? will the impala rotor fit the axle with out any modification?
CHEVY ONLY |
04-16-2009, 12:47 AM | #3 |
60-66 Nut
The Impala e-brake was a shoe setup inside the rotor which would be a little difficult to adapt to a 12 bolt truck diff. The Impala rotor fits over the axle flange with nothing more than slightly opening up the center hole to slide over the step on the axle flange. A die grinder and a flap drum will do it is 5 minutes or less.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-16-2009 at 12:48 AM. |
04-16-2009, 07:54 AM | #4 |
I'll take a set. Paypal on the way.
04-16-2009, 02:44 PM | #5 |
Do you use the truck rotor or impala rotor?
04-16-2009, 05:18 PM | #6 |
Formerly- 1972SuperCheyenne
Uses Impala SS or Caprice/Roadmaster rear rotors.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
04-16-2009, 10:38 PM | #7 |
60-66 Nut
I haven't received it yet.....as soon as I do I will send a set out to you. Thanks
Thanks for replying Josh. I see you got yours today, have you put them on yet? I'm not aware of any 5 X 5 truck rotors that would work on the rear.
04-17-2009, 10:40 AM | #8 |
They're on there buddy. Fit and quality is perfect. Couldn't ask for a better product or better service. Thank you.
04-17-2009, 11:52 PM | #9 | |
60-66 Nut
Thanks for the compliment Josh.....and for the purchase too
04-18-2009, 01:24 AM | #10 |
If you have spares put me down for a set. Do you have the part numbers for the brake set-up?
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
04-18-2009, 01:30 AM | #11 |
hey cap... do you also make them for the ten bolt rearends?
04-18-2009, 01:53 AM | #12 |
payment sent. Cant wait to see how this app. fits and look on my truck. My brother might want a set too so Ill let you know.
04-18-2009, 11:03 PM | #13 |
60-66 Nut
What year of 10 bolt? Are you referring to a 8.5 truck 10 bolt? If so I'm pretty sure the ddistance from the axle tube flange to the axle flange is the same as a 12 bolt. So they should work but I would need to verify that, unless someone here can.
I'm working on putting together a list of parts and part numbers. You basically need rotors, calipers, factory caliper brackets, pads, and hoses for a '95 Impala SS. You will also need a brake line adapter to go from metric to SAE.
04-23-2009, 08:35 PM | #14 |
What do you recommend for the prop valve when adding the Impala rear discs?
04-23-2009, 11:09 PM | #15 | |
60-66 Nut
With that said,as for the Impala rear brake conversion, I think I might recommend seriously looking at the components that GM used on the Impala for a start. Although the weight bias of a pickup is likely to be a bit different than an Impala. Also the weight bias from one pickup to another will be different in how the truck was built. This is mainly why I believe an adjustable proportion valve is beneficial to the brake system. BTW Scot, how did that booster bracket work out for you?
04-24-2009, 12:00 AM | #16 |
It looks great . . ... sitting on a shelf full of parts (Vette MC, Malibu booster, Porterbuilt Dropmember, 350/700R4, van tilt, blah, blah. blah.... Also should have a couple of steelies on the way .
The parts are waiting to come together but I've gotten behind on building the frame for my retroRod project so everything else is delayed as well. Should make for a busy summer. There will be a thread w/details soon.
05-03-2009, 09:15 AM | #17 |
Hello Captinfab,
what did the impala use for an e-brake? is everyone using a rear disc with out an e-brake? chas
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
05-03-2009, 11:02 PM | #18 |
60-66 Nut
The Impala SS used a shoe setup inside the rotor for an e-brake. So using These brackets on your truck won't give you an e-brake. If you need to have an e-brake, you'll have to buy the Camaro caliper brackets that glock35ipsc is making. Thanks for inquiring.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-03-2009 at 11:04 PM. |
05-07-2009, 10:54 PM | #19 |
What front set up matches the ss caliper?
05-07-2009, 11:38 PM | #20 | |
60-66 Nut
[quote=Dahawk;3299044]
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-07-2009 at 11:41 PM. |
06-24-2009, 10:34 PM | #21 |
60-66 Nut
I have one set of these brackets left......I'll throw in a pair of Metric to SAE line adapters for free with this last set.
06-30-2009, 03:41 PM | #22 |
Hay Team!!
Capt....please check your PM's as I am interested.
I'm also curious to know what the diameter of the impala rotor is? Can you get me a measurement from the center of the axle to the highest point on the caliper? My wheel has a 7 inch backspacing so fitment is going to be close depending on the dimensions. Thanks in advance
1972 Chevrolet Cheyenne LWB "Orange and White" 8) |
06-30-2009, 04:32 PM | #23 |
06-30-2009, 11:24 PM | #24 | ||
60-66 Nut
07-01-2009, 03:44 AM | #25 |
hey captinfab
just so you know i would like to buy two sets thats not a problem. let me know either way |
