Old 08-20-2009, 01:35 AM   #1
Hart_Rod
Hart_Rod's Avatar
68 S/C update.....
** UPDATE: In the process of updating the motor/tranny to a 6.2/6L80/TVS1900 Magnacharger/ShrifterSix Paddle Shifters/Dakota Digital VHX gauges and Vintage Air! **
LS updates start here: http://67-72chevytrucks.com/vboard/s...358692&page=17
*************TRUCK INFORMATION*****************
Wheel info:
Billet Specialties Vintec Dish wheels
Fronts: 18x8, 5" BS, Mickey Thompson 28-10 M/T SR
Rears: 20x12, 7" BS, Mickey Thompson 31-16 M/T SR
Parts:
Grille filler panels: http://www.nwautofab.com/index.html
Radiator cover: http://www.hotroddynamics.com/shop/v...p?productid=30
I purchased this truck back in June after boardmember SEETEN started a thread about an Ebay AD that peaked my interest.
I had been looking for a nice SWB 68 truck to be my "daily driver" while I'm finishing up a few other projects and this one met 90% of the criteria that I was looking for in a truck.
The first few pictures are of the truck when I first purchased it. It is an extremely solid, minimal rust, original paint truck. It came with a sweet 630 TQ/622 HP 383 Stroker motor with a Vortech Supercharger, Sid Neal TH350 and a 3.08 posi. While the motor/tranny seemed to be bullet proof, the suspension was not...... It had the original suspension that the previous owner cut and heated the coils to lower it. The ride was terrible and it felt unsafe when you would hit any bumps. So the suspension was the first thing that I tackled. It also had a fuel cell and battery mounted in the bed, This along with some super wide tubs, pretty much rendered the bed useless. So battery and tank will be removed and placed in their proper location, . Here's a list of updates that I have completed and some of the other stuff I plan on updating.
Exterior:
New front/rear bumpers - Done
New halogen headlights - Done
New LED tail lights - Done
Repaint emblems - Done
New "Custom" door emblems - Done
Installed factory mirrors - Done
New front and rear CST side marker lights with bulbs – Done
Remove battery from bed and put back under the hood - Done
Remove fuel cell from bed - Done!
Install under bed FuelCellGuy 18 gal fuel tank - Done!
Side marker light fuel filler: http://67-72chevytrucks.com/vboard/s...er+fuel+filler
UPDATE: Installed a Boyds tank with Aeromotive A1000 intank pump
Sandblast the inside of the bed and do a spray in liner = Done!
Install a super trick fuel filler/door - Done
Install stainless steel vent shades - Done
New Billet Specialties Vintec Dish wheels with three prong spinners!
Fronts: 18x8, 5" BS, 28-10 M/T SR
Rears: 20x12, 7" BS, 31-16 M/T SR
Front suspension:
Install CPP tubular front a-arms - Done
Install Front 1 1/4" sway bar with poly bushings and lowered brackets - Done
Install Eibach 2" drop springs - Done
Install Porterbuilt front shock relocators with new KYB lowered shocks – Done
Install CPP 13" rotors/powder coated dual piston calipers/2" modular spindles)[/B]
Install new rubber cab mounts – Done
Rear suspension:
Install Porterbuilt 3" dropped tubular trailing arms – Done
Install ECE 5" drop springs – Done
Install Porterbuilt shock relocators – Done
Install Porterbuilt track bar – Done
Install KYB lowered shocks – Done
Install CPP bolt in notch Done
Completely rebuild 68 rear end with : Yukon 4.11 gears, Moser axels, Eaton posi, new bearings and 12"CPP powdercoated disc brakes, . Done
Interior:
Dakota Digital VHX Gauges - Done
Install new 3 Point seatbelts - Done
Remove B&M shifter - Done
Install factory tilt column with shifter - Done
Lokar tranny selector rod - Done
New Billet Specialties steering wheel - Done
UPDATE: Installed ShrifterSix paddle shifters to controle 6L80 tranny.
Install Pioneer 6x9 speakers and RetroSound stereoo - Done
Recover and install factory buddy buckets - Done!
New arm rests - Done!
New Visors - Done!
New Dash pad - Done
Custom cup holder - Done
Install 72 cable gas pedal (LOKAR) - Done
Install new rubber floor mat (double FatMat insulation) - Done!
Motor:
*** UPDATE: Installing of a 2013 Camaro SS 6.2L/6L80E along a TVS1900 Magnacharger.... ***
http://67-72chevytrucks.com/vboard/s...d.php?t=370973
Installed B&M Line lock that is activated by the horn,
Installed new ProMaster High torque starter - Done!
New plugs - Done!
Rewired electric fan and fuel pump (again!) - Done!
Install power steering - Done!
Lokar throttle and kickdown cables - Done!
Install blow-off valve - Done!
New radiator with dual electric fans - Done!
Custom radiator cover - Done!
http://www.hotroddynamics.com/shop/v...php?groupid=11
Re-do fuel system:
Install new Aeromotive fuel pump (with pre and post filters) - Done!
Install Aeromotive boost adjusted FPR - Done!
Build custom fuel cell - - Done!
Doug Throley 1 7/8" mid length headers - Done!
Flowmasters (50 series) - Done!
UPDATE: Installed new Magnaflows
QTP Electric cutouts - Done!
Hart_Rod is offline   Reply With Quote
Old 08-20-2009, 01:36 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: 68 S/C update.....
cab mounts
Old 08-20-2009, 01:36 AM   #3
Hart_Rod
Hart_Rod's Avatar
Front suspension: The front coils were cut and the truck was basically riding on the bumpstops. To top it off it sat about an 1" lower on the passengers side. So, I decided to go with Eibach 2" dropped springs to get a solid reference point. It definitely sits higher now than it did before but at least I have a good reference point. I will probably go with a 2 or 2 1/2" dropped spindle later on but I want to see how the springs settle first. I also added a 1 1/16th sway bar with poly bushings and lowered mounts. The ride is 1000% better!!!!! Here are a few pictures....
Old 08-20-2009, 01:37 AM   #4
Hart_Rod
Hart_Rod's Avatar
The rear suspension, just like the front, consisted of a lot 41 year old OEM parts, including original bushings in the trailing arms and the pan hard bar. A set of dropped springs were added, but apparently they weren't low enough, so PO heated them up with a torch ......Nice work ehhhh. Anyone want a slightly used, slightly modified set of of drop springs? It took about 4 hours to pull everything out and prep it for the new stuff. The neatly tucked up full exhaust didn't make the process any easier......
Old 08-20-2009, 01:37 AM   #5
Hart_Rod
Hart_Rod's Avatar
Rear suspension part deux!
Old 08-20-2009, 01:38 AM   #6
Hart_Rod
Hart_Rod's Avatar
fuel tank and battery
Old 08-20-2009, 01:38 AM   #7
Hart_Rod
Hart_Rod's Avatar
Interior:
I installed a rebuilt tilt column from KevsClassics, (nice product). Apparently the PO didn't cut any wires because the backup lights and the neutral safety switch still work, . While doing the column, I put in a LOKAR tranny selector kit. That was pretty straight forward as nothing was in the way. I also put in a stereo I picked up on the board. Anyone got any cassettes I can borrow??? While I had the column out, I cleaned up a bunch of wires under the dash. No major damage, just a bunch of spaghetti from all the additional gauges and MSD setup.
Old 08-20-2009, 01:39 AM   #8
Hart_Rod
Hart_Rod's Avatar
Interior:
Old 08-20-2009, 01:39 AM   #9
Hart_Rod
Hart_Rod's Avatar
Burnouts!!!!
Old 08-20-2009, 08:08 AM   #10
gcburdic
Restoration Virgin!
gcburdic's Avatar
In.....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 08-20-2009, 08:20 AM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Subscribed...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-20-2009, 10:45 AM   #12
bigguy69
dazed and confused
bigguy69's Avatar
x2
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 08-20-2009, 11:16 AM   #13
VA72C10
VA72C10
VA72C10's Avatar
Will be following this...
Old 08-20-2009, 01:33 PM   #14
my67chevytruck
Under Construction
my67chevytruck's Avatar
time to get busy Rob!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 08-20-2009, 01:55 PM   #15
PipsC10
PipsC10's Avatar
subscribed
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 08-20-2009, 04:55 PM   #16
Hart_Rod
Hart_Rod's Avatar
Front suspension updated.....
Old 08-20-2009, 06:07 PM   #17
lolife99
67-72 parts collector,…
lolife99's Avatar
subscribing also,...
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 08-20-2009, 07:25 PM   #18
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
OOOOOO Count me in!!!!!!
stealthy '69 is offline   Reply With Quote
Old 08-20-2009, 07:35 PM   #19
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
wth count me in too even though it looks like we ran out of pics..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-20-2009, 10:07 PM   #20
68 short step
nice progress....i do believe, those rear springs were shot.
68 short step is offline   Reply With Quote
Old 08-21-2009, 07:43 AM   #21
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Burnouts, need more burnouts!!
ChuckDriver is offline   Reply With Quote
Old 08-22-2009, 12:28 PM   #22
big_al_71
big_al_71's Avatar
Ok Rob go ahead and finish my truck and I mean this one!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-22-2009, 01:01 PM   #23
Hart_Rod
Hart_Rod's Avatar
Retro, old school or new school......
Old 08-22-2009, 01:49 PM   #24
VA72C10
VA72C10
VA72C10's Avatar
I actually like the retro...but I saw a picture with rally wheels with no caps that I actually think looked the best on that truck. It's funny because on 99.99999999999999% of other trucks I'd go with the new school choice....your truck just begs for something different
this picture is the one I was referring to.....with matching rally in the front though....
Old 08-23-2009, 03:48 PM   #25
1sik52
I thought the wheels wouldnt go on?
1sik52 is offline   Reply With Quote
