Old 07-04-2009, 02:44 AM   #101
highperf4x4
Re: Project 7deuce
Now that sounds like fun!
highperf4x4 is offline   Reply With Quote
Old 07-08-2009, 11:21 PM   #102
71'tahoe
71'tahoe's Avatar
Re: Project 7deuce
I just reread pages 3,4,5 and see that you just clearenced the frame and u-bolts? You dont have to run a rack with the notched x member? I have read several threads on this mod but never seen one completed. I have been thinking about doing a notched x member but want to see if you can run a box or a rack. thanks for any help.
71'tahoe is offline   Reply With Quote
Old 07-08-2009, 11:43 PM   #103
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Project 7deuce
So far its good but I have not driven it yet...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-09-2009, 01:28 AM   #104
highperf4x4
Re: Project 7deuce
Well................... when are ya gonna drive it?
Old 08-22-2009, 10:57 PM   #105
mcbassin
Still Learning
mcbassin's Avatar
Re: Project 7deuce
Cool project! Looks like you have some serious hours tied up in it. I was curious about the cross member mod too. I have seen a lot of members installing the P/B members similar. What does this do for you? Just lower the suspension that much more? Although, I think this style looks good, I really haven't gotten on board with all the bags and lowering stuff yet. I had a 67 short step bed that always looked like there was too much gap between the tires and the fenders.(it needed to be lowered a few inches).
I didn't even know this lowering gear existed for trucks until I ran into this site a few months back.I thought that was only for the impalas and montes out in Cali....... Keep going with your project!
Old 08-23-2009, 09:55 AM   #106
Frizzle Fry
Frizzle Fry's Avatar
Re: Project 7deuce
What's your plan for the exhaust? I see you made exhaust cut-outs in the TA xmember and flipped the TA brackets. On the Tahoe I found that the brackets need to be down (not flipped) in order to get the exhaust up/over the TA's. Otherwise you are going to have to hang it below the TA's to get further back. That's with 3" pipes; smaller might make it.
Frizzle Fry is offline   Reply With Quote
Old 09-07-2009, 10:30 AM   #107
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
So far I can run the box the only place it seems to hit is aired out the pitman arm stud runs into the lower a arm? I need to finish the front but have just been out of motivation for the project..
MEMBER #6377
Project "7DEUCE"
Old 09-07-2009, 10:35 AM   #108
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
Not sure when im gonna drive havein to much fun drivin the 56 now that its on the road... mIke as far as the rear crossmember I am at a standstill i am almost thinking I may just cut it all off and 4 link it as with the trailing arms I just cannot get down as low as the front. Also with the trailing arms and the b.b. and the headders im running id almost have to run the mufflers behind the rear axle and then the runs into wheres the fuel cell gonna go? Id like the bed to be finished with wood and not all hacked up looking.. Also on second thought I could just ditch the center crossmember and truck arms and link it from there? any ideas on this one mike cause im sure that as soon as the 56 is able to be out side all night im sure my 72 is going down to bare frame...
MEMBER #6377
Project "7DEUCE"
Old 09-07-2009, 11:00 AM   #109
71'tahoe
71'tahoe's Avatar
Re: Project 7deuce
Nice truck!! Thanks for the info on the steering!
Old 09-07-2009, 12:11 PM   #110
highperf4x4
Re: Project 7deuce
Cool, I like it. That's one of my favorite body styles.
Old 09-08-2009, 01:18 AM   #111
Frizzle Fry
Re: Project 7deuce
love the 55-57's
On the rear susp, you will need a big notch to get the rear as low as the front regardless of what the axle hangs from. I like the truck arms with bags and blocks, but I don't want to lay frame. I recommend spending some time reading up on the various options and their pros/cons over in the suspension section.
Old 09-08-2009, 07:42 PM   #112
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
Im not much for the frame or rockers being on the ground id just like to be close...
MEMBER #6377
Project "7DEUCE"
Old 11-23-2009, 09:53 AM   #113
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
Well I have been driving the hell out of the 56 but now that winter is here im back on the 72........
MEMBER #6377
Project "7DEUCE"
Old 11-23-2009, 09:56 AM   #114
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
Got the forward tilt hood done and she works great. One person can open and close the hood with no issues....
MEMBER #6377
Project "7DEUCE"
Old 11-23-2009, 10:11 AM   #115
VA72C10
VA72C10
VA72C10's Avatar
Re: Project 7deuce
Nicely done. I really like the forward tilt hoods.
Old 11-23-2009, 09:20 PM   #116
highperf4x4
Re: Project 7deuce
Right on!
You got a better pic of that K-5?
Old 11-24-2009, 12:11 AM   #117
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
Heres a few k-5 shots........
MEMBER #6377
Project "7DEUCE"
Old 11-24-2009, 12:25 AM   #118
Puropedo
Re: Project 7deuce
Man..... you got some really nice rides!..... You have great taste
Puropedo is offline   Reply With Quote
Old 11-24-2009, 03:02 AM   #119
highperf4x4
Re: Project 7deuce
Sweet
Old 11-24-2009, 05:43 AM   #120
vegaschevy
Re: Project 7deuce
I am doing a dropmember truck as one of my next few trucks. I want a nice 4x4 and I want an air ride frame dragging truck!!!!
vegaschevy is offline   Reply With Quote
Old 11-24-2009, 09:37 AM   #121
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
I just bought paint yesterday.......getting closer...
MEMBER #6377
Project "7DEUCE"
Old 11-24-2009, 10:15 AM   #122
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Project 7deuce
waiting on paint progress!... Truck is coming along good. It seems as though you have too many vehicles, why dont you send the '56 my way for awhile......
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-24-2009, 01:13 PM   #123
Ricks' 72C10
Going Down?
Ricks' 72C10's Avatar
Re: Project 7deuce
Mee Too!! Looks Good!!
But do you mind sharing how you did the hood hinges? I looked back in the thread and couldn't find and detail on them.
Thanks!
Just another day in Paradise
Rebuild thread
http://67-72chevytrucks.com/vboard/s...d.php?t=354512
Ricks' 72C10 is offline   Reply With Quote
Old 11-24-2009, 01:37 PM   #124
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
I actually used kevins how to guide I dont have the link but a quick board search brings it up.
MEMBER #6377
Project "7DEUCE"
Old 11-24-2009, 04:48 PM   #125
Ricks' 72C10
Going Down?
Re: Project 7deuce
I think this is the one you are referring to:
http://67-72chevytrucks.com/vboard/s...lt+hood+hinges
I read through it and my head still hurts. Did you really do that buick la sabre salvage yard thing?
Thanks for the info
Rebuild thread
