07-17-2013, 08:42 AM | #1 |
Re: Boyd Welding-67-72 Rear Mount Aluminum Tank
Sorry we don't carry the regulators. The side fill is intended to fit between the frame and bed. There are no notches required.
Dave Boyd View Our 63-72 C10 Tank options https://fueltankparts.com/collections/63-72-c10-tanks Boyd Welding Main Site : http://www.boydwelding.com/ Boyd Online Shop: https://fueltankparts.com/ E: Sales@boydwelding.com |
07-17-2013, 08:48 AM | #2 |
Vintage Evil
07-17-2013, 09:29 AM | #3 |
Vintage Evil
07-17-2013, 10:08 AM | #4 | |
Dave, I had to notch my frame rail for the filler neck to clear. The tank is mounted directly to the bottom of the frame. Did you guys change this or did I get a tank with a short neck? There is no way my tank filler neck would clear the frame. I can take some measurements when I get home later if that helps. Here are a few pics to show what I had to do. The notch plate is trimmed and welded in now but dont have a pic with the tank back in it. I am not complaining here, I love the tank but it was quite a surprise to find the filler neck would not clear. This is on my 67 C10 swb.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
07-18-2013, 08:42 AM | #5 | |
If you refer to Page 30 post #730 you will see this frame accepted the side fill without any issues. If you look at Page 28 post #682 you will see this frame would not accept it on the bottom of the frame rail. He also noted that his frame was a 4x4 Is your frame a 4x4?
07-18-2013, 10:18 AM | #6 | |
Details from your website: Details Frequently Asked Questions: Q: How Far down are the mounting tabs? A: 3" down from the top of the tank Q: How Tall is the fill neck? What is the Diameter of the pipe? A: The fill neck is approx 3" tall. The pipe is 2" OD Q: Are there Baffles in the Tank? A: Yes, There are 3 baffles in the tank. Q: What is the Roll Over Safety Vent? Do i need it? A: The Rollover Safety Vent is a simple ball check valve device that will allow the tank to vent when in the normal operating position. In the event of an accident causing a rollover the ball will drop and block off the vent port so that fuel does not leak out. For safety I would always recommend purchasing the Rollover Safety vent option.. Thanks Dave, I see post 730 looks like it is higher than mine, post 682 is a local guy "Crash" and I follow his build. His truck was originally a long bed and cut down to SWB so that may be part of the reason, thinking the frame is taller as it goes forward toward the cab? I think maybe a cab swap also. A lot of unknowns there and of course there were many variations in these trucks. My truck has matching Vin/Spid/partial frame Vin. It is an original 67 SWB V8 283 3ott. I measured the frame rail where the tank attaches and it measure 4.25" The tank flange mount surface to top of tank 3" (just as your specs above show) The filler neck (bottom) is 1" from the top of tank, the filler neck top is 3" above the top of the tank. Tank mounting 3" + filler bottom height 1"= 4" where the frame is 4.25" so the bottom edge of the filler neck is .25" below the top of the frame rail. I decided I needed .75" notch to give clearance for the filler hose.
07-17-2013, 10:09 AM | #7 |
Pics only load one at a time...
Pic #2
07-17-2013, 10:10 AM | #8 |
pic #3 - the notch.
EFI stealth, side fill is the tank version.
07-17-2013, 01:01 PM | #9 |
Tank ordered !!!!
Eric 1967 C10 Small Window - LWB http://67-72chevytrucks.com/vboard/s...d.php?t=657509 2004 Silverado 2500HD - Turbo Diesel 603 rwhp / 1090 rwtq 2016 Camaro SS - Satin Pearl Nero wrap My 2010 Camaro SS Magazine feature (SOLD) http://www.superchevy.com/features/g...of-perfection/ |
07-17-2013, 02:06 PM | #10 |
68 C 10
Just placed a order with Travis for a center fill.
Thanks Kevin
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
07-17-2013, 06:25 PM | #11 |
Got one on order...Thanks for the group buy
07-17-2013, 11:44 PM | #12 |
Tank ordered! Thanks Dave!
07-18-2013, 12:29 AM | #13 |
Dave, dont forget to add the a1000 bed fill to the listing on your site to make it an option
07-18-2013, 12:41 AM | #14 | |
VA72C10
http://www.boydwelding.com/shop/inde...7-72-c-10.html
Looking for a 67-72 swb or blazer project in or around VA. |
07-18-2013, 09:03 AM | #15 | |
07-18-2013, 10:03 AM | #16 |
The A1000 pic is bed fill but when you click add to cart you have the option to choose side fill or bed fill
07-18-2013, 10:10 AM | #17 |
07-18-2013, 01:17 PM | #18 |
thanks for providing support. I think (Bed Fill) in the title was a little misleading so i just deleted them from the title.
07-18-2013, 08:52 PM | #19 |
thanks, just ordered!
07-18-2013, 11:46 PM | #20 |
Thanks! Just placed my order.
1967 Chevy SWB 1972 Chevy SWB 1972 Chevy SWB K20 4x4 1991 Ford F-150 2013 Dodge Ram 1500 4x4 |
07-20-2013, 06:23 PM | #21 |
Ordered through the group Buy on Monday, Friday it arrived. Standard bed fill with rollover vent and sending unit. Nice clean well made product was very easy to install after removing the small diagonal brace. Nice to see a good product without creating additional hiccups.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
07-20-2013, 10:15 PM | #22 |
A day late and $1 short...
I received my UPS notification yesterday, it'll be here Tuesday.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
07-22-2013, 06:49 AM | #23 |
mine will be here tuesday also
07-22-2013, 07:59 AM | #24 |
Dave, I expect to receive my tank today or tomorrow. One question before I fill it with fuel, have you had or heard of any instances of Ethanol fuel causing corrosion inside the tank? If so, is there any preventive measures that should be taken? I do have access locally to non-Ethanol fuel, but you never know when travelling.
BTW, thanks for the Group Buy!
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
07-22-2013, 04:15 PM | #25 |
Did the group buy end? I'm ready to order! Hope I didn't miss it.
Posted via Mobile Device Last edited by ~Whitey~; 07-22-2013 at 04:34 PM. |
Tags |
67-72 truck, aluminum tank, boydwelding.com, fuel tank, tank relocation |
