12-09-2009, 04:30 PM | #1 |
The Few, The Proud
Need some help...brake hose measurements
I need to order a set of brake hoses for my '69 K10 with a 4" lift. I swapped in '72 axles so I currently have disc brakes up front with drum brakes out back still. I took a rough meaurement from the back of my calipers to the hole in the frame where they mount and came up with 24". How much "extra" brake hose do I need for suspension travel? Anyone out there with the same lift specs that can get some measurements for me?
Thanks.
Shannon |
12-09-2009, 04:48 PM | #2 | |
Re: Need some help...brake hose measurements
12-09-2009, 05:13 PM | #3 |
The Few, The Proud
Thank you Sir. I'm talking with ORD about their hoses and they told me that a 24" hose came in their extended hose kit for trucks with a 4" lift, which of course isn't long enough for me. He then told me that they have 29" or 33" hoses as well. I'm thinking the 33" hose would work but I don't want to end up with too much slop in the hoses.
Shannon |
12-09-2009, 05:32 PM | #4 |
to much slop in your hose could be bad ya know... (snickering like a 13 yr old!)
I don't think that your suspension will drop that much would it? I guess if you crossed a ditch and the driver side jammed up tight then the pass side would flex longer, but not a lot with leaf springs...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
12-09-2009, 09:35 PM | #5 | |
The Few, The Proud
Here are a couple of pictures showing what I have now. Front end, granted this is a straight line but it's 22-23" from the caliper to the frame mounting point. Rear end from top of the axle to the rear mount.
Shannon |
12-10-2009, 06:56 AM | #6 |
Sb 400 club
hmm. I have a 77 so it is probably different but i am running ORD's 4 inch lift extended brake lines and have plenty of slack in front. When i got them i thought they looked alittle short but on my truck they are perfect.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
12-10-2009, 09:11 AM | #7 |
The Few, The Proud
I guess I need to talk to ORD again and confirm what I was told. I've been emailing one of their techs about this and his response below is why I measured my frame to start with. Like everyone else I want to order the right part the first time. I'll forward the pictures above to them today and see what they suggest.
"The fronts are 25", and the rear is 18". We have longer kits if you need them. We have not recieved UPS yet today, but as of now we have not recieved them." Jon Snow Offroad Design 484 C.R. 113 Carbondale CO 81623 970-945-7777 Thanks for the help.
Shannon |
12-10-2009, 11:12 AM | #8 |
The Few, The Proud
Did you ever have time to take some measurements?
Shannon |
12-10-2009, 02:21 PM | #9 |
Yes, 27".I used the top hole in the frame, and got rid of the 'L' bracket the PO used
BTW, great looking build ya got going, nice work Sorry the first pic is fuzzy, to much caffeine
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-10-2009 at 02:22 PM. |
12-10-2009, 03:10 PM | #10 |
The Few, The Proud
Thank you Sir. That's what I needed to know and the pictures are a great help as well.
Shannon |
