Old 02-16-2010, 01:46 PM   #176
smokedat
smokedat's Avatar
Re: LS1 into a 73 cheyenne
Originally Posted by glock35ipsc View Post
I love that color! This is what I was going to paint my 68. I even had a little design figured out that I was going to have airbrushed on a lower corner of the tailgate...... an orange that was split open at the top, with a mushroom cloud coming out of it.
so wut color did you end up painting youre 68? I like that blown up orange idea
smokedat is offline   Reply With Quote
Old 02-16-2010, 01:50 PM   #177
smokedat
smokedat's Avatar
Originally Posted by 68 TT View Post
Do you have a part number for that Griffin radiator?
Yes sir its 6-573AR-JAX. You might want to call and specify exactly what you want. Phone: (864) 845-5000
Old 02-16-2010, 04:28 PM   #178
bigarmzz
bigarmzz's Avatar
wow
i just now came across this thread.....wow
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 02-16-2010, 06:07 PM   #179
smokedat
smokedat's Avatar
Originally Posted by 3r!c84 View Post
what paint did you use on the frame?
Its Ellis Hy-Lux one stage,with wet look hardner added. It sprays really thick eaven when reduced a bit extra, so it will go along ways ended up using about 1/3 of 1 gallon. Sorry for the low- res picture it was taken with my phone.
Old 02-17-2010, 05:25 PM   #180
silvereagle07
silvereagle07's Avatar
smokedat, the engine looks awesome but the cab and frame are even better. NICCCCCE!
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-17-2010, 06:03 PM   #181
smokedat
smokedat's Avatar
Thanks for the compliments, will also color match the rally wheels.
Old 02-17-2010, 06:05 PM   #182
smokedat
smokedat's Avatar
Check out my new avatar
Old 03-09-2010, 11:03 PM   #183
smokedat
smokedat's Avatar
Update, I started to gather some of the paint supplys I got the clear 2 gallons of Dupont Imron, yes the stuff that got outlawed in Cali. Game plan I will start by removing the front clip to get to the old 350 pulling it out, strip interior, remove cab and bed, clean the frame, paint the frame, then work on the exterior body bringing it down to bare metal, tubbing the rear drop in a Ford 9", install 4 link, paint exterior, then finally drop the LS, wire the new set up, run new wet lines, list goes on and on...This swap has been past due as I was suppose to move on Feb, but escrow got delayed, so i will start the swap after i move hopefully by the end of this month.
Old 03-10-2010, 02:17 PM   #184
justpball
justpball's Avatar
I had a supra back in the day that i painted that color...very nice color!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 03-21-2010, 08:36 PM   #185
smokedat
smokedat's Avatar
This is my body and paint material,
Old 03-21-2010, 08:37 PM   #186
smokedat
smokedat's Avatar
Dupont Imron 500S Clear
Old 03-21-2010, 08:39 PM   #187
smokedat
smokedat's Avatar
Old 03-21-2010, 08:41 PM   #188
smokedat
smokedat's Avatar
Old 03-21-2010, 08:42 PM   #189
smokedat
smokedat's Avatar
Old 03-21-2010, 08:45 PM   #190
smokedat
smokedat's Avatar
I will be fabricating custom aluminum accesories for interior
Old 03-21-2010, 08:46 PM   #191
smokedat
smokedat's Avatar
sterring wheel and honker
Old 03-21-2010, 08:48 PM   #192
smokedat
smokedat's Avatar
Will fabricate a dash panel for my gauges and the trim piece for the dash
Old 03-21-2010, 08:50 PM   #193
smokedat
smokedat's Avatar
Pedals that I fabricated still need to be cut drilled and pilished
Old 03-21-2010, 08:51 PM   #194
smokedat
smokedat's Avatar
fabriceted this catch can still in progress but heres a pic
Old 03-21-2010, 09:29 PM   #195
Gemp
Gemp's Avatar
Nice build.......and pics
06' GMC 1500 Crew cab.....
Gemp is offline   Reply With Quote
Old 03-21-2010, 11:04 PM   #196
qu1cks1lver56
qu1cks1lver56's Avatar
im interested in seeing how those pedals turn out.
qu1cks1lver56 is offline   Reply With Quote
Old 03-22-2010, 11:32 AM   #197
Jonboy
Slots go on anything!
Man I miss the old school IMRON. The switch to the low VOC IMRON 5000 was a beating back when it come out in the mid 90's. You almost couldn't make it dry. The IMRON 6000 low VOC base/clear had an awesome cross linking clear (99S, IIRC) that flowed like glass, and fast, too. I think they outlawed that everywhere, though.
The only bad thing you will find with the IMRON is that it is like sanding a rock if you have to go back and color sand it.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 03-23-2010, 12:34 AM   #198
smokedat
smokedat's Avatar
Yeah this product was outlawed in Cali the VOC limit is 2.8 this stuff at 3:1 has a VOC of 5.0
Old 03-23-2010, 12:35 AM   #199
smokedat
smokedat's Avatar
I will post pictures once their complete
Old 03-23-2010, 04:30 AM   #200
qu1cks1lver56
great
73c10, c10, cheyenne, ls1, swap
