Drag Racing
I've decided to get into this a little and found out what class I will fit into, but I'd like to get some things figured out. I'm running a healthy 355 in a 3/4ton long box.
-Weight How much does your pickup weigh? I tipped the scales at 4350lbs with me in it. -Cam I've narrowed down my choices to two and want input. Comp cams 275DEH or the XE274H. I have heads that will take more than this, but I'd still like to be able to drive it on the streets. -Torque converter I was looking at a 2500 stall for either one, but want to know if it might be a little low. What are the effects of having to high of a stall? -Tires What would be a good set of tires to put on that are decent on the street and strip? -The final question is Nitrous Would you do it or not? I was considering a 100 or 150 shot if I do it. Thats all for now and thanks for your input in advance. Thomas Last edited by sav300; 04-20-2010 at 09:26 PM. |
Re: Drag Racing
what class are you going to run in? sportsman, pro..? I think if your running NOS, NHRA says you run pro or superpro can't remember. also what trans, rearend and gear ratio are you running?
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
Re: Drag Racing
think you could still run dot as long as your tires are dot then move up as your times improve and add goodies
#4 | |
mini truck racer
Re: Drag Racing
If it were me , i would start out with a set of drag radials and run in a foot brake no electronic class with the tow rig while i was looking for a half ton to build a race truck out of . JMO .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Re: Drag Racing
I was consider going with a hydraulic roller. Alot of flat tappet cams have been going bad lately due to not enough ZDDP in oils. JMO.
Shawn
Shawn 85 SWB 7.39 @ 93 Best so far with 0 tuning Lesson in life: Never fry bacon naked! |
Re: Drag Racing
shawnt, i see that you are currently in iraq, thanks for serving
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 Last edited by 69trk; 04-21-2010 at 09:43 PM. |
Re: Drag Racing
I have a rebuilt TH350 and 4.56 gears inside an HO52. I fall into the unlimited street class.
