04-26-2010, 12:05 AM | #26 |
Squarebody Aficionado
Re: subwoofer boxes
Shouldnt i have enough space to mount a box on each side and still have space to mount the amp in the middle? I wonder why did they move this to the audio forum, if i am specifically looking for a box for a 73-87.
04-26-2010, 03:21 AM | #27 |
>130dB Moderator
Re: subwoofer boxes
You will have enough room to mount the amp in the center, I was just offering my own personal recommendation.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
04-26-2010, 06:35 AM | #28 |
Badass
Re: subwoofer boxes
i like the amp under the seat idea better.well thats what i did..
gives you the extra room to make the box bigger
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
04-26-2010, 08:25 AM | #29 |
Re: subwoofer boxes
You guys are right, I think it might be better but I think those subs don't need that much air space do they? Do you know if they work like a regular sub that if you give them the max air space they require will make them play a little harder and handle more power? The amp I have for them is a kicker kx 1200.1 so I have the power to give them but another reason I wanted to mount it between the subs to give it an all kicker look, the subs matching the amps.
04-26-2010, 10:30 PM | #30 |
Old member
Re: subwoofer boxes
Here is what I did.
Had to move the amp down to the bottom so the seat would go all the way back.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
05-03-2010, 10:22 AM | #31 |
Re: subwoofer boxes
i have a pair of rockford punch power eights, they have a bigger mounting depth than most 12s and i fit two subs and two amps behind my seat.
67 short bed stepside tach tilt buddy buckets bagged sittin on 20s and 4w disc brakes (not quite finnished) |
07-21-2010, 06:36 PM | #32 |
ROCK*STAR
Re: subwoofer boxes
11-15-2010, 03:45 PM | #33 | |
Re: subwoofer boxes
you install looks good! How did you mount the bottom black speaker? I dont see any mounting holes!
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
11-16-2010, 09:19 PM | #34 |
Parts and more parts
Re: subwoofer boxes
The bottom speakers are 8" midbass units mounted into a fixture made of medite wood. The carpeted part going to the back of the back end of the door is a1/4" thick piece that copies the factory trim carpeted pieces. To that piece, I glued 3/4" thick medite pieces stacked together to make the full speaker housing form. The pieces that are glued together are hollowed out to give the room for the speaker and airspace to function. The speaker is also ported into the door for more space to operate. The whole assembly is mounted to the door with screws that are painted to match and is very solid. I formed the outside to get the contours and then hollowed the inside to make sure that it was not to thin in any one place. I sealed the whole thing with fiberglass resin and then carpeted it.
Frank |
11-17-2010, 03:59 AM | #35 | |
Re: subwoofer boxes
11-19-2010, 07:36 AM | #36 |
Re: subwoofer boxes
for the normal person, with a standard cab old truck. why the ned of 2 subs.
wouldn't one sub either run in mono or a dual coil sub run in 2 channel. be more than enough and alow more air room (cubic feet) to allow the sub to get lower in the range and be tighter with a sealed box.. I had a home made box in my 97 f150 with (2)jl 12" (very costly, but still their mid range sub) and it was overkill.. yes it sounded killer but the sub amp gain was almost off, as it over powered the rest of the sound, and it wasn't a lack of power to the mids and highs (rockfordfosgate 4 channel 100w per with the speakers bi amped, / and a 50w rockford 2 channel for the doors) sub was powered by a rockford monoblock 500w into 4ohm Last edited by stich626; 11-19-2010 at 07:38 AM. |
01-01-2011, 05:49 PM | #37 |
Re: subwoofer boxes
Hey 3r!c84. We used your dimensions and the box turned out great. Actually we added a 1/2" to the depth and made it 59" wide so we could mount an amp in the box. We also did some fiberglass door speakers and covered them in carpet.
Still need to route some wires and do some cleanup. Other than that, we're happy. Thanks to everyone for your ideas.
California Shloopter '87 fleetside shortbed, 5-7 drop, stock engine '66 VW Beetle, on the ground '57 VW Manx copy, work in progress |
01-01-2011, 06:37 PM | #38 |
Re: subwoofer boxes
Thats exactly what I want is your seat all the way back? I really like those pods you used for the 6x9s does your truck have,pwer windows?
Posted via Mobile Device |
01-02-2011, 12:09 AM | #39 |
Re: subwoofer boxes
The seat is one click forward but my son is only 5'-6" tall so it's good for him. The 10" Addicted Audio speakers had to be mounted all the way at the bottom to clear the back and then we had to mill some of the back panel for assurance.
The side door panels are made of wood frame, fiber glassed and then covered with carpet. A lot of work but well worth it. Yeas we have power windows so that's why the speakers stick into the cab so far. No room inside the door. Oh, we also lined the entire cab with Dynomat. HUGE difference!
01-02-2011, 12:26 AM | #40 |
Re: subwoofer boxes
i would like to do that with the seat all the way back. I have 2 12" cvt kickers. What do you think?
01-02-2011, 01:27 PM | #41 |
Re: subwoofer boxes
Depends on the depth of the magnets. You can start with making a template of the side of the box in the shape you need, then place it behind the seat to see how much space you have. Then put it up against your speaker to see if it will clear the magnet.
I did a quick drawing to see if it would work (see below).
01-04-2011, 05:31 PM | #42 |
needs more $$$
Re: subwoofer boxes
Very clean, shloopter!
1970 2wd Blazer |
01-04-2011, 06:20 PM | #43 |
Re: subwoofer boxes
good info
