TF master cylinder options
Hey Guys!
I need some advise. I'm planning on coverting to a dual chamber master cylinder on my 57 and still rum drums all the way around. I want to use the adapter bracket that mounts in the stock location and not firewall mounted. Can anyone tell mo of a suitable donor vehicle to get a MC from? Of couse I going to buy a new one, I just don't know what to tell the guy at the parts store. Any info would be greatly appreciated. Rob 55-9 Chevy/GMC a.k.a. Frank |
Re: TF master cylinder options
If you are talking about the power booster early vettes had smaller ones in them (I think they are 7" diameter). if it is just the master cylinder, you need one that is specific for four wheel drums.
These guys have the parts to do what ever you want. You could probably get the parts cheaper from a normal parts store but you would have to make your own adaptor to fit them to your frame. http://www.brotherstrucks.com/departments.asp?dept=404 Kim |
Yellow truck club
Talk to MBG Mike. He is a vendor on here and he usually has a discount for us members. Good guy and good prices. I just used one of his under floor mounts with the pedal arm and worked out ok.
Link to PM him is below or look him up in the vendor area http://67-72chevytrucks.com/vboard/p...=newpm&u=18694
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited Last edited by entourageguy; 07-05-2010 at 02:59 PM. |
