Transmission cross member
Well i got the big block installed in my truck and everything lined up pretty good.yesterday i installed the pass. Side header, i used the 2455 hooker comps, and it went in ok but the problem is that the collector sits about half way on the trans cross member.wat do yal guys think i should do about this?
Re: Transmission cross member
What do you mean on? on my caprice the crossmember went right behind the collector so I couldn't add exhaust. I put on a double hump crossmember from g-force.
At the body shop.
I built one from 3/4 ton with out a cat. Notched the center for the mount.
" That didnt make it any newer " " Dont antique the equipment " |
My cross member is right behind my collector too and about half way on the collectors,looks like ima have to notch the cross member to clear the exhaust I plan on running 3 in exhaust
I ordered one from transdapt. Worked great...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
I'm trying to find the part number for you. I can't seem to find the receipt, which i have every receipt for the last 20 years on this truck... What i did was measured inside to inside on the frame, then found that piece on transdapt website. Yes, the ends i welded them on. I bolted the crossmember to the trans, then adjusted the ends, marked them, tacked them in place, then welded them up and shot them with some primer and black paint. Make sure you have the trans set where the original crossmember held it.. I ordered it thru summit racing or jeggs , they don't show them in their catalog..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 Last edited by 69trk; 07-28-2010 at 08:05 PM. |
#9 | |
I can't remember what i paid for mine, but i do think they were cheaper thru summit and jegs. And yes it was a 3" drop..
#11 | |
I have the same as 69trk. about $50 or 60
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
stock mount
#15 |
