08-19-2010, 10:41 PM | #26 |
Truck and auto performance nut
Re: Rack & Pinion on Stock Crossmember?
I've also heard of t-bird racks being used.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
08-19-2010, 10:51 PM | #27 |
Here is the website with the truck build..
http://okcminis.com/showthread.php?t=8849 |
08-19-2010, 11:11 PM | #28 | |
Never Ending Projects
"Mustang fox body " So it's not a MII but a '80's to early '90's Mustang rack. That makes a little more sense, since the later Mustangs are wider than MII setups.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-20-2010, 12:45 AM | #29 | |
Laid Lo
Have to check on that...
Semper Fi, Jeff '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
08-20-2010, 06:14 PM | #30 |
I seem to have two threads going on this topic, but anyway, I measured a 2006 GMC 2wd 4.3L rack, and it is 59" spindle to spindle, and the rack housing is about 21".
They are about $300 new, and $250 rebuilt. Hard to get a photo, but you can see how the rack bolts to the crossmember in front of the engine. I may be able to lay in a piece of angle iron to my 67 and bolt the rack to the vertical, and have the lower horizontal protect the bottom of the rack tube when I am running too low. That rack is used on vans, tahoes, surbs, pickups, and maybe impalas from 02 up on the small engines. Look how short the 4.3 is in the engine bay!
67 C10 Fleetside, shortened, dropped, bagged |
08-20-2010, 06:43 PM | #31 |
at 1st with that rear mount you'd think its a rear steer rack...untill you see where the ends come out.
08-21-2010, 12:52 AM | #32 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-21-2010 at 12:53 AM. |
08-22-2010, 11:29 AM | #33 |
No offense taken. I enjoy good discussion, thats why I joined this site, and thats why I post my hairbrained ideas on this board first before I spend time and money.
Don't know the answer to whether it is the correct rack for a 67. The 06 width is 59", and the 67 is 56". Seems like 3" could be made up in tie rod ends and couplers pretty easy. As for geometry, my plan was to try and place the rack as close as possible to the Flaming River rack, make sure it worked for all control arm and spindle angles, and try it out. That's why I posted here, to try and find someone who had purchased the Flaming River kit, but no one has. Just trying to find a less expensive alternative to a complete subframe swap, and do it safely. I think there is a need for a bolt in R&P that doesn't require notching the frame and doesn't cost $3K. The nice thing about DIY is that you don't have to have all three of the "Better, Cheaper, Faster" conditions. You can try different things on your own time, and just settle for "Better and Cheaper". I really appreciate your posts Scotti.
08-22-2010, 01:20 PM | #34 |
I too am looking to add a r&p and feel about the same on the available crossmembers. There's a whole slew of "static" drop guys that don't care about laying frame. The dropmember would work great for these guys if it wasn't engineered to have the rack several inches up into the frame. I'd buy one if there was one made for us static drop guys where everything bolted in w/o cutting/welding. I've got a welder...so thats not the issue. I'm trying to shed front end weight...and simplify the steering system.
As long as the rack is in line where the drag link normally lives and the ends match the total length of the stock system...don't see why it wouldn't work provided the rack is mounted securely. Using with the fox body rack or t-bird. W/O an available solution for these guys...they're apt to do it themselves. I'd buy the new crossmember engineered for it all..... if it was made.
08-22-2010, 02:05 PM | #35 | ||
08-22-2010, 06:56 PM | #36 |
Lookin forward to the Porterbuilt version... "coil-over" w/rack and a bit less drop to compliment the Stage II mild drop rear. I think I read that it is hard to make work with a front coil spring.
http://67-72chevytrucks.com/vboard/s...d.php?t=396294
Harrol 1968 SWB 1968 SWB 4x4 1969 Suburban 1970 LWB 1970 Blazer 2002 Tahoe Inside every older person is a younger person wondering what happened |
08-22-2010, 09:05 PM | #37 |
optomistic ah-so
On that OKC minis example, it's important to note that the frame has been sectioned and "double" Z'd, probably instead of using air bags for a drop. This means the frame is not as much in the way of a rack as it would be for a strictly bagged drop.
Anyone who chooses to follow that example may need to implement the whole plan of attack including the frame mods. Implementing half-a-solution plan is the same as implementing a WHAT-o-lution?
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
08-22-2010, 10:22 PM | #38 |
that new dropmember still has the frame notched for the end links to pass thru.
08-23-2010, 09:49 AM | #39 |
[QUOTE=68GMCCustom;4152445]that new dropmember still has the frame notched for the end links to pass thru.
Yeah.... I was just showing that coil-over version is close. "coil-over 3.4" might be mounted two inches lower and still provide great ground clearance, rack and pinion, centering the wheel in the well, Lsx mounts, and tubular control arms with the logo.
08-23-2010, 01:20 PM | #40 |
well I hope he decides to build it then! I told him this is what I wanted months ago.
01-10-2022, 07:06 PM | #41 | |
Posted via Mobile Device |
Tags |
pinion, rack, steering |
