Old 08-24-2010, 10:31 AM   #26
3r!c84
Badass
3r!c84's Avatar
Re: sad day /:
[quote=Sarge261;4154657]
Originally Posted by 3r!c84 View Post
Take the throttle body off and remove the IAC motor, clean all the carbon out of the IAC and the throttle body, then put it back together, remove the battery cables and touch them together for about 10 seconds.
You can buy a TB gasket for about a buck or so. Also try removing the EGR valve and clean that too another known problem area, one more thing to check is see if there is coolant leaking out of the CTS, its in the cylinder head under the upper hose boss, if that is leaking you need to replace the sensor and the connector.
Anymore help let me know.
Sarge
ok thankyou i will try that out this weekend when i get home and PM you and let you know from there. thankyou
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-24-2010, 10:42 AM   #27
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: sad day /:
I still drive a beater to work, even at 40 y/o! Bought a 92 Subaru several years back for $1000 with 200k on the clock. Still driving it today, and it still gets 28 mpg! I drive about 40 miles round trip to work and back, so I mostly got it to keep from racking up the miles on my trucks.
At my age, it's all about making sure you can get there and back, and not what you look like while doing it!
Hopefully you can get the idle problem figured out.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-24-2010, 10:11 PM   #28
3r!c84
Badass
3r!c84's Avatar
Re: sad day /:
umm just got 31.1 mpg with a high idle prob is ok.... haha
-00 Saturn 5spd
1/4:13:90
