09-01-2010, 09:55 PM | #51 |
Re: !!!!5.3 Vortec Swap Started!!!!
I guess no one knows anything about oxygen sensors on these LS Swaps?
09-01-2010, 10:46 PM | #52 |
Truck and auto performance nut
only one's in my build will be for the a/f gauge(s).
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
09-02-2010, 03:04 AM | #53 |
69' Chevy Stepside
Well I can offer some advise I did this swap in my 69' and when I wired it up I plugged the drivers side o2 sensor plugin onto the passenger side o2 sensor and didn't even know I swapped them around! Made it run like crap, miss firing under load and a flashing check engine light. You probably don't have this particular problem but just check your wiring. I'm sure your bosch o2's are fine. Scan the computer for codes and let us know what comes up.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
09-02-2010, 09:35 AM | #54 | |
Also, I would run your ALDL into the cab of truck rather than under the hood, will make difficult logging if you ever decide to have it tuned properly. Also, why did you guess at the wiring of the O2s, they are quick connects, was your harness cut up? and make sure you have the FRONT O2s and did not wire them into the REAR O2s.....
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
09-02-2010, 10:12 AM | #55 |
Next project: 1970 K10
I used Bosch direct fit sensors on mine (Bosch #15150) that plug right in, they should be the same for yours. I'm wondering like Shon, was your harness chopped? Is that why you used the universal sensors? I would always go for the direct fits sensors, Bosch or ACDelco.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
09-02-2010, 11:06 AM | #56 |
aren't the universal one's usually only 0v to 1V?
09-05-2010, 11:06 PM | #57 |
Just drove 480 Miles in my new 5.3 swap and it drove great. I have realized now that my suspension is not up to par with the horsepower and torque the new engine puts out. That's the next project. All this and I got 20 mpg!!!! It did drop to around 17 mpg but I was fighting a 25 mph head wind and had my 750 pound Harley Street Glide in the bed of the truck.
09-12-2010, 12:44 AM | #58 | |
09-12-2010, 12:49 AM | #59 | |
The rear O2 sensor wiring was removed from the harness completely, therefore they were not connected to the rear ones. the drives side was miss wired by myself. It has been fixed. Thanks for the help. |
09-12-2010, 12:51 AM | #60 | |
09-21-2010, 09:25 PM | #61 |
im going to swap my old 402 for a 5.3 ,just wondering about what gaer ratio should u run ?
09-28-2010, 11:40 PM | #62 |
I'm running 3.72's in my 12 bolt rearend. and it runs fine. fairly stout in the low end and great highway cruising. Definatly not drag raceing ratio by any means. but great for everyday drivers.
03-21-2012, 01:38 AM | #63 |
Looks good man, im doing the same swap into mine. you ever swap over to a set of headers?
03-02-2013, 04:20 PM | #64 |
doug thorley makes a nice set of 5.3 swap headers.. mine just came in the mail today!
