Old 08-22-2010, 09:12 PM   #26
eagleuh1
eagleuh1's Avatar
More of the same.
Let me know if you need more or an actual measurement for something. Good luck.
I did need to massage the seem lip in the tranny tunnel to get more clearance for the vent tube on top of tranny, to avoid rubbing noises later.
I like where mine sets. Plenty of room up front. Room behind. Not touching firewall etc. I did have to drill rivets out to move tranny crossmember forward, I think about 2 inches. The oil pan( truck pan) clears the front crossmember with at least a 1/4 inch or more. It hangs below frame though. Mines c20 at stock height, so who cares. Skid pan to come later though. The only problems I had with going this far back were the seem on tunnel needed folded back a little, the Lokar cable for shifter to me is a little short, tight bends. And my Doug Thorley headers dumped right in front of Parking brake cables, so it was tight bends coming out to exhaust. I thank my exhaust man for doing such a good job at that fix. Drive shaft needed shortened, but that fixed my vibration problems. Found out shaft yoke wasn't welded on square from factory I guess. Any questions just ask. Good luck. I'll take some pics of the plates I made for the motor mounts tommorrow.
eagleuh1 is offline   Reply With Quote
Old 08-30-2010, 05:25 AM   #27
trenz68
Damage Inc
trenz68's Avatar
Re: LS swappers, post up your pics!!
heres mine
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold
01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame
04 RCSB-joe gibbs clone,22in billets
68 stepper build
http://67-72chevytrucks.com/vboard/s...d.php?t=332337
trenz68 is offline   Reply With Quote
Old 08-30-2010, 02:43 PM   #28
Shon
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 08-31-2010, 06:37 AM   #29
Hart_Rod
Hart_Rod's Avatar
Mine....
Hart_Rod is offline   Reply With Quote
Old 09-14-2010, 08:03 PM   #30
menace121978
menace121978's Avatar
here's a some what current one...
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-15-2010, 04:09 PM   #31
menace121978
The rims are eagle alloy 225's with toyp proxy II.
That is a factory 3 piece escalade covers that have been smoothed by driveway dreams(Gerald) and painted
thanks for the compliments guys
"Dennis the Menace"
Old 09-19-2010, 11:49 PM   #32
LEEVON
LEEVON's Avatar
In progress. The block will be blue like the wheels and it will have cast aluminum finned valve covers. That is an NP833 o/d 4-speed behind it. Just finished putting in a 212/218 .522/.529 cam, LS6 springs, and TSP pushrods. Gonna need some less expensive tires for burnouts...
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-20-2010, 03:55 PM   #33
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
low_84_inchaska - I built a simple box mount for mine that sets up against the rad support, and uses two of the three rad support-to-inner fender mounting holes.
It's since been painted.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-27-2010, 01:16 PM   #34
shaunatk
shaunatk's Avatar
5.3L and mockup transmission are finally mounted!
Here's the mounts we created. The chassis is 2003 S10, and the engine sits back about 8.5":
What it looks like when attached to the frame (using all existing threaded holes and stock S10 motor mounts)
Finally!
I have a re-worked harness, LS1 intake, fuel rails, injectors, and idler pulley relocation bracket. I have an un-tuned PCM. I bought a F-body oil pan and dipstick tube. I bought F-body manifolds (which aren't going to work either).
I still need all of the truck accessories and brackets. Also still need a starter. Also, I still need to cross my fingers, and hope that when we swap oil pans and check the bearings that everything looks ok. I still need an electric fan. I still need a 4L60E transmission (have a lead on one for $50, but needs rebuilt, will probably purchase soon). I assume that I'm going to need a MAF. Also need an air intake tube and filter.
This swap will nickle and dime you to death. Don't go into the swap thinking you're going to spend less than $1500. It's just not going to happen.
If anybody switched to a F-body or Vette accessory system, and still has the truck accessory drive that they want to sell, please send me a PM.
It's going to suck forking out the money for custom headers, but we don't see any way around it. We may try to make our own though...
Our next step is mounting the S10 steering column.
shaunatk is offline   Reply With Quote
Old 09-28-2010, 06:03 PM   #35
Wasted Income
Boosted Member
Wasted Income's Avatar
5.3L / 72 mm turbo / head studs / rod bolts / LS6 cam / 4L80E and Yank 3400
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-24-2010, 05:05 PM   #36
85burb
85burb's Avatar
Here is my LQ4 that will be going in my 85 4X4 burb. Has F body headers and SDPC Hot Truck Series HT1 cam 214/218 555/562lift and 111 LSA. Streat avenger 670 cfm carb and edelbrock duel plain intake. Awaiting fianl clean and assembly and paint.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 10-24-2010, 07:27 PM   #37
mrhino
Here's what I got. 01 5.3l, 4l60e classic Performance tubular engine mounts, Sanderson headers.
Check it out! I Just Started a Build thread
mrhino is offline   Reply With Quote
Old 11-03-2010, 03:58 PM   #38
smokedat
smokedat's Avatar
LS1 on K5 and LS1 on 74 C10
smokedat is offline   Reply With Quote
Old 11-06-2010, 12:04 AM   #39
Oval55rag
Oval55rag's Avatar
67 short step LQ9 TH400
Oval55rag is offline   Reply With Quote
Old 11-22-2010, 02:10 PM   #40
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
mines getting close....
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-22-2010, 09:19 PM   #41
85burb
85burb's Avatar
Got motor mostly back together and only have few more things to order.....we have all said that befor....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-23-2010, 06:59 AM   #42
67C10BUB
67C10BUB's Avatar
Here's mine. 2008 Silverado 5.3L / 4L60E in a 67 C10.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 11-26-2010, 11:47 PM   #43
85burb
85burb's Avatar
Got a few more things installed...
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-29-2010, 05:19 AM   #44
matthew20061
69' Chevy Stepside
matthew20061's Avatar
My 1969 Chevy C-10 Stepside Swap, started off as a simple 5.3L swap with a nice electroic 4L60E. Then I decided that wasn't good enough so I cammed it, that was a great improvement but then I decided to go crazy and swap it out with a completely build up LQ9 6.0L with brand new high flowing L92 cylinder heads, LS3 Intake manifold, 90mm throttle body, Comp Cams 223/231, .610/.617, on 112 lsa. I topped the new motor off with GM Performance Part LSX polished valve covers and hiding the coils in the frame rails!!!
PICS:
VIDEO:
Many more pics in my build thread and I'm planning on taking it out to the track this spring to see how fast it is!
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 11-29-2010, 08:06 PM   #45
matthew20061
69' Chevy Stepside
Originally Posted by mac72 View Post
Really nice job! Ive been wanting to see a pic of those valve covers,thanks for sharing. Do you have any hp&torq numbers with that cam & head combo?
I just got it running for the first time this week so no numbers from my exact setup but I copyed this setup: "LS2 with L92 Heads LS3 Manifold makes 460rwhp and 446rwtq" So it should run awesome!!!
-Matthew
Old 12-06-2010, 06:13 PM   #46
c.brown
c.brown's Avatar
i finally explored this sight farther than the 60-66 section heres mine so far 1966 suburban 6.2 and a 6l90e porterbuilt front and rear
c.brown is offline   Reply With Quote
Old 12-07-2010, 12:59 PM   #47
gopokes
gopokes's Avatar
Doesn't look all that great yet, but had the first start up last night!! That's my brother that sounds like a crazy person laughing, he was a little excited.
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224
gopokes is offline   Reply With Quote
Old 01-04-2011, 01:28 AM   #48
oldmanlance
oldmanlance's Avatar
[attach]676327[Name:  006.jpg
Size:  57.4 KB/attach]
oldmanlance is offline   Reply With Quote
Old 01-04-2011, 01:38 AM   #49
oldmanlance
[attach]676332[/attachName:  5.3.jpg
Old 01-04-2011, 07:20 PM   #50
oldmanlance
im using duel electric fans kit from old air products ,had it on the truck when i had the 402 in it.thought i would go alittle modern with the 5.3 ,4l6e
