Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-16-2010, 01:32 PM   #1
68racer
Yeah baby!
68racer's Avatar
Slick Balancing?
Do you get your drag slicks balanced?
11.37 @116
68racer is offline   Reply With Quote
Old 12-16-2010, 02:18 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Slick Balancing?
Yes.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-16-2010, 03:00 PM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
+1 for balancing
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 12-16-2010, 05:33 PM   #4
C-10 simplex
Where and how?
C-10 simplex is offline   Reply With Quote
Old 12-16-2010, 05:42 PM   #5
Allensracing
Allensracing's Avatar
make sure the weights cant come off
Allensracing is offline   Reply With Quote
Old 12-16-2010, 09:59 PM   #6
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Yes I also get my slicks balanced.
They can not use out side weights. They have to use tape weights.
Then you have to tape them down with a duct tape grade or better.
Just think of it as out of balanced rotating mass.
Think of the carnage it would do if that was your crank.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 12-16-2010, 10:06 PM   #7
vincentgkirkland
vincentgkirkland's Avatar
for sure
vincentgkirkland is offline   Reply With Quote
Old 12-17-2010, 01:22 AM   #8
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
I worked for a tire shop back from '82-'91. Not sure how the balancers have changed in those years but it's tricky if you have a DEEP polished lip and don't want tape weights on the outside of your wheels. Most balancers, at least back then, split the wheel down the middle and gave you a weight for each side making it hard to tape to just the inside. If you find someone or a shop that knows what they are doing, they make glue on weights that are just like a repair patch for fixing a flat. Usually used for balancing semi tires but you can cut them down and actually buff/glue them to the inside of the tire requiring far less weight to balance because it is so far to the outside like the heavy spot in the tire! Just a thought.
prostreetC-10 is offline   Reply With Quote
Old 12-17-2010, 11:36 AM   #9
Marv D
Registered Truck Offender
Marv D's Avatar
The tape on weights and then cover them with a piece of aluminum duct tape is what I usually do. BUT if you have disks make sure you know where the disks run in the wheel so the weights don't hit. A 15" wheel with a 3+" backspace gets REAL CLOSE to the Willwood / Aerospace calipers.
I have to find a shop that is willing to slip a magnet in the hood sensor to bypass the hood safety when your using big pfhat wide tires. Most hoods and computer balancers wont accept anything over a 11 or 12" slick.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 12-17-2010, 03:03 PM   #10
stich626
I've had good luck, dismounting the tire and moving it on the rim.
most times you can get it real close this way u only need small weights..
stich626 is offline   Reply With Quote
Old 12-17-2010, 04:41 PM   #11
Wasted Income
Boosted Member
Wasted Income's Avatar
They're not "Drag Slicks" but I do balance my M/T ET Street radials...no reason not to. Makes driving to work on them a little nicer
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-18-2010, 01:50 AM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
Guess i need screws then, my hoosier D/R's turn on the wheel. Then shakes like... well you know. I peeled off the weights.
Old 12-18-2010, 11:48 AM   #13
68 C-10 KID
Mean Green
LOL. I ran a pair of M/T et streets last year with no bead screws and spun both sides a full 1" That was only on 1 nights worth of racing.
I used my window chalk to mark my tire and wheel.
AKA MEAN GREEN.
Old 12-24-2010, 04:22 AM   #14
team39763
Does doing burnouts throw the slicks off balance? Just wondering. I didn't get my slicks balanced this time because I didn't trust any of the shops around here(100+ miles from the nearest big city). So far I haven't had shaking or vibrating problems.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 12-24-2010, 11:19 AM   #15
noonzor
correct me if im wrong someone please. but im pretty sure the burnout actually helps level the tire for better balance.... like i said, correct me if im wrong.
the slicks i ran on my old mustang were balanced then duct taped over. never had a problem with the tire spinnin on the rim though. did the same thing and marked the valvestem location on rim/tire to check for play and never had anything move.
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
