Old 01-12-2011, 08:45 PM   #1
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
New Autometer Phantom gauges
I have a new bezel with new autometer phantom gauges for sale. I am going another direction so I dont need these any more. The gauges are 2 1/16 in size. The gauges are electric except for the oil pressure which is mechanical. A 5 in Speedo and Tach will fit perfectly in the large holes.
175.00 shipped to lower 48
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 01-12-2011, 09:58 PM   #2
POPO1984
POPO1984's Avatar
Re: New Autometer Phantom gauges
where in texas are you located and what size is the medium hole
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 01-12-2011, 10:03 PM   #3
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
The medium hole as in the middle hole between the 2 large ones? If that's what your talking about, it's 3-1/2 inches
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 01-12-2011, 10:19 PM   #4
chevytruckluver
thanks for answering the question for me myoldchevytruck! as for the other one
I am in Ft Worth...aka "cowtown" therefore I call it "the town of the cow"...lol
Trey
72 Short Step
Old 01-12-2011, 10:28 PM   #5
myoldchevytruck
No problem, good luck with the sale
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 01-13-2011, 11:19 AM   #6
POPO1984
POPO1984's Avatar
Ok thanks ill pass
South Houston
Old 01-13-2011, 06:26 PM   #7
1sik7t2
dave
1sik7t2's Avatar
i'm putting in a 6.0 2005 lq4 motor in my 72 burb so i need all electric guages will this work? and does it come with the bezel ? thx dave
check out my build "DIRTY BURB"
1sik7t2 is offline   Reply With Quote
Old 01-13-2011, 07:56 PM   #8
chevytruckluver
Hi Dave
The oil pressure gauge is a mechanical gauge just like the factory one that came on your truck. It will need to be connected by a small tube to the engine to pick up oil pressure. Your engine will have a oil switch that you can tee into, or you could use a spare port on the block, usually near the oil filter. The volt gauge simply connects to a 12volt source, the fuel gauge is for a 0-90 ohm sender same as the factory tank has. The water temp gauge connects to the heat sending unit. You should have no problems with getting these hooked up to your 6 ltr.
Yes the bezel is included with the gauges
Trey
72 Short Step
Old 01-13-2011, 07:58 PM   #9
chevytruckluver
I also still have the papers that came with the gauges
Trey
72 Short Step
Old 01-14-2011, 06:47 PM   #10
chevytruckluver
ttt
Trey
72 Short Step
Old 01-14-2011, 07:02 PM   #11
1sik7t2
dave
1sik7t2's Avatar
i'll check my fitment when i'm home from work my tach is in the middle soooo need to figure it all out thx dave
Old 01-14-2011, 10:26 PM   #12
1sik7t2
dave
1sik7t2's Avatar
pm sent
Old 01-16-2011, 12:36 AM   #13
chevytruckluver
replied to pm
Trey
72 Short Step
