Old 02-13-2011, 01:33 PM   #1
masterlock
masterlock's Avatar
Question Exhaust question
This may be a dumb question but I dont know the answer sooo... is the length of the exhaust between the headers and the muffler and the muffler to the end of the exhaust important. Reason is I want to run my mufflers just behind the cab and have them dump out right there instead of going all the way back. Is this possible or do I need that length of pipe after the muffler?
masterlock is offline   Reply With Quote
Old 02-13-2011, 02:07 PM   #2
Mrtn15
Mrtn15's Avatar
Re: Exhaust question
I have mine done the same way! And I like it, but as far as performance, it helped me! More flow and power
1986 Single cab 2WD Chevy 350/350
1977 Single cab Dually C30 BB454!
Mrtn15 is offline   Reply With Quote
Old 02-13-2011, 03:04 PM   #3
Toxic Redline
Toxic Redline's Avatar
personally I feel that if you aren't drag racing everyweekend most exhaust setups work fine. You want backpressure on your exhaust so you dont burn your valves, but the way you want to do yours you should have plenty
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 02-13-2011, 03:09 PM   #4
masterlock
masterlock's Avatar
Yeah I just figure if I dont need the rest of the exhaust pipe why have it? I like the whole "less is more" theory.
Old 02-13-2011, 06:06 PM   #5
Zane M
I would also check your local laws especially since it looks like you live in "Smog Law CA". While your idea certainly won't make a difference as far as the amount of emissions, your state may have regulations on how an exhaust exits.
Zane M is offline   Reply With Quote
Old 02-13-2011, 06:30 PM   #6
Toxic Redline
Ya check with local regulations, here in Utah it has to go past the cab of the vehicle by like a foot or so, so if you have a suburban for example you HAVE to run it out the back of the vehicle. trust me we turned my friends 4 Runner exhaust right behind the front tires and within a half hour of driving we had headaches... and that was Fuel Injected.it was like then
68 c20 dump bed
Old 02-13-2011, 10:21 PM   #7
mooseknuckles
mooseknuckles's Avatar
get the mufflers past the cab as far as you can, it'll be alot quieter inside the cab!
mooseknuckles is offline   Reply With Quote
Old 02-14-2011, 11:31 AM   #8
Blue Chevy 1987
Blue Chevy 1987's Avatar
IMO a full exhaust system with tips out the back sounds way better. i had a full system with tips on mine an my buddy had the same cats, both of us running no mufflers but his dumped mid way an no tips. even he agreed mine sounded alot better.
Blue Chevy 1987 is offline   Reply With Quote
