Old 06-18-2010, 08:02 PM   #1
67 c10 guy
67 c10 guy's Avatar
Post my 67 c10 first build
Well im gonna start my build thread. My senior year I bought my 67 c10 from
Mineral wells, Texas. The PO said it would start and drive, but I decided not to take a chance of a break down on the way down to Pasadena and had it shipped. Once the truck arrived it had a hard time to stay running, it wouldn’t go ten feet w/o dying. Three days later all of the old fuel was out of the carb and it ran fine. It’s been nearly two years and im finally starting to get to work on it due to problems on my daily (cracked block). Plans so far are to get the correct fenders and an undamaged core support, fix rust (cab corner, rocker), fix separation an foot wells, rebuild leaking th350 transmission and engine. The 350 v8 will be gone through and might get new aluminum heads from procomp and a cam up-grade and a new park brake system. Other than that im just getting started with the project and don’t want to blow it apart just yet. If any body has advice its greatly appreciated.
Eric
67 C10 longbed 350/th350
13 Ford Fusion 2.0T daily
67 lwb build sold
67 c10 guy is offline   Reply With Quote
Old 06-18-2010, 10:19 PM   #2
chevy71c10
chevy71c10's Avatar
Re: my 67 c10 first build
Nice truck, Looks like a great project truck. Keep us posted with pics and status.
Justin
71' C10 SWB
00' Dakota R/T
05' Z-71 Silverado
16' Z-71 Silverado
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904
chevy71c10 is offline   Reply With Quote
Old 06-19-2010, 01:44 AM   #3
67chevy1series
67chevy1series's Avatar
sweet biulds any progress was the po the one who put the 68 fenders on it
67chevy1series is offline   Reply With Quote
Old 06-19-2010, 10:59 AM   #4
67 c10 guy
67 c10 guy's Avatar
the po did put fenders but there 69 fenders and i think its a 69 front clip minus the hood that they used to repair damage from a wreck. and for progress i have removed the clip, engine, transmission and
removed the carpet. found some seats from a 2004 grand am that i plan to use but they need to be covered
67 lwb build sold
Old 07-11-2010, 03:44 AM   #5
67chevy1series
dang i didnt know you could put a 67 68 grill on a 69 72 fender
Old 07-21-2010, 04:30 PM   #6
67 c10 guy
67 c10 guy's Avatar
Smile Re: my 67 c10 first build
Well the fenders hood and grill didn't really look right on there and the core support was damaged. Others than that not much progress since last post but I got the heads in and they were wrong and i sent them back to get the right ones. So the correct heads should be on the way procomp aluminum heads. I plan on getting the engine reconditioned and put in a mild cam soon
67 lwb build sold
Old 12-27-2010, 02:10 AM   #7
67chevy1series
well what have you done since then
Old 12-28-2010, 02:39 PM   #8
RCbowtie69
RCbowtie69's Avatar
nice truck to start a project good luck
RCbowtie69 is offline   Reply With Quote
Old 12-28-2010, 07:47 PM   #9
67 c10 guy
67 c10 guy's Avatar
Well since my last post I have fount that the engine is bored .060 over and has good crosshatching and I have got the timing gears, heads, completed the valve train and the cam (224/234 lsa 114 lift .465/.488) rockers are 1.6 . Other than that the block is ready to be painted. I need to get new engine mounts and get the frame blaster and coated in por-15
67 lwb build sold
Old 02-17-2011, 03:56 AM   #10
67 c10 guy
67 c10 guy's Avatar
well the motor is built minus balancer pully and oil pan and now im gonna be moving on to the frame and suspension. has anyone boxed in their frame for more rigidity or do these frames even need to be fully boxed? i had thought about doing this but wanted to get an opinion.
67 lwb build sold
Old 02-17-2011, 06:55 PM   #11
67chevy1series
aluminum heads! NICE!!!!!!!
Old 08-15-2011, 02:02 AM   #12
67 c10 guy
67 c10 guy's Avatar
long time without an update and not a whole lot done still, i have gotten the bed off the frame and the engine ready to go in just need to get my cab off and have the frane blasted.
selling my old long tube headers and plan on getting some ceramic coated headers.
67 lwb build sold
Old 08-15-2011, 09:22 PM   #13
trkfrk
trkfrk's Avatar
Looking good.. keep the pictures coming. Are you pulling off the suspension to sand blast/paint?
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 08-26-2012, 04:27 PM   #14
77ChevySharkBite
77ChevySharkBite's Avatar
so.......where's the progress update at mayne? Haven't heard anything on it in a year give us an update ahh!!!!!
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 02-06-2013, 12:44 PM   #15
77ChevySharkBite
Whats an update on the truck man???
Korwin
Old 06-02-2013, 12:18 PM   #16
77ChevySharkBite
Well guys, I know it's been a long time since this has been updated but the project is starting to pick up slowly, so here's some pictures. What we did is of course pulled the frame out.
Just some pictures of how everything is looking right now.
Here's the correct transmission support that's supposed to be with the truck, PO ghetto rigged one up.
The one the PO made
Here's the comparison between the supposed to be tranny mount, and the PO ghetto rigged transmission support.
Does anyone know what these numbers are?
The truck when it was originally built was made with a I-6 I'm guess it was a 250cid? But here's the take the I-6 mounts being removed.
Here's the correct engine mounting hardware for the sbc
It seems as if I didn't take any pictures of it, but we also wire wheeled some of the engine mount hardware, and we also wire wheeled on the frame where the engine mount bracket goes. Right now he's wanting to get the frame ready for sanding blasting, so that it can start being built back up again.
Korwin
Old 06-21-2013, 02:18 AM   #17
chevybuilder18
chevybuilder18's Avatar
lots of work man! but you can pull it off
Her name is Quicksilver
1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER
gotta pay $$ if you wanna play
chevybuilder18 is offline   Reply With Quote
Old 06-21-2013, 08:52 AM   #18
77ChevySharkBite
Like I said in mine, it's not my truck, its a really good friends of mine. I'm just the assistant to help put it back together he's the boss!
Korwin
Old 06-24-2013, 12:10 AM   #19
chevybuilder18
lol ok, good build though! tell your buddy were routin for him
Old 06-24-2013, 12:17 AM   #20
77ChevySharkBite
Yeah he's watching he still gets here and reads what we say just doesn't post much, but yeah it's a work in progress it's going to look sick when it's done!
Korwin
Old 10-28-2013, 10:43 PM   #21
77ChevySharkBite
Where's the update bro??????????????????
Wait maybe I should stop asking you to help on mine and we could get work done on yours
Korwin
Old 10-28-2013, 10:50 PM   #22
67 c10 guy
67 c10 guy's Avatar
Yeah but your gonna owe a lota help on mine? lol especially for getting the outta wack timming set right and preping ur motor to be pulled and then I find out it was the 350 u wanted from the beginning. In gonna get some work done soon.
Anyone know of any good sand blasting/paint shops to get a frame cleaned up?
67 lwb build sold
Old 10-28-2013, 10:57 PM   #23
77ChevySharkBite
Very true and I'll help you out as much as I can just gotta let me know my brother, yeah you really did help my outta wack motor been a lot of help to me lately man.
Korwin
Old 11-28-2013, 04:30 PM   #24
Big Rat
Big Rat's Avatar
Those numbers on the frame are a serial number and a build date. Looks like this '67 was built and assembled August 25, 1990
Those numbers might make reference to your VIN. I know they do on my frame. If they aren't your VIN, then I stand by my first suggestion!
Evan
'69 C20 - Grandpa's 'ol truck
'70 Nova - Birthday present from the wife. She's a KEEPER!
'79 C10 - High school hot rod, BUILD THREAD
Big Rat is offline   Reply With Quote
Old 11-29-2013, 04:00 AM   #25
low&slow
Making progress is always good whether it's slow or fast.
As for that front clip, the hood, grille, and driver side fender are 67-68 parts. The passenger fender is 69-72.
low&slow is offline   Reply With Quote
67 build up, 67 c10
