Member of the longbed union.
Re: Daverods 52
A 4.3 is a 4.3. Just motor mounts are diffrent. You gonna run the efi from it? I would get a ealier harness though.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
SSN 706
Re: Daverods 52
ya I'm going to run efi I can get a 2005 4.3 with 50,000 for 650. It's out of a Silverado.
SSN 706
Re: Daverods 52
Fixed the last of my rusty cab.
SSN 706
Re: Daverods 52
Still looking at engines. What would work better in my truck CPI or TBI? They are both out of a blazer.
SSN 706
Re: Daverods 52
Thinking 350/350 would make my life a lot easier. Simple is better and cheaper. Went to buy my rear air set up and it went "off sale". I'm hoping they will give it to me for the sale price.
Re: Daverods 52
yeah just go with the 350/350. When you look for a air kit look at Guage Magazine store. good deals.
SSN 706
Re: Daverods 52
https://www.ekstensive.com/store/pro...df0c7c4ca399ac I'm liking this.
1 thing at a time is progress.
Re: Daverods 52
Didn't now you had this one going on yet. i knew you got it. I've got some catching up to do.
Alan
Philippians 2:14-16 |
SSN 706
Re: Daverods 52
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-27-2011 at 11:48 PM. |
#10 | |
Re: Daverods 52
Alan
SSN 706
Re: Daverods 52
Did some cleaning and cutting and painting. Ordered some cab mounts so I get my cab on.
SSN 706
Re: Daverods 52
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-28-2011 at 10:32 AM. |
Re: Daverods 52
What's the white stuff. It's 90 in Texas!
SSN 706
Re: Daverods 52
To bad.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-28-2011 at 02:13 PM. |
#15 |
Re: Daverods 52
Great elk rack, I like.....
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 03-28-2011 at 02:26 PM. |
#16 |
SSN 706
Re: Daverods 52
Nice. I got mine with a bow about two years ago. Out of a tree stand next to a river crossing. Ran about 100 yrds and dropped like a rock. More gore.
#17 |
SSN 706
Re: Daverods 52
#18 |
SSN 706
Re: Daverods 52
This guy was hanging around last year got my heart pumping a few times.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-28-2011 at 02:47 PM. |
#19 |
Re: Daverods 52
Dave you should go with a diffrent upper control arm. You will either have to pie cut them or get after market arms, because you will have a bunch of camber when droped.
I got MMW Michigan Metal Works arms for mine. They were $100 for the pair and came with bushings, use your stock cross shaft, and ball joints.
#20 |
SSN 706
Re: Daverods 52
I wonder if camber really matters when it sitting on the ground.
#21 |
SSN 706
Re: Daverods 52
Took my 350 to the machine shop to get it machined/heads done. Got some lowered spindles/headers/engine mounts coming. Tore all my wiring out of my cab. Found a zr2 rear end with posi for 300 need to go get it. Sold my old 52 frame on craigs for 150.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-29-2011 at 11:24 PM. |
#22 |
Re: Daverods 52
I guess you'll just have to see if anything gets in the way when layed out. I was reading yesterday about the s10 rears, The ZR2 is weaker then the drum rears. so stay out of the throttle.
#23 |
vintage car junkie
Re: Daverods 52
You needed drop spindles? You dont really need the upper arms, these frames do not really camber that much. I know mine is maxing out the upper ball joint though so I either need to get different arms or longer travel ball joints. I like the MMW arms, looks like I would get a lot more clearance for the inner fenders if I ran them.
1950 chevy truck, s10 swap, bagged, v8, 18s My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761 Last edited by blitz'd; 03-30-2011 at 08:51 AM. |
#24 | |
SSN 706
Re: Daverods 52
#25 |
SSN 706
Re: Daverods 52
I think it has a bigger ring gear. It's made for off road. You would think it would be stronger? Not really sure what the ring gear does? I just like it because it's wide enough and it has disk brakes. No, I'm no staying out of the throttle.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-30-2011 at 09:27 AM. |
