Old 09-12-2011, 01:06 AM   #176
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 85 GMC Sierra Classic 1 Ton Crew Cab
It looks great Matt! Did you spray the back of the cab too, any orange peel?
The SPID in my step brothers 86 gmc said it was "Frost White", just a little info.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 09-12-2011, 08:57 AM   #177
Mattman2010
Mattman2010's Avatar
Thanks Tony.
Yes I sprayed the back of the cab, everything got sprayed but the firewall and the bottom side of the cab. There is orange peel, but I think I am going to leave it. It really is kinda hard to see it. There are also some places that dirt got into the paint, but they are kind of hard to see as well. In all I am happy with how the cab came out, but its definitely not show truck quality, but i intend to drive this truck everyday.
As for the white, they had several paint markers for fixing scratches and the guy showed me all of the GM whites and Olympic White seemed to be the best looking white out of all of them. it is a very bright white.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 09-24-2011, 01:16 PM   #178
Mattman2010
Well I have been putting the wiring back into the cab and decided to finish painting the front clip. I went ahead and put one fender on just to see what it looks like.
Need to pull the hydro boost off of the other cab and then start hooking things up and I should be able to fire it up before to long.
Build Thread
Build Thread
Thread
Old 09-24-2011, 06:29 PM   #179
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Awesome dude!
Oh and............................................. you suck! J/K
Tony
Old 09-24-2011, 06:57 PM   #180
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looks great man.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 09-24-2011, 07:08 PM   #181
y5mgisi
Second Chance Program
y5mgisi's Avatar
Whoa! How did i miss this until now!? Looks great! Good job!
y5mgisi is offline   Reply With Quote
Old 09-25-2011, 12:48 AM   #182
Mattman2010
Awesome dude!
Dude, I told you I was going to win this race. Oh yeah, Thanks!
Originally Posted by 1972SuperCheyenne View Post
Looks great man.
Thanks man!
Thanks!
I have to figure out what to do with my hydro-boost, it is leaking and I am not sure where to get a rebuild kit, and a remanufactured is $175.
Build Thread
Build Thread
Thread
Old 09-25-2011, 10:09 AM   #183
Conundrum
Conundrum's Avatar
You might check rockauto.com
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 10-24-2011, 11:54 PM   #184
Mattman2010
Well I went ahead and replaced the hydro-boost unit, and rebuilt the steering box, and got the steering all hooked up. I got the brakes bled, steering installed, and the clutch working. Now all I need to do is finalize the radiator mount, tighten a lot of suspension bolts, add some oil, anti-freeze/water, and buy some batteries and then I should be able to fire it up. I am still fighting the SRW or DRW option, but for now I am just going to throw my dually bed on and run it that way. I wont have all the paint done yet, but I should be getting it close to road worthy soon.
Build Thread
Build Thread
Thread
Old 10-25-2011, 02:11 AM   #185
Your41Plague12
Your41Plague12's Avatar
Definitely go dually. Love the white, too!
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 10-25-2011, 02:20 AM   #186
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice job man! It is looking great!
Ryan
1969 Chevy milk truck
Old 10-25-2011, 08:47 AM   #187
Mattman2010
I want to keep it a dually, but I also want to drive it everyday. Parking is not crew cab friendly, let alone dually friendly at college. Maybe I'll have to build a short bed version so I can drive it daily. Thanks!
thanks man! Did you happen to get my last PM?
Build Thread
Build Thread
Thread
Old 10-25-2011, 04:22 PM   #188
Dieselwrencher
Oh, shoot, I did and I forgot to reply to you. I will later man.
Ryan
Old 10-29-2011, 09:40 AM   #189
Mattman2010
Well put the front clip on the truck yesterday and found out that somehow when I put the correct 86 front core support/spring mounts that they are mounted to far back so I am going to have to fix that.
I did however hook up a battery and was able to fire it up with the one battery. I need to get another one but I just wanted to make sure everything was working. I need to add some anti-freeze in the cooling system and then I will fire it up again and try and drive it around.
Build Thread
Build Thread
Thread
Old 11-21-2011, 10:41 PM   #190
Mattman2010
Well I have been working a lot on the truck. I have been trying to get the truck on the road because I think I am going to be changing the direction of this build once again.
I have not gotten around to painting the doors or the bed and tailgate. I should be getting the truck tagged this week, and hopefully get my windshield and back window installed and then I am going to throw the bed on it and some other things.
Now you might be asking, how am I going to be changing the direction of the build. Well After driving this around the farm for a while testing things I have noticed that the turning radius is very large. I am wanting to be able to drive this truck daily, so I am going to be converting my 3/4 ton crew cab frame into a short bed single wheel frame and swap the cab and front clip over to that frame. I want to be able to drive this truck all the time and with it being so long and so wide I don't see that being very good for DD duty. Once I get the short bed built I will probably find another cab to go ahead and build me a crew cab long bed dually on this frame.
Build Thread
Build Thread
Thread
Old 11-21-2011, 11:53 PM   #191
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
It looks good man!
Tony
Old 11-22-2011, 12:03 AM   #192
Mattman2010
Thanks Bub! It almost makes me want to keep it a dually. Ill just have to see how it is when i get the bed on it.
Build Thread
Build Thread
Thread
Old 11-27-2011, 12:09 PM   #193
Mattman2010
Got the bed on it. I started to get clutch problems. It seems as if my master cylinder for the clutch doesn't work right. So I bought a new master and slave cylinder so I hope I can get the bled some time soon and it works right.
Build Thread
Build Thread
Thread
Old 11-27-2011, 10:19 PM   #194
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Nice! Are you going to try to put the windows in yourself? Its not too hard, it just takes some time and patience.
Tony
Old 11-27-2011, 11:12 PM   #195
Mattman2010
My windshield is broke so I am going to get a new one. I am going to go ahead and install the old windows back in, but my trim rings all broke in pieces and so I would need new ones (Not sure where to get them). Then when I get a new windshield Ill just have them install it.
Build Thread
Build Thread
Thread
Old 11-28-2011, 03:23 AM   #196
Dieselwrencher
Great work Matt! It's coming together. It's good to be able to move it around for sure. These things get hard to push around all the time.
Ryan
Old 11-28-2011, 11:51 AM   #197
Mattman2010
Yes they do suck to push around all the time. As you can see there is a 30 ft pontoon boat behind my truck. This summer when my uncle wanted his boat I would have to push the truck out of the way. What you dont see is the hill that leads down to the shop that you have to push the truck up haha.
Build Thread
Build Thread
Thread
Old 11-28-2011, 12:51 PM   #198
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
You have a tractor...
Tony
Old 11-28-2011, 12:54 PM   #199
Mattman2010
I actually used my k10 to pull it, the part that sucked was when the brakes and steering was not hooked up and you had to turn the tires by hand, and pushing it back into the shop without brakes sucked because you had to keep it from rolling down the hill into the shop to fast.
Build Thread
Build Thread
Thread
Old 11-28-2011, 04:37 PM   #200
Dieselwrencher
I know how you feel. We have 3 trucks like this we've been moving around. It sucks bad.
Ryan
