Old 10-29-2011, 11:02 PM   #1
'68 C-20
'68 C-20's Avatar
'67 FWD broken front Leaf Spring
My yard truck is a '67 four wheel drive. Last winter I broke the front primary leaf on the drivers side right at the front eye. A local check of boneyards did not yield any results, so I welded it. It held up for several storms until it broke again. Since I am a pretty crude stick welder at best I brought it to my neighbor who used to weld for a living. He did not want to weld it, but I bribed him into it, it broke when I pulled it down off of jack. :lol So I jacked it up pulled it apart and welded it again with my stick. I got through the rest of winter last year, I don't want to make spring welding my weekend occupation, so I suppose I have to do it right.
I checked with the local spring shops and I cannot get one locally. If I order one from LMC or some such I have to order all three pieces which will add shipping weight and cost that I do not need. I only need the main leaf.
I am in New England. Anyone know where I can procure just a primary leaf?
Thx
DIY body and paint work is cheap, making it look good... priceless
My Toys;
’26 Ford Model T
‘72 Triumph Spitfire 1500
'09 "The Briggs Flyer" Gettin' High.
'68 C-20 is offline   Reply With Quote
Old 10-29-2011, 11:13 PM   #2
71gmcburb
71gmcburb's Avatar
Re: '67 FWD broken front Leaf Spring
get ahold of eaton spring in detroit mi usa. I have used them whenever I need a set (or One) of springs. told them the waight of the rig and some pertinant info and had the springs i needed. I'll try to find a link
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 10-29-2011, 11:23 PM   #3
chisler
chisler's Avatar
Have a look at these guys......very good stuff www.standen spring.com www.standens.com sorry
chisler is offline   Reply With Quote
Old 10-29-2011, 11:27 PM   #4
'68 C-20
'68 C-20's Avatar
www.standenspring.com ? Does not come up....
My Toys;
’26 Ford Model T
Old 10-29-2011, 11:33 PM   #5
FLEET72
FLEET72's Avatar
The Suspension King
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 10-29-2011, 11:34 PM   #6
FLEET72
FLEET72's Avatar
Try http://www.standens.com/leaf-springs.html
Oscar
'95 Jimmy 4X4
Old 10-29-2011, 11:41 PM   #7
'68 C-20
'68 C-20's Avatar
Thx for the replys.
Anyone worked with these folks? Will they make a one-off spring? Or for the money am I just as well off to buy a complete spring from a Vendor.
My Toys;
’26 Ford Model T
Old 10-29-2011, 11:42 PM   #8
chisler
chisler's Avatar
Originally Posted by FLEET72 View Post
Thanks FLEET72 thats it
Old 10-30-2011, 09:09 AM   #9
cdowns
cdowns's Avatar
you should never weld a spring// it detempers the heat treated steel and makes it not spring steel anymore
try the yellow pages no need to pay shipping for things commonly available from a local guy
i spent 30seconds googleing found this
http://www.palmerspring.com/what.html
Old 10-30-2011, 10:37 AM   #10
'68 C-20
'68 C-20's Avatar
If it were anything but a yard truck I certainly would not weld a spring. It has not seen road service in 20 years.
In the yard, and to keep me plowing for the current storm, I will do pretty much anything. As I said it actually lasted for several storms.
I have tried Palmer and Donovan spring and neither of them actually form springs. They purchase spring stock and build up leafs. Apparently my 67 is no longer available as a main leaf. I need to order the complete the leaf set. Just hate to buy more than I need.
I even went through all the board vendors. A couple of them have springs, but only as complete sets, (both sides).
I will give a call to Vintage Chevy Trucks when they open in the morning and see if they have a used one. They list a huge amount of used parts here on the board. If not it is probably off to LMC for a complete spring.
My Toys;
’26 Ford Model T
Old 10-30-2011, 10:38 AM   #11
1972RedNeck
1972RedNeck's Avatar
You will probably want to replace the spring on both side otherwise it might lean on way.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 10-30-2011, 01:46 PM   #12
'68 C-20
'68 C-20's Avatar
My Toys;
’26 Ford Model T
Old 10-30-2011, 02:20 PM   #13
'68 C-20
'68 C-20's Avatar
Well she always has listed a little to Starboard, maybe she will level out! But seriously, this rig is a yard truck. No body, not much interior, well ventilated. It just needs to be functiomal to move snow and haul wood from the back lot to the splitter then to the woodshed.
With the spring broken I can't turn the whel to the right!
My Toys;
’26 Ford Model T
Old 10-30-2011, 02:55 PM   #14
FLEET72
FLEET72's Avatar
If that's the case, any old spring(s) that are the length and width should work. take the measurements and go to pick n pull and cut a deal with the guys in the yard. If the spring lengths are ok you could re-drill the pin if necessary.
Oscar
'95 Jimmy 4X4
Old 10-30-2011, 09:57 PM   #15
'68 C-20
'68 C-20's Avatar
That is a decent thought, thx.
My Toys;
’26 Ford Model T
