11-22-2011, 12:23 PM | #1 |
Has anybody done this??
Taken a 60's cab and bed and put in on a 73--87 frame?
Spoke |
11-22-2011, 01:58 PM | #2 |
Re: Has anybody done this??
Buddy did it with a 65 panel couple of months ago
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
11-22-2011, 10:47 PM | #3 |
there is one in the build threads. I forgot who's truck it was. strodder maybe. I also thought about this. the cab floor had to be notched for the frame.
11-23-2011, 01:42 AM | #4 |
60-66 Nut
Yep, been there done that.....about 20 years ago.
Here's a thread I started about this. http://www.67-72chevytrucks.com/vboa...d.php?t=481023 It depends on how much work you want to do as to the end result. Personally, unless your original frame is unuseable, I see no good reason to change the whole frame. Just upgrade the suspension, brakes and steering.
11-24-2011, 02:16 PM | #5 |
Registerd User
Strodder is doing it.
Posted via Mobile Device |
11-24-2011, 02:29 PM | #6 |
Your better off just changing the cross member, quick and easy.
11-24-2011, 11:53 PM | #7 |
60-66 Nut
Yes and no. He welded the back half of a '73 frame onto his '65 frame. He also had to do some modifying and fabricating on the rear of his cab floor to allow for the different rear frame, to avoid the body lift look.
11-26-2011, 11:22 AM | #8 |
Easy Does It
seems like more work than its worth, I like the frames with trailing arms on the 63-66 set up better than the newer ones, just do the disc brake upgrade.
