#37 |
mini truck racer
Re: Rollcage pics anyone?
I just reread this thread and i will say i took flames right here for out riggers when i put the bar in my blue Luv . I also outriggered the mainhoop and put points from the roth of the seatbelt bar to the top of the frame . The door bars hit plates bolted to the floor . THis didn't pass ! i had to add plates under the floor pan under the plate and have bars bent to tie the plates to the frame . The way it is around here, if it has a frame it has to tie ,, if unibody landing pads will work .
I also have had the same problems as Marv . Expired belts that will recert will not pass ,, but stock 35 year old belts will work . Crazy ! I am about to have bars put in the new truck unfortunatly . with pin in door bars . My suggestion to anybody having Chassis / cage / bar work done is before the work starts put a certifacation stiker in the deal . If you are having a cage built tell them to have it certed before you pick it up . A local guy that is building mine adds $125 to bring a inspector out and ert it . This is cheap insurance . If it isnt right he has to make it right .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Tags |
rollcage |
