Old 12-18-2011, 10:51 PM   #1
mjensen
mjensen's Avatar
T Case
How would you determine if the T Case needs to be rebuilt? This is a Rockwell 221, and rebuilding looks pricey so I want to make an informed decision here.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 12-18-2011, 11:16 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: T Case
For starters, If its not working or makes awful noises.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 12-19-2011, 12:56 AM   #3
mjensen
mjensen's Avatar
Re: T Case
It didn't seem to be too bad (last time I drove it anyway). The only thing that I remember being an issue is that it would pop out of 2WD. My grandpa just had a bungy cord holding it in I'm not sure if that was just an adjustment item or an indication of an issue.
Mike
Old 12-19-2011, 08:59 AM   #4
duallyjams
duallyjams's Avatar
Re: T Case
Upgrade to a np205.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-19-2011, 09:53 AM   #5
67gmcstepside
Re: T Case
I just upgraded my T221 to a NP205 and it wasnt that difficult. I rebuild the trans and the only hard part was getting the heavy trans and TC back in by myself. Very doable. You will need new drive shafts.
67gmcstepside is offline   Reply With Quote
Old 12-19-2011, 04:33 PM   #6
1969K10
1969K10's Avatar
Re: T Case
the popping out of 2WD, would be a spring that is worn out. You are correct, rebuildling a 221 will get expensive. I liked mine much more than the NP205 I'm running now.
That being said, I had to fab a new cross member for the carrier bearing, and shorten the rear drive shaft, when I converted to the 205. IIRC, the front d/s will be OK.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 12-19-2011, 08:33 PM   #7
67gmcstepside
Re: T Case
I have 2 221's. One that worked fine in my truck and a parts donor. If you can describe what you need I can pull it from one or the other. They are going to the scrape yard soon.
Old 12-19-2011, 09:34 PM   #8
mjensen
mjensen's Avatar
Re: T Case
I'm not even sure what to look for to know what I would need.
Mike
Old 12-23-2011, 06:03 PM   #9
mjensen
mjensen's Avatar
Re: T Case
Okay, so I've torn it down just a bit. Can anyone tell me if you think this is worth rebuilding based upon what you see?
Bearing was destroyed.
Mike
Old 12-26-2011, 11:54 PM   #10
mjensen
mjensen's Avatar
Re: T Case
Well, after looking at this a bit more it seems like the input shaft probably needs to be replaced. I'm not sure if I'm going to rebuild this case or try and find me a 205.
Mike
Old 12-27-2011, 09:42 AM   #11
duallyjams
duallyjams's Avatar
Re: T Case
Time to cut your losses and move on.
James
IG duallyjams
Old 12-27-2011, 12:15 PM   #12
67gmcstepside
Re: T Case
I have parts if you need them. Scraping 2 case in the next week or so.
Old 12-28-2011, 10:22 PM   #13
mjensen
mjensen's Avatar
Re: T Case
If you have an input shaft that looks better than this one (and if the bearing that goes with it is in good shape) I would be interested.
Mike
