05-28-2012, 10:56 PM | #1 |
Cigarette lighter housing removal
Im in the process of tearing apart my dash for a fresh coat of paint. I can't seem to figure out how to remove the cig lighter housing. Also any tips on removing the ignition switch would be a great help too. Thanks
05-28-2012, 11:23 PM | #2 |
Active Member
Re: Cigarette lighter housing removal
On the ign. sw. look through this posts:
http://67-72chevytrucks.com/vboard/s...gnition+switch On the lighter, disconnect the ground and hot wire from the back and from the back unscrew the outer housing from the front housing. On mine, I had to hold the outer ring really tight and had to struggle to loosen the back housing but it finally came loose. |
05-28-2012, 11:46 PM | #3 |
the hosuing is in two parts that screw together - kinda like a light bulb and socket - with the dash sandwiched in the middle. Like 68 said, gotta hold one steady while twisting the other. I ususally stick pliers inside the lighter opening and spread them, then just unscrew the houing from behind the dash. It is a bit odd how they go together.
05-29-2012, 12:02 PM | #4 |
Thanks Gents great help
08-05-2024, 11:35 PM | #5 |
70+ ( Old Skool Club )
Oh goody. I pushed my lighter in and now won't release. Sounds like im in for some fun.. Though I'd be a good spot for a USB port.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
